Intel D101GGC Motherboard Logo
Anonymous Posted on Sep 28, 2010
Can ddr1 be used for intel D101GGC - Intel D101GGC Motherboard
Anonymous
Level 2:
New Friend:
  • Expert 62 Answers
  • Posted on Sep 28, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
62
Questions
0
Helped
16568
Points
184
Yes, you can use only DDR1 memory. If you have a CPU with FSB at 800 MHz, it will run at 400Mhz (in case of a PC3200 module), with FSB at 533Mhz it will run at 333MHz.
If this is the solution for your problem, please rate my post, otherwise give us more details.
Regards,
Andras
1helpful
Is it possible to add 1GB DDR1 RAM 333 MHZ to INTEl D101 GGC
u can use the 1gb ddr1 ram,if the sound is coming then may there is two problem
1.may be the ram is damage
2.your motherboard is not supporting 333mhz bus support
try to find 400mhz ram instead of 333mhz
Upgrade ram
hiya
this board is ddr so you will need ddr400 or pc3200 and a maximum capacity of 2gb so be carefull with 1 gb sticks as sometimes this causes system crashes
hope this helps
Regard Rik
2answers
RAM
check your previous memory if its dd1, ddr2 or dd3 and check also your motherboard's manual for this. be sure that you add the same specs of memory otherwise remove your previous memory.
thank you for using fixya
CHARCOIS
5helpful
2answers
Intel p4 (r) motherboard drivers with ddr1 ram
Try this driver ...it's for the chipset for the boards with the ATI Radeon Express video:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=2229&DwnldID=9557&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
Let me know if this helps, and be sure to rate my answer :)
4answers
Memory Upgrade
ask for ddr1 ram of 1 gb.also take your old ram which is at present in your pc to match the locks with the new ram.
it will cost u near to 50$.
thanks.
3helpful
8answers
Intel D101GGC Motherboard PCI Express compatibility issues........
i'm using NVIDIA GEFORCE 8600 GT on my d101ggc board and its working fine
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
