Question about Sanyo Televison & Video
The tv turned off 4 times in 3 or 4 mintes and will not turn on now .
  • 732 Answers
Sally, You or hubby or boyfriend will need to investigate the internal "switch-mode-power-supply" because it may be going into "shutdown mode" because it has detected a "fault condition" with itself or another periferal electronic circuit. If not into DIY repair, I suggest contracting out the repair work. Before you do that, a visit to YOUTUBE will help. Search out similar or same size Sanyo model there and here at fixya for any history of typical "black screen of death" symptoms that may be the same as your unit. After your research is done return to this posting and provide us tech's more info and what you intend to do about your sanyo unit. 12fixlouie
Posted on Sep 28, 2010
My Tv turns on as soon as you plug it than runs with a perfect picture for 1 mint than off & back on by it self & runs for about 5 mints than turns back off & doesn't turn back on until I unplug it!
The inside of your projection tv is dirty. Clean the bulbs but leave no fingerprints or oils on the lamps. Clean the mirror while you are inside it as well for a much brighter picture.
Mar 20, 2015 | Televison & Video
How to turn on internal camera in Linux Mint?
Hello, Mint is built from Ubuntu and Debian, so if you are having a hard time finding a fix, usually it can be found at askubuntu.com. For instructions on turning on an integrated webcam, please see this page: How to turn on the integrated webcam
Hope this helps
Aug 27, 2014 | HP Paviliondv4-1199es Lcd Screen 14.1 Wxga...
Hd-56g647aa jvc tv theres a tv lock code kids got ahold of the tv remote but the lock comes up all the time and cant watch tv for longer then ten-fifteen minutes screen turns black and tv locks ive been...
Hi Anthony
Please try to go on the tv lock code features, may be you were able to set time. You just mention that 10 to 15 mints your tv will turn to black and then lock. You need to off the setting.
Jan 16, 2014 | Televison & Video
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
Tv switches off after 5 mins
There might be three or more reasons for this:
1) The sleep timer may be on causing the TV to turn off after a preset time.
2) If sleep timer is on and no signal from the remote is received for a preset time (Samsung: 15 minutes) the tv will turn itself off.
3) The TV may have been turned on automaticaly with "On Timer". If so, and no signal is received for a preset time (Samsung: 3 hours) the tv will turn itself off.
4) A fan is not working or a vent is blocked causing the TV to overheat and turn off.
For 1) thru 3), go to the "setup" menu and make sure "sleep timer" and "On Timer" are turned off.
May 09, 2009 | Televison & Video
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
The tv just randomly turns off by itself
Check to see how many times it blinks when turning off and then look for the codes for Sony tv blinks. this will tell you what's wrong. This set is notorious for Shorted tubes.
Feb 27, 2009 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
