Question about Car Audio & Video
1985 Mercedes 300SD: The radio DEH-P4500MP was removed for console shifter repair. The radio is properly installed and the main wire harness connector and the antenna are properly connected. The radio powers up and indicates that when commanded the unit changes from AM, FM and CD functions. Volume indicates that it increases and decreases as commanded, however no sound at all is output at the speakers. The radio was functioning prior to removal. The vehcile wiring diagram indicates a fader bwtween the radio and speakers. The fader and speakers power and ground circuits are all provded and controlled by the radio on the facory wiring digram. Any direction would be appreciated.
simplemitch
  • 752 Answers
SOURCE: Pioneer X MT- 2000 Stereo Bookshelf Unit - No sound!
It definitely sounds like it took a surge. yhe Power Amop IC in those things are pretty sensitive. Any decent repair shop should be able to repair it for under $125.
Posted on Sep 18, 2007
djnick989
  • 1067 Answers
SOURCE: no sound
see if u can get master speaker wiith cables on it that died on ebay best bet what kinda are these
Posted on Jan 09, 2008
micromaster
  • 3614 Answers
SOURCE: I have a PLCDCS90 Casette/cd
any other unit have connected??
Posted on Apr 22, 2008
myob247
  • 1342 Answers
SOURCE: after market radio to install
Here's a wiring guide for your 1997 CRV
Posted on Apr 27, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Pioneer DEH-2000MP Radio In 2001 Chrysler T & C
Hi there!
It is possible that the original connectors are wired differently to the new radio.
Find the speaker cable colour on your vehicle, and match the pins to the connectors on the radio. This may be given in the manual.
You may need a conversion cable for fitting. These are readily available.
Hope this helps you.
Posted on Jun 14, 2008
Can't get audio
your wiring is wrong, get diagrams for the car radio as well as the radio you bought.--Good Luck.
Jan 28, 2013 | Pioneer DEH-1400 CD Player
Will the pioneer deh p3100ub fit a 92 civic?
Yes, it should slip right in, but I recommend you buy the adapter for the wiring harness. Look here for details and instructions are pasted below:
http://www.crutchfield.com/p_130DEH1700/Pioneer-DEH-1700.html?tp=5684
1992-95 Models
See Figure 4
Removing the radio will require removal of the front part of the center console.
The original equipment radio has a coded theft protection circuit. Before beginning removal, be sure to know the code for re-installation. The code is erased whenever the battery is disconnected or the No. 32 (7.5A) fuse from the under hood fuse/relay box is removed. When power is re-connected, the word "CODE" will be displayed and will require entry of the 5-digit code for that particular unit.
WARNING All SRS wire harnesses are covered with a yellow insulation. Read the SRS precautions found in this section and install the short connectors as described.
  1. Disable the SRS system as described in this section.
  2. Remove the center instrument panel by removing the four philips screws on the top and sides.
  3. Disconnect the 4-pin connector from the cigarette lighter.
  4. Remove the two screws, then disconnect the 16-pin connector and the antenna lead.
  5. Carefully pull the radio/cassette player out.
To Install:
  1. Plug in the 16 pin connector and install the two retaining screws.
  2. Plug in the antenna lead, the cigarette lighter and carefully install the unit.
  3. Install the center instrument panel. Re-connect power to the car, and enter the 5-digit theft protection code for the radio/cassette player.
  4. Enable the SRS system.
Aug 14, 2011 | Pioneer DEH-1700 CD Player
Installing DEH-P3700MP in mitsubishi diamante need wiring diagram
The following may help you. The first is for the vehicle the second for the stereo. Good Luck.
