Question about Lexmark Optra E310 Laser Printer
I have imported various .eps vector images into Corel Draw X3 and Illustrator CS3 when I'm ready to print the printer processes it then right before it prints the error light comes on. It says ERROR: limitcheck OFFENDING COMMAND: eofill
Extend the memory of the printer
Posted on Nov 16, 2010
How to repair illustrator file?
And also u can use the same program Illustrator Repair Toolbox
But with working link below:)
http://www.illustrator.repairtoolbox.com/
Dec 15, 2014 | Adobe Illustrator CS3 - Windows for PC...
How do i use adobe illustrator?
Illustrator uses vector drawing tools, which require you to start with a range of points that are connected by lines... and contained areas are filled with color automatically as you draw. Look for the pen tool in the pallette, click points and watch them be joined by lines. To draw a curve, click and drag slightly before moving to the next point. This leaves a curve point, that has a set of handles you can manipulate. Good luck!
Oct 11, 2014 | Adobe Computers & Internet
How do you check for fonts in the artwork and include them with output files
Their is no option to carry your fonts which have artwork, as like we have command in corel draw publish to printing buro. we can read all fonts name throgh
go to file file info. and read all fonts name then copy them from windows fonts folder
Feb 01, 2010 | Adobe Illustrator® CS3 for Mac Full...
Changing resolution in eps options of Adobe Illustrator C3 (mac)
Unfortunately I do not have the answer, but I do have a recommendation for what I did. I exported the file as a jpeg. This allows you to change the resolution there. Hope this helps.
Mar 23, 2009 | Apple Computers & Internet
Xerox 7760 GX squishing print jobs vertically
you need a snippet {software patch installed}call .xerox support
Mar 13, 2009 | Xerox Phaser 7750GX Laser Printer
HP PRINTER
function addess protection fault errors when I try to print file and go through older version of Corel Draw Print setup menu. error says "Application Properties sheet pages may not work properly". Upon execution of print file, CP1518 prints a couple lines of gibirish on top of multiple pages. I have to cancel print job manually and CP1518 needs to be "cancel print job" several times before the printing of gibirish stops. I can print just fine from Adobe Illustrator, so I am thinking that is something within Corel Draw, perhaps I need a new driver so that it works with the CP1518.
Any suggestions appreciated. Thanks.
Sep 12, 2008 | Office Equipment & Supplies
Illustrator to photoshop
Here is everything you will need. I hope you will find this worthy of a FixYa rating.
Import Illustrator CS2-CS3 artwork into Photoshop CS2-CS3
What's covered In Adobe Photoshop, you can import Adobe Illustrator artwork in several different ways, each of which offers a different level of control. When you open or place AI, EPS, or PDF files created by Illustrator, Photoshop rasterizes vector artwork and removes the ability to edit transparency, fonts, layers, and paths. To retain more control over imported Illustrator artwork, Adobe recommends that you drag or paste it into a Photoshop image or export it in Photoshop format.
Drag Illustrator artwork into Photoshop Dragging Illustrator artwork is the quickest way to import it into Photoshop. By default, Photoshop creates a new layer for the dragged artwork and imports the artwork as a Vector Smart Object. (For more information, see "Smart Objects" in the Photoshop Help.) You can import dragged vector artwork as a work path, however, by holding down Control (Windows) or Command (Mac OS) while dragging. To center imported artwork in the Photoshop image, hold down Shift while dragging.
Note: To import dragged type as a work path, you must first convert it to outlines in Illustrator. For more information, see "Modifying letterforms as graphic objects" in Illustrator Help.
Paste Illustrator artwork into Photoshop When you copy Illustrator artwork, you can paste it into Photoshop and retain many Illustrator features. To do so, however, you must properly configure Clipboard preferences in Illustrator.
The Illustrator Clipboard supports a variety of formats including: PICT, PDF, and AICB. Though Illustrator always copies PICT data to the clipboard, you can configure Illustrator so that it also copies PDF or AICB format. These two formats allow you to retain Illustrator features in artwork pasted in Photoshop. PDF retains Illustrator transparency, while AICB format retains Illustrator paths.
You should only select the AICB format by itself if you are going to be pasting paths in to Photoshop. In all other cases, select the PDF format or the PDF format in conjunction with AICB. The PDF format retains transparency and other features in Illustrator such as extended support for spot colors.
To configure Clipboard preferences in Illustrator:
  1. Choose Edit > Preferences > Files & Clipboard (Windows) or Illustrator > Preferences > Files & Clipboard (Mac OS X).
  2. In the Clipboard section, select the desired format.
  3. If you selected AICB, select either Preserve Paths or Preserve Appearance.
  4. Click OK.
Paste options in Photoshop
When you use the Paste command to import copied Illustrator artwork, Photoshop provides the following options in the Paste dialog box:
  • Paste as Smart Object: Pastes the art as a Vector Smart Object that can be scaled, transformed, or moved without degrading the image before it's placed into the Photoshop document. As the art is placed, its file data is embedded in the Photoshop document and the art is rasterized on a separate layer.
  • Paste as Pixels: Pastes the copied artwork in a new layer and rasterizes it at the resolution of the Photoshop image. Use this option when pasting raster objects.
    Note: When you use this option, clipping masks for raster images are not retained as paths. These masks still clip images, however.
  • Paste as Path: Pastes the copied artwork as a work path.
  • Paste as Shape Layer: Pastes the copied artwork in a new vector shape layer. Compound Illustrator shapes retain their attributes and remain editable. Multiple copied paths and clipping masks are pasted as multiple paths that use the unite attribute .
    Note: When you use this option, pasted objects use the foreground color in Photoshop, not the fill color they use in Illustrator. Likewise, transparent objects become opaque.
Export Illustrator files in Photoshop format Exporting Illustrator documents files in Photoshop format gives you the most control over Illustrator artwork in Photoshop. With this method, you can specify resolution and enable anti-aliasing for rasterized artwork. You can also retain the following Illustrator features:
  • Editable text
  • ICC profiles
  • Layers, including nested and hidden layers
  • Masks
  • Transparency
  • Compound shapes
  • Slices and image maps
Note: A compound shape must have either no stroke or a stroke with a round join that uses whole integers for the stroke weight. However, the compound shape can reside on a layer with other objects. In that situation, Photoshop places the other objects on a separate layer in the same layer set.
For more information about exporting Illustrator files in Photoshop format, see "Photoshop export options" in Illustrator Help.
Open Illustrator (AI) files in Photoshop You can open AI files in Photoshop if you save them using the Create PDF Compatible File option.
To save an AI file using the Create PDF Compatible File option:
  1. Choose File > Save As.
  2. Choose Illustrator (*.AI) as the file format, and click Save.
  3. Click Create PDF Compatible File in the Illustrator Options dialog box, and click OK.
Thanks,
Lee
Jun 18, 2008 | Adobe Photoshop 7.0 for PC
Image quality in MS Word
JPEG is a raster image. Every pixel is identified to the computer.
MS Word is resizing the picture to make it fit. When it does this it causes pixels to disappear. This is why you will get blocky images and or unreadable text.
The Solution is
Re size the image and bump the dpi to at least 300. This will add enough pixels to where you won't notice the stair step.
The professional way to do it is with Vector images. This is difficult to do if you are using a photograph. You will need to plot the image out (basically re draw it with lines and bucket fills)
Hope this helps you.
May 29, 2008 | Corel Draw 8
Lexmark Optra E310 Laser Printer Logo
353 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
