Question about Olympus DS-4000 Digital Voice Recorder
Trying to access files on DS-4000 recorder. Recorder has a lock icon on the display but lock feature in menu options will not remove. Files are inaccessable and say they are corrupt when trying to access via programs. If I try to play from recorder it will only play the first 8 seconds of each file.
    Genius:
  • 1,218 Answers
To download users manual go to www.olympusamerica.com
Posted on Sep 30, 2010
How do i unlock the files
The lock function can be found in the menu, however if you did not go there to lock the files, chances are your memory is corrupted. You can reformat the memory from the menu but this will wipe out any recordings. If you need to recover the files, try PC Inspector, Smart recovery. This is a free download, just search google.
Aug 10, 2011 | Olympus DS-4000 Digital Voice Recorder
Correct full memory message on olympus 4000 recorder
You need to erase some files. If there are no files, the memory may be corrupted. From the menu go to sub menu, then format. This will clear the memory.
Jun 18, 2011 | Olympus DS-4000 Digital Voice Recorder
How to remove the write protection from olympus voice recorder
The DS4000 has a lock option available from the menu. press the menu and scroll untill you find lock. If you did not prposely lock the file, most likely the files on the memory card are corrupt. You will need to reformat the memory. The format option is in the menu as well.
May 03, 2011 | Olympus DS-4000 Digital Voice Recorder
I have an olympus ds 4000 and the folders are locked. How do I unlock the folders and what causes this problem? thanks, Sherise
Hello 1 Press the Menu button the menu appears 2 Press FF or Rew button until "lock"in sub menu flases on the Display. 3 Press Menu button the file locking set up process begins. 4 Press the FF or REW button to chose between "ON" and "OFF" ON: Locks the file and prevents from being edit or erased. OFF: unlocks the file and alows to be edit or erase 5 press the Menu button to select the option. Press and hold the MENU button for 1 second or longer to close the Menu.
Nov 24, 2010 | Olympus DS-4000 Digital Voice Recorder
Device stopped recording, or doing anything else. The screen shows a little lock icon. It is fully powered up.
The lock icon means you have switched the "lock" on ...this prevents accidental erasure of files.... if you need the operators manual go to www.olympusamerica.com ...manuals are under "SUPPORT".
Sep 09, 2010 | Olympus DS-4000 Digital Voice Recorder
The Olympus DS-330 read only memory lock
You may need to format the recorder to clean the file system on the recorder. Follow the directions below to format: If you format the recorder, all function settings will return to their defaults*. All files** stored in the recorder will be deleted. If you have important files that you want to save, connect the recorder to a computer and transfer those files from the recorder to the computer before formatting the device. * Date and time settings won't be cleared, so you won't need to set them again. ** Locked files will also be deleted. 1 Press and hold the FOLDER/MENU button for 1 second or longer. The menu opens. 2 Press the up or down arrows button to choose "FORMAT". 3 Press the REC/SET button again. 4 Press the FF or REW to choose "START". 5 Press the REC/SET button. Formatting starts. "FORMAT DONE" displays when formatting ends.
Jun 11, 2009 | Olympus DS-330 Digital Voice Recorder
Lock/read only card message
Make sure all the files from the memory card have been downloaded and saved to the computer. You are going to need to format the memory card to remove the write protect/read only/lock issue. By formatting this will permanently erase all data from the memory card so you are able to use it again.
To format the card: go to Menu - to Submenu - to Format option - Start - then Start again - Press Menu to initiate the process - When done the recorder will be able to be used for recording purposes again.
Dec 18, 2008 | Olympus DS-4000 Digital Voice Recorder
Locked file ?
The folder lock can oly be solved by chosing the option "format" in the sub-menu. But please copy the *.dss - files still resting at your card at your harddisk first.
When the recorder finishes the format procedure, all folders will be unlocked again.
The "Read-Only-Failure" will occur again at recorders with differend user profiles, when you put the switched-off recorder into the docking station first and switch the power button to "on". So avoid this constellation!
Jun 19, 2008 | Olympus DS-4000 Digital Voice Recorder
Locked file
Jun 18, 2008 | Olympus DS-4000 Digital Voice Recorder
DS-400 DIGITAL VOICE RECORDER
Had same problem. Found online handbook for DS-4000 and page 37 pointed way.
Press menu button on the handset.Go to sub menu. Page 37 of online handbook suggests you can lock and unlock from this but I used the format icon on the submenu to reformat the card. Seems to be working fine now.
Feb 14, 2008 | Olympus DS-4000 Digital Voice Recorder
Olympus DS-4000 Digital Voice Recorder Logo
224 people viewed this question
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
