Question about Panasonic Heating & Cooling
Have a problem with CU-PC24DKH, condensor.compressor start on 8.5 Amp and get down to 6Amp and the gauge pressure get down on vaccum, but when you start compressor alone the suction and the discharge work normally. is the condensor faulty?
3 Suggested Answers
  • 334 Answers
SOURCE: Bon-Air mini split 1.5 ton, suction and discharge
Sorry to sat but the tech has no idea what he is doing. The metering device is in the discharge valve, making that line a low pressure, not high. If the "suction" line is hotthen it is running in heat mode.
Posted on Jun 25, 2009
  • 20 Answers
SOURCE: No cooling
More than likely, you have a leak in your system and the refrigerant has all but leaked out. What you need to do is call a QUALIFIED repair tech and have him/her locate and fix the leak, then recharge the system. If you continue to run it, you run the risk of burning up the compressor, then you can figure a total replacement for the system.
Posted on Sep 01, 2009
Why would the lg r410a start cooling then stop?
If its low on refrigerant, the low pressure switch will drop out the compressor. If it has an extremely dirty condensor, the high pressure switch will drop out the compressor. If it has a bad condensor fan, the high pressure switch will drop out the compressor. If the internal overload of the compressor is weak and it is marginally low on refrigerant, the compressor will stop until it cools down. The list goes on and on and on.... These are the first four most obviouse that comes to mind.
Jan 31, 2015 | LG Heating & Cooling
I have a samsung 1 year old fridge that wont get cold at all. the compressor, evap and condensor fans all run and i installed a schrader valve on low side to try to vacuum and charge with no luck. it
Compressor should rapidly bring pressure down from standing pressure to running pressure when switched on. If no change, compressor not pumping. Make sure the line tap valve isn't leaking, and the gas you used was correctly charged.
May 19, 2012 | Samsung RF217ACPN 19.7 Cu. Ft. French Door...
I have a fedders (piece of junk)3 1/2 ton 4 year old unit. It runs fine during the evening after it cools off, but during the day it constantly cuts off and on unless I am spraying it with water. As soon...
sounds like your compressor is overheating is the compressor sweating down the sides? If it is you may have an airflow problem clean filters, clean blower fan motor and the evaporator coil. if this does not work you will need to have someone put a set of manifold gauges on it to see if the proper pressures are where they need to be. Also you can check the amps on the compressor to see if it is sezing or if it is locking out. The compressor is getting to hot is the reason when you squirt water on it runs because you are cooling it down. have you cleaned the condensor coil? Your head and suction pressures will give you a good idea.
Jun 23, 2010 | Fedders A6P09S2A Air Conditioner
For my thesis: 5 condenser problems and 5 solutions
Problem number one.
condenser fan won't come on. solution check the capacitor if good ohm out the fan to see if it is bad. If bad replace fan motor with new one.
2. compressor will not come on. solution check the contactor to see if engaging this applies to problem 1 also. If engages check the capacitor on the herm side if it is bad replace. If good check compressor to see if the compressor is bad. Should it be bad replace compressor.
3. High head pressure not cooling properly dirty condenser coils. Clean coils. With hose and water.
4. Low head pressure frosting accruing on suction line. Check freon levels. Also check inside air filter for being dirty.
5. Condenser unit is failing to come on. solution check the power source check the contactor should the main power be bad check main breaker and replace any slow blow fuses that are bad. Should the contactor be bad check transformer to ensure 24 volts going to secondary side on contactor. Inspect the two wire going to outside unit condenser. replace any broken wire any bad transformer or bad contactor.
Feb 21, 2010 | Carrier 38CKC042 Air Conditioner
Freezer is warm, not freezing at all, fans run
If the fans your talking about are in the refrigeration section, then the unit is not in defrost. The interior fans shut off during the defrost cycle.
There is a condenser fan motor in the machine section by the compressor. If it fails, the problem you described can occur.
If that fan motor is still, and the compressor is cool to the touch, then no power is getting to the refrigeration section.
