Gateway laptop issue
Can I connect a G'way laptop to a G'way laptop to try to access the harddrive in question? I cannot view screen on Lptp #2 and do not have access to supplemental monitor. Will it read it like an external drive?
  • 1 more comment
  • Terry E May 25, 2008
    WorldVet -
    I'm going to try this as there is a Radio Shack within walking distance...can get there before they close and will work on this possibly tomorrow or Monday. I really need to rescue my son's laptop harddrive...
    Will let you know how I fare, but until then, THANK YOU!!!!
    jtcpl
    WorldVet -
    After reading through related posts on this website, I did connect it to another monitor in case it was just the screen gone bad, but it seems that it is much more than that. It turns on, but I only get the fan noise. It apparently doesn't boot up into Windows XP Pro, it just gets stuck. No drive lights light up to indicate processing, no beeps to hear, only the battery light and the power light are illuminated.
    I guess I just don't want to send it off to the disk doctor and get charged a bazillion bucks to try a data recovery, unless all other viable options have been tried.
    What should I know about the 'disk enclosure' you mentioned, and also, what should I be aware of to protect the surrogate laptop that I connect it to?
    Thanks...
    jtcpl
  • Terry E May 26, 2008
    WorldVet,
    Can I take the Seagate 60GB hard drive that has an IDE Ultra ATA/100 interface type out of Gateway Laptop2 and connect it directly to Gateway laptop1 via a USB to IDE 40-pin adapter cable and read it that way? Both utilize Windows XP (lptp1 - Home Edition, lptp2 - Pro edition)...
    Thanks,
    jtcpl
    Guru:
  • 859 Answers
Yes, you need to connect the the two laptops using a "Crossover Cable" not a standard network cable. Then you'll need to enter Network via Control Panel and find the link for 'setup a new Network Connection' The network type you want is "Peer to Peer". Once this is done you need to turn on sharing for the folders you choose to share. Right click on each folder you want to share for each laptop and click on sharing. The next window allows you to turn on sharing, with a warning, and give the share a unique name such as Gateway1 My Documents and Gateway2 My Documents.
The crossover cable you need you can find at Radio Shack for about $12. Once you have it, mark each end with a sharpie and write a big X on it which is what we use to identify cross over cables from standard network cables.
If you get stuck or have more questions on how to finish this task off once you have the proper cable just comment back or click on my As Me link.
Regards,
Worldvet
Posted on May 24, 2008
  • 1 more comment
  • Glenn Rogers
    Glenn Rogers May 25, 2008
    Does your Son's laptop power up to a desktop? If it won't you won't be able to establish a connection to it. The only other way to access his date would be to remove his hard drive and install it in an external hard drive enclosure and connect that to your laptop via USB.
    Just a thought,
    Worldvet
  • Glenn Rogers
    Glenn Rogers May 27, 2008
    I'll have to check and look that up, the only issue would be the attached power connector as I see it initially. Is the one on the usb cable to the hard drive about 3/4 inches wide?
    Worldvet
  • Glenn Rogers
    Yes, a 40pin connector should be right, its the power connector that needs to match. If it is a match, place the drive on the usb cable in a small cardboard box with a slot for the cable to pass through.
    Once you are accessing the external drive DO NOT move the box in any way or you may damage the drive's data platters.
    OK?
    Worldvet
Red and yellow horizontal lines on the last third of the screen
3 Options
LCD damaged
Flex cable from MB to LCD
Graphic card damaged
First try to connect the laptop to a external screen...its ok???
Remove the lcd and try another one...its ok???
If not....change the flex....its ok?
If not...only one option...graphic card (GPU)
Feb 26, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
Laptop screen color fades in and out
Try external screen...
If the image is ok on external...LCD damaged...if not...GPU problem
Feb 02, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
Mouse keys not working
  1. Click the Start button, and then click Control Panel.
  2. In Control Panel, make sure you are in Classic View, with all Control Panel icons showing. If not, click Switch to Classic View in the left pane of Control Panel.
  3. Click Accessibility Options to open the Accessibility Options dialog box. Click the Mouse tab. Turn on MouseKeys by selecting the Use MouseKeys check box.
  4. Click Settings. In the Setting for Mousekeys dialog box, click the options you want.
  5. Click OK, click OK again, and then click Close to close Control Panel.
Jan 15, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
The screen was cracked, I had it replaced and now it is saying no hard disk its a compaq laptop
Go to BIOS and check whether the harddrive is detecte in BIOS.If it is not detected then the harddrive is either missing or there is a problem with the hard drive connection.Reconnecting the same may resolve the issue
Jan 04, 2011 | Compaq Presario CQ60-220US PC Laptop
I have Gateway NX560XL Laptop. Work fine. Next time tried to use it , it comes on fans run and all, but screen Never comes on. Has harddrive gone bad?? Do i need a new laptop??? I have tried every...
Your screen may have gone out - try hooking up an external monitor with a VGA input. Connect it to the VGA output of the laptop. If you get a display, your screen inverter or backlight has gone out. If the hard drive light on the control panel is flashing then the harddrive is likely ok.
Oct 28, 2010 | Gateway NX560XL PC Notebook
My laptop doesn't boot up. Only get a black screen.
have you tried connecting to an external monitor?
Oct 15, 2009 | Gateway M285-E Notebook
Mbr error
1. You can fix the MBR error by booting the Computer with a Windows Setup disk.
2. Boot from the Windows CD, and press "R" to enter the Recovery Console.
3. In the Recovery Console Enter your Administrator password.
4. Type in the following: bootcfg /rebuild
5. Then: fix mbr
6. Type: Exit
Good Luck!!!!!!!!!!!!!!!!!!
Sep 13, 2009 | Gateway Computers & Internet
Can't boot laptop.
IS something is coming on screen after booting ..if yes then the cable connection to harddrive is faulty if not then your motherboard needs to be replaced..
Feb 28, 2009 | Gateway MT3705 Notebook
Gateway laptop 450ROG video issue when using a projector
Honestly from the information you have listed it sounds like the issue is with your projector, not your laptop. If your laptop was having display issues it would be consistent on anything it was attempting to output display to, such as your monitor.
The projector sounds like its out of focus and possibly has a bad back light in it, I would suggest contacting the manufacture for a possible resolution.
Dec 15, 2008 | Gateway 450ROG Notebook
Replace hard drive on Gateway laptop
get a New 2.5'' laptop hardrive, and follow the steps: - Turn off the Laptop - Take off the Power Supply - Remove the Battery - Remove the Screw from the Harddrive cover plate - Once cover removed,romove the other (2) screws that hold the harddrive - Slide the Harddrive toward the Screw Hole - Lift the Connection End. - Slide the New Harddrive towards the connection end, Put back the Screws & cover plate - install a new copy of Operating System.
hope this is helpful 'suraj'
Oct 10, 2008 | Computers & Internet
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
