Question about Panasonic KX-T7633 Corded Phone
Line not flashing with ringing - Panasonic KX-T7633 Corded Phone
  • Panasonic Master
  • 2,460 Answers
Line not programmed to ring. Try adding the extension to an ICD group.
Posted on Sep 28, 2010
My Samsung iDCS 18D phone will not ring. The Line light flashes, and I can asnwer calls, but it won't ring. I have tried adjusting volume levels, etc- but it seems like the ringer is turned off.
First prove it is not a faulty handset. Find someone elses phone that is the same model as yours and rings then plug it into your line. If that phone rings your handset is faulty. If the borrowed phone will not ring but flashes then it is programming
Jul 06, 2015 | Samsung Falcon iDCS 18D Display Phone with...
How do I turn the ringer off at my phone for external incoming calls?
Go into the extension programming and change the line settings to no ring. It is best done if you have a display phone so you can see the changes. If not, then you will need to look at the flashing line lights when you enter the programming mode.
Press Feature 00. This will take you into the programming mode. You should see the line buttons lit up green. They will be Solid (Immediate Ring) or Slow Flash (Delayed Ring) or Fast Flash (No Ring). I assume yours is solid so push each line button until it changes to a fast flash. Once done press Feature 00 to exit the system and save the settings.
Sep 11, 2014 | Avaya Lands Phones
How Do I for some of my lines only to ring on certain phones? I dont want the rest of my phones to ring.
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Central telephone Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Sep 30, 2010 | Lucent PARTNER18 Corded Phone
Line is on "no lines rings"
Sep 22, 2010 | Lucent PARTNER18 Corded Phone
How do I turn off the ringer for the fax line?
I'm guessing that the fax line also appears on the telephone sets and rings on them.
Aug 24, 2010 | Lucent PARTNER18 Corded Phone
Hello.. We have the parter-18D phone system. one of the phone rings when there is an incoming call, but it shouldn't, since this is not the main phone Ext 10. How can I program this phone to ring only...
Press the right hand intercom once. The display should say Centralized Programming.
May 06, 2010 | Lucent PARTNER18 Corded Phone
How do you turn the ringers off on the phone?
Do Not Disturb (Feature 01) will turn the ringing off of a phone, but it will also send any lines assigned to ring on that phone to voicemail (if applicable).
OR, to turn ringing off in system programming:
From ext. 10 or 11, press Feature button, 00, left intercom button twice, right intercom button once. Enter extension number of phone you wish to remove the ringing line from. Light indicators next to line keys show ringing status. Press line keys to desired ringing preference for each line-
steady green light- immediate ring
green fast flutter- no ring
green slow flash- delayed ring
Press "feature" 00 to exit
Mar 06, 2009 | AT&T Lucent MLS-12D Phone
Line ringing on different phones
Im guessing by Lucent 308 you mean Lucent Partner ACS. Changing ringing on a Partner system is done on either ext 10 or 11.
Hope that helps
Jan 28, 2009 | Lands Phones
Lucent Partner 18D - stop ringing of line 2 at phone
From extension 10 or 11
Press feature 00
Left intercom
Left intercom
right intercom
enter your extension number
all lines that are programmed on your phone will light up.
Solid means immediate ring. Slow flash means delayed ring. Really fast flash means no ring.
Press the line you wish to not ring, 2 times.
Feature 00 when you are done.
Oct 14, 2008 | Lucent PARTNER18 Corded Phone
Mitel 5220 IP phone won't ring when the main line is ringing
WOW
Ok this post is OLD, but for anyone else having this issue, this is the solution...
There is a programming feature that states: DELAYED RING on certain lines, meaning you can physically see a call coming in to the system (via line flashing), but it will not ring at your desk till something like the 4th ring(hence the name DELAYED ring).
If your set does not ring, and you pick up the heandset, the phone system doesn't know if you want to answer the call -or- you just want to make an outgoing call...
Therefore the Mitel system picks up internal dialtone and waits for you to make the initial reaction (hit 9 for a line out or hit a line that is flashing on the set).
Too change this option, a Mitel Tech is required...
Jan 23, 2007 | Mitel 5220 IP Phone
Panasonic KX-T7633 Corded Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