Could be a bad thermostat, or the unit has tripped off on the high pressure safety switch. The high pressure switch can be one of 2 styles. Auto reset, which means it will try to restart the compressor when the pressures become normal. The other has a lock out feature that requires it be reset manually. If it goes out on the high pressure switch, once reset, check the condenser fan motor to make sure it is running and/or excessive dirt in the condenser, which must be blown out.
Other causes can be a total loss of refrigerant, or a compressor that won't run.
Short of a broken wire all items listed except for a dirty condensor and reset of the high pressure switch, require a decent knowledge of electrical, Knowledge in the use of a VOM meter and amp-probe, as well as a set of refrigeration gauges.
Oct 30, 2009 | Turbo Air 49 cu. ft. / 1388 liter...
My ac comes on in my RV and runs for a about 15 minutes and then the fan shuts off and finally the compressor shuts off. this happens before reaching the cooling temp. When it comes back on the fan does...
The Fan topside , Is the one working? The one that blows on the condensor? If not, your compressor can be trying to start against high head pressure. Ck the other fan, not the one that blows inside, the other one.It cools down the condensor and if the pressure is too high it will hinder the compressor. Good Luck
Sep 12, 2009 | Heating & Cooling
Freezer @ +28 deg/appears common problem B 1st 2 answer right....
Model numbers of Kenmore , starting with 253. are made by Frigidare . The compressor probably has a valve out , either the high-side , or low-side . Probably the low-side valve is bad , therefore , the high-side will pump but not get the freezer as cold as it should be . Both sides have to work . Low-side helps pull the refrigerant thru the system , while the high-side pumps pressure thru the system .
Aug 26, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Check engine light and air conditioning
I Think I Can,
You Might Be Blending Hot Air With A/C Cold Air And Being 100Deg Outside, Your Getting
Really Warm/Hot Air Inside,
Your System Is Charged w/Freon, The A/C Compressor Is On/Engaged,
There Are 2-Aluminum Tubes Comming From The Compressor, [In & Out Pressure]
1 Tube Will Goto The Front Condensor, Infront Of The Raidator,
The OTHER Tube Comming Out Of The Condensor Will Goto A Dryer,
[Aluminum Looking Cylinder] Bigger Aluminum Tube[s]
The DRYER Will Then Feed Freon To Your Evap-Coil Inside Your Car [Cool-Air],
OK, The Dryer Tube's, 1 Of Them Should Be Cool/Cold, Locate That Tube, A Thermometer
wrapped w/Alum-Foil Around This Tube,
A/C ON, [A/C Compressor Engaged]
If You See The Temp Is Around 50-55 Degree's Or Lower, You Have Cold Air,
If Not, Above That, Low Freon, Or A restriction In The System. [Comes Later]
You Have Cold Air, You Have Warm/Hot Air Inside Car/Vents?
You Are Blending Hot Air w/Cold A/C Air, Problem Is With Heater-A/C Blend Box
Under Dash. There Are 2 Seperate Coils Under The Dash,
1 For Winter/Heat, Other [Evaporator Coil] For A/C, There Is a Diverter/Flapper door
That, For A/C, Closes Off The Heater Coil, Or It Should, To Prevent Engine Hot Water/Heat
From Blending w/ Cold A/C Air.
Most Are Controlled By A Diaphram, Vaccum Controlled From The Heater-A/C Controller
On The Dash.
If You Can Select From Defrost Vent To Dash and Floor Vents, Most Likely you Have
a Bad Diaphram That Controls The Heat-A/C Flapper Valve.
Most Time's You Can Open/Remove The Glove Box And See It,
A Temp Fix, For Cold Air, Would Be Remove The Vaccum Line From That Diaphram,
And Plug It, Pull The Metal Rod Back On The Diaphram with a Needle Nose Pliers,
If you Get Cold Air, Take a Ty-Wrap, Around The Shaft, Secure It, To Keep The
Vent In The Cold Air Position.
Then You Will Have To Get A New Diaphram Installed, Most Time's, Can Be Done
Through The Glove Box Opening.
