Question about ViewSonic VA520 15" Flat Panel LCD Monitor
VA520 Resolution Message
I have a Viewsonic VA520 Monitor. Anytime I play games I get a message to change the resolution and the buttons on the message do not work. It hovers there for sevetal seconds, disappears only to reappear a couple minutes later. Have changed resolution to match suggestion, uploaded drivers from viewsonic. Nothing works. I have a friend who has the same monitor with the same problem. Any suggestions?
  • ViewSonic Master
  • 5,568 Answers
Have you tried via the Control Panel/Display function?  The driver provides the means but Windows provides access to those settings.
Posted on Oct 03, 2008
I get "Out of Range" message. What is this?
The monitor resolution settings has been changed.
please set the resolution settings to defaults in the monitor
Jan 27, 2011 | ViewSonic VA902b 19" Monitor
Upgraded OS to Windows 7. Now can only get resolution of 800/600. Viewsonic does not know what a VA520 is. Any help?
The problem is not at your monitor, it's on the VGA card; there are no drivers installed. Clarify me the brand / model of your VGA (or in case of embeded at the motherboard post the motherboard's brand / model) in order to try to locate and post you back the drivers for Windows 7.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Dec 02, 2010 | ViewSonic VA520 15" Flat Panel LCD Monitor
Upon powering up, a banner flashes OUT OF RANGE. What is the fix?
The maximum/native resolution for this display is 1024 x 768 @ 60Hz, you need to adjust your PC video resolution, it is too high right now for the Viewsonic to work. Hook up your old monitor and set the new resolution, otherwise bootup in safe mode (hit f8 key while booting up) and choose VGA support, set the new resolution, reboot.
Apr 29, 2010 | ViewSonic VA520 15" Flat Panel LCD Monitor
Acer al1716 monitor input not supported
You get the message because the game try to run at the PC video resolution that you monitor cannot display/support. You need to run your game at native resolution of the monitor.
Mar 25, 2010 | Acer AL1716 17" LCD Monitor
Out of range message seen after installed new software and reboot
The monitor will display out of range message because the PC video resolution is too high for the monitor to display, the new software may have changed or corrupt the video seting, try booting up in safe mode (hit f8 while computer booting up) and set the video resolution to 640 x 480, then reboot in regular mode, then reset the resolution to the native resolution of this monitor which is 1280x1024@60Hz.
Mar 24, 2010 | ViewSonic VA703B LCD Monitor
Resolution notice keeps coming up it says press 1 to clear message or 2 to disable message i do and it keeps coming up
Hi
The message on the screen will be something like
your best resolution is 1240 X680
To clear this error what you will need to do is right click on the desktop and click on properties, you will be presented with a window that says 'dispaly properties' click on the tab that says settings. in this window change the resolution (using the slide bar) to match the numbers shown on your monitor
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | ViewSonic VA1912w 19" LCD Monitor
My ViewSonic computer monitor keeps displaying a Vga Not Support Message upon booting then the message Out Of Range comes up on a completely dark screen. Need Help
It sounds like the computer is trying to use a resolution that the monitor cannot handle. Boot into safe mode by pressing the f8 key during boot up and select safe mode. Once booted, right click on the desktop and select properties. In settings lower the resolution by moving the bar to the left and reboot.
I would move it all the way down, you can then move it up a step at a time once you are in normal mode again.
Hope this helps
May 02, 2009 | ViewSonic VA721 17" LCD Monitor
Make sure Resolution is 1440 x 900......
hello,
did your monitor support 1440X900 resolution. if yes then go to desktop properties then change the resolution to 1440X900 then play the game.
if not support then remove the game from your pc.
ramesh
Nov 29, 2008 | Envision 19" Widescreen Flat Panel LCD...
Monitor problems
You need to change down the res. to a minor mode. i.e. 800x600 low quality. For Windows enter the protected mode - i.e. after POST (bootup) press F8 then enter with your account, or the administrator. Right-click anywhere on the empty desktop and enter "Properties" menu. Turn the screen resolution down in there (i.e. 800x600); also, check whether your current monitor is recognized by model in there. Re-adjust to a suitable working resolution. If all fails, you can also de-install the video card driver in admin protected mode to go back to basics. Of course You need to re-install it again afterwards when in your original Windows.
Jan 28, 2007 | ViewSonic VP191b 19" LCD Monitor
ViewSonic VA520 15" Flat Panel LCD Monitor Logo
123 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
