Question about Motorola Mobility H700 Wireless Headset
Mic Problems with H700 and Ps3
I have my bluetooth connected to my Ps3 and it worked fine till recently. The problem is when i use it I can hear like i use to but now people cant hear me. My microphone is not taking what im saying.
  • 8 more comments
  • Anonymous May 25, 2008
    Yeah I have the same problem too.
  • dealsticker May 30, 2008
    same problem since I bought it
  • Anonymous Jun 02, 2008
    same here
  • Anonymous Jul 04, 2008
    same exact problem
  • Anonymous Jul 15, 2008
    I can hear other people, they can't hear me.
  • rojordan Aug 11, 2008
    I HAVE THE SAME PROBLEM
  • Anonymous Aug 12, 2008
    Same problem
  • Anonymous Aug 19, 2008
    people can not hear me the mike is not working
  • Vaiodrums Sep 28, 2008
    I AM ALMOST READY TO SMASH THIS 400 DOLLAR PAPER WEIGHT BECAUSE OF THIS AND HAVE TRIED EVERYTHING, INCLUDING EXCHANGING 3 OF THEM WITH BEST BUY TO TRY AND CORRECT. SOMEONE PLEASE SOLVE THE ISSUE AND LET MY VOICE BE HEARD
  • Anonymous Oct 04, 2008
    They **** just go for the cheap jabra bt135 or the plantronic 320
  • 4 Answers
Hmm.
1.well try pressing those little arrow buttons on the top and bottom of the headset.
2.Try charging it until the ring turns green.
3.On your PS3 go into accessories, audio and increase the output volume
Hope i helped :)
Posted on Jan 05, 2010
#1 helped me. thanks :)
Motorola sucks, go for the Jabra bt135 or the Plantronic 320
Posted on Oct 04, 2008
I have the same problem also, unfortunatly, this is a problem i have had with several headsets, to correct the problem you have to exit out of the game(or turn off your ps3) and reconnect the headset..
Posted on Aug 15, 2008
Mine was working until yesterday and now I do not know what to do
Posted on Aug 11, 2008
Yeap me 2
Posted on Jul 14, 2008
I've been using my Motorola H700 with my LG phone for over 1 year with no problems. Now it will no longer connect, I've charged it till the light is bright green but my phone is not able to connect to it....
You should remove this item from the phone and reconnect / pair it again. In the manual for the headset you have information on how to reconnect the headset to the phone and the phone have to be in "discover" mode for bluetooth
Jan 02, 2011 | Motorola Mobility H700 Wireless Headset
H700 Motorola Bluetooth works fine except when I talk
I used this solution and it worked...good luck with yours: http://www.geocities.com/jconkwright/H700fix.html
Apr 02, 2009 | Motorola Mobility H700 Wireless Headset
Mic problems online
If your mic is a bluetooth then it could be that your far away from your ps3 when your playing.
Aug 05, 2008 | Sony Resistance: Fall of Man
Purple light on H700 will not stay lit
I was having trouble with the same thing. The light would flash purple when closed, I opened and it stayed lit only for a second. Give it another second, I found it flashed off then came back on steady for pairing mode.
Mar 26, 2008 | Motorola Mobility H700 Wireless Headset
Reg: H700 connection with sony ericsson 580i
You may have to get a bluetooth headset specifically used with Ericson or change bluetooth setting on your cell to handsfree
Jan 08, 2008 | Motorola Mobility H700 Wireless Headset
Help with pairing
narrow down possibilities
with h700 in off position you held down the center button till it turned pink then opened the mic so that it stayed pink?
told the phone to add new device?
made sure that bluetooth is turned on under settings?
i just got a h700 myself and it was very easy to sync.
Dec 23, 2007 | Motorola Mobility H700 Wireless Headset
H700 Bluetooth
its probably very cost effective to replace it at www.n1wireless.com about 30 bucks The leads that connect the folding mic are probably broken moving parts with contacts usually have a limited life.
Dec 11, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 bluetooth "transmit" problem
This is how I fixed the same problem on mine. I wear it outdoors all the time and it probably got wet and deteriorated the foam on the mic.
Nov 17, 2007 | Motorola Mobility H700 Wireless Headset
Connection problem
noavatar_s.png By nonexpert_s.gif Guest
Rank: Not rated
Rating: 0%, 0 votes
First, turn on your bluetooth on your phone.
Flip the boom mic on your H700 and hold down the call button for 5 seconds.
The indicator light should be purple. That means it is in pairing mode.
Then using your phone, attempt to connect to your H700.
It'll ask for a passkey. The default passkey is 0000.
Nov 08, 2007 | Motorola Mobility H700 Wireless Headset
How to do pairing
Thank you. I called a 1-800 number for tech support but they told me I had to wait 14 days from the date of purchase before they could help me. Your suggestion was right on the money. Thank you.
Jul 18, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
474 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