Now About The Restriction In A System,
You Will Need A Set Of A/C Gauges, Car-Off, A/C Off, Connect Gauges.
IMPORTANT: The Gauges Before Connecting Should Show Pressure In Them [Freon]
Either The Gauges Have Freon In Them Or They Are In A Vaccum.
Otherwise They Have Air In Them, Air w/Freon=BAD Things.
OK, Gauges Show Pressure, Gauges Not Connected To Anything,
Open Up Both Knob's, Blue [Low-Side], Red [High-Side]
Gauges Needles will Move/Equal Out pressure,
BOTH Gauges Should Read Same Pressure, If Not, Quick Fix, Remove Gauge Glass
Covers, Need Little Screwdriver, If Gauges Off By ie: 4 psig,
Adjsut Low-Side [Blue] By 2psig and other, by 2psig, [Split The Difference]
So Now Both Gauges Read IDENTICAL Pressure.
Close Both Valves, Blue & Red
Connect Gauges To Car, Car=Off, A-C=Off
You Will See Pressure On Both Gauges,
Low Side Shuld Be Around 75-95psig, Depending on Outside Temp, If Around 60 or less
need freon.
OK, BOTH Gauges Should Show SAME Pressure reading,
If There Is MORE Than a 4psig Difference Between Them,
There Is A restriction In The System,
a Plugged "Orfice Tube" [Filter] Part Cost $3.00, Servicing The Filter, Alot More.
Restriction Causing Might Be , Moisture/Air in System [Improper Vaccum On System During Last Repairs], Compressor Breaking Down [Metal, Black Goo Bul-up]
Hope You Get Some Cold Air Soon.
Jun 25, 2009 | 1999 Mazda Millenia
2000 mercury grand marquis air conditioning won't work
1st Thing,
Located Someone With a Set Of A/C Gauges 134A Freon,
Make Sure Your A/C System Has Enought Freon In It, There Is a Low Freon Pressure Switch
In The Electrical System, Usually, 50-60 PSIG or Less On The Gauges, Will Indicate Low Freon, When Freon Is Low The Compressor Is Dis-engaged To Prevent Compressor Damage.
1] Low Freon
2] Bad Low Pressure switch
3] Blowen Fuse[s]
4] Electrical Problem[s]
[a] Digital Climate Controlled ?
Climate Control Self Diagnose From Button's On Unit, OEM Manual Explains This,
If Yor Auto Has Digital Climate Control.
5] Bad Compressor DC Coil
Note: Does The Compressor Engage, Click-On When Button Is Pressed, But Getting
Only Warm Air?
Is One Of The Compressor Aluminum Tube's Cold, Be Careful Other Is Really Warm/Hot,
If Cold and or Sweating, Dripping Water [Normal], You Are Blending Hot Air w/Cold
Air At The Heater Blend Box, Making Warm Air.
If This Is So, If A Vaccum Controlled Temp Unit, Check For A Vaccum Hose Bad,
Should Be Either 1or 2 Vaccum Lines Going Into Firewall To Feed The Controller
Unit, If OK, Might Be a Bad Blend Box Diaphram, [Control's A/C air, Blocks Off
heater Coil Hot Air].
If Your Auto Is Vaccum Controlled, Can You Changed From Bottom, Dash,
Defrost Air Flow?, Yes, No Vaccum Lost Feeding Controller, Still Might Have
Bad Diaphram Blending Hot Air w/Cold If Your Have Cold Alum-Tubing In
engine Compartment.
If Digital Climate Controlled, Might have Diaphram's, Vaccum Controlled or
electrical Servo's Controlled vs Diaphram [Vaccum] Controlled.
This Might Help, Hopefully, This Is Just For Starter's, There More To Some System's
and Without The OEM Mgr's Manual[s] You/Be Would Be Lost, especially w/Electrical.
Later, God Bless
Apr 24, 2009 | 2000 Mercury Grand Marquis
Heating & Cooling Logo
62 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
