Question about Lexmark X340n All-In-One Laser Printer
Lexmark X340 shows the following error code: Fax Control 543:900.xx Fax Init Fail Please I need help, I'm in my midterms exams. Thank you.
2 Suggested Answers
  • 3278 Answers
SOURCE: How do I fix a
Hello.
From FixYa Support (printmastert):
Your problem could be due to an old version of firmware installed on your device. Go to this link: http://bit.ly/biqa0o and type in the keycode 401ec4. That will download the newest firmware to your computer.
Then, to send it to your printer, go back to the above link (http://bit.ly/biqa0o ). Jjust use this keycode usbflash. That will download a usb utility that will help you flash the new firmware to your printer. Your X340 needs to be connected to your computer via a USB port.
Hope this helps.
Posted on Oct 25, 2010
I got code 108 eror
How to solve 108.xx, 108.08 error on Lexmark printers ~ Fix ...
fix-your-printer.blogspot.com/.../how-to-solve-108xx-10808-error-on.ht...
How to solve 108.xx, 108.08 error on Lexmark printers. A 106.xx, 107.xx, 108.xx, or 109.xx error indicates a problem with one of the ... Libell?s : Error code ...
IBM OPOS, Common Error/Return Codes - United States
www.ibm.com/support/docview.wss?uid=pos1R1000395
IBMMar 30, 2006 - I'm new to OPOS and get error return codes or result codes. What do ...108, OPOS_E_OFFLINE, The physical device is not connected or not ...
why am i getting error code 108 - QuickBooks Learn & Support
Dec 26, 2015 | Office Equipment & Supplies
Faxcontrol.c 546: 900.000 fax init failed
Hello Your problem could be due to an old version of firmware installed on your device. Go to this link. http://bit.ly/biqa0o and type in the keycode box in first this keycode 401ec4 that will download the newest firmware to your computer. Then to send it to your printer download the following from the same link just use this keycode usbflash that will download a usb utility that will help you flash the new firmware to your printer. The X340 needs to be connected to your computer via USB.
Dec 12, 2009 | Lexmark X340n All-In-One Laser Printer
Lexmark x340 error:''917.01 service transfer error''
Is the printer connected straight into the wall outlet? Make sure it is. Do not use any UPS or surge protector.The most likely cause is a faulty HVPS. It may also indicate a problem in the transfer roll area. You may need to have that replaced.
Aug 07, 2009 | Lexmark Office Equipment & Supplies
Lexmark fax machine series x4270 has an error code saying #1200
Please click on this link :
http://support.lexmark.com/perl/support/support.cgi
and then click on support ,once the page is opened please center X4270 in
Search by Model ,after that choose Lexmark X4270 ,after seconds a page will open and then in
Search the KnowledgeBasePut this number and follow the steps given:
ENUS23485
good luck...
Oct 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Brother MFC-5840CN unable to scan
From Brother Customer Service email:
You can try the following reset - it will most of the settings back to the default options.
Unplug power cord to the machine.
Press and hold down Menu.
Plug power cord back in.
Let go if menu when fax/scan/copy flash.
You may see either "maintenance" or "machine error xx" on the screen.
Type stop/exit, 9, 1.
The machine should show "param init" or similar to show that the reset is being done.
It will then go back to or machine error.
Type stop/exit, 9, 9.
This should take the machine out of maintenance mode and back to normal.
If the error is still present the machine will require an engineer to resolve the issue.
Jul 08, 2008 | Brother MFC-5840CN All-In-One InkJet...
HP-3050 priter is showing memory low in time of fax
Please perform the following:
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
Apr 25, 2008 | HP LaserJet 3050 All-In-One Printer
Lexmark X340n All-In-One Laser Printer Logo
613 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