Battery WHITE/YELLOW (+) RADIO HARNESS Accesory WHITE/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination RED/BLACK (+) RADIO HARNESS Dimmer RED (-) RADIO HARNESS Power Antenna YELLOW/WHITE (+) RADIO HARNESS Amp Turn On YELLOW/WHITE (+) RADIO HARNESS LF Speaker (+) WHITE LF Speaker (-) ORANGE RF Speaker (+) YELLOW RF Speaker (-) BROWN LR Speaker (+) RED LR Speaker (-) GREEN RR Speaker (+) BLUE RR Speaker (-) BLACK Amp Location MOUNTED TO BRACKET IN RIGHT SIDE OF TRUNK Steering Cntrls YES THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTARĀ® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT. Speed Cntrl NO Radio Security YES Securityiadame_18.jpg
May 14, 2011 | Pioneer DEH-P3700MP CD Player
How do i remove a pioneer deh-p4500mp radio from the car
The removal keys for this unit are not the usual "U" or "HorseShoe" keys. Disconnect the live feed before starting.
You require the Pioneer removal keys to avoid damaging the unit. Your local accessory dealer may loan them but cheap enough to purchase. Once the unit is out you simply gently pry at the locking tabs which retain the cage into the dash facia. I normally use a firm electrical screw driver for this part.
Remove the loom and antenna etc. from the cage connectors and it should be free
Mar 29, 2011 | Pioneer DEH-P4500MP CD Player
I need a FREE, Pioneer DEH P4500MP wiring diagram? Thanks
If this is your Model : http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/In-Dash/CD-Players/ci.DEH-P450MP.Support
Click on Download Owner Manual you'll have the Wiring Diagram in it !
Basic Wire are :
Yellow : Constant + 12V
Red : Acc + 12V
Black : - Ground
Orange : Dimmer Light
Blue : Electric Antenna
Blue/White : Remote Controller ( For Amplifier )
And 8 Wire for Speaker's each with a +/- wire ! Negative one's has a BLK line on it ! I Hope this Help you !
Aug 11, 2010 | Pioneer DEH-P4500MP CD Player
1985 Mercedes 300SD Glow plug light does not come on.
Glow plug fuse under hood of car, driver side close to head light . There is a cover pull off and see the blown fuse.
Nov 23, 2009 | 1985 Mercedes-Benz 300
1985 mercedes benz 300sd...when stoping there is a loud clunk noise...no shimy..had ball joint replaced and brake caliper
On my 300sd I have this same issue. I think what is happening is that as you reach a stop, the transmission downshifts which leads to a rapid increase in resistance in the driveline so anywhere there is play between the transmission and wheels will slap around. There are two potential sources, these are the center carrier bearing and the the rear differential mount point. On the rear differential there is rubber cradle that it sits in, which can dry out and develop some play. Good luck.
Oct 11, 2009 | 1985 Mercedes-Benz 300
Pioneer DEH-P3300 and 94 Mazda
Hello ryan_jaime,
It's good that you have an aftermarket Mazda wiring harness. It will allow you to make all of the connections in a well-lighted and comfortable location rather than fumbling around behind the dash.
If you are somewhat skilled at soldering, the most secure, electrically conductive, and positively insulated splices are made with solder and heat-shrink tubing. You can get the needed equipment from any Radio Shack, Lowe's or even WalMart. Be sure to put the heat-shrink tubing on the wires BEFORE you solder them together. I had to say that! Because I've forgotten many times! But if the soldering route is not for you, get properly sized insulated inline crimp splices and the appropriate crimping tool. Match up each wire by function on the Pioneer harness with the corresponding wire on your aftermarket harness. Most of the time, the wires will be color-for-color matched. But make sure, sometimes wires for things like "illumination", "dimmer", "mute", etc may not be the same colors.
Disconnect the negative battery terminal while you are working behind the dash. After you have the harnesses spliced together, plug the radio end into your Pioneer, remove the old radio from the dash opening, unplug the antenna and wiring harness plug and plug the other end of your spliced harnesses into the vehicle plug and the antenna plug into your Pioneer's antenna connector. Slide the Pioneer loosely into the opening, but don't secure it yet. Reconnect the negative battery cable and test the receiver. If everything works, slide it into the dash opening and secure it. Use the rear support stud and rubber bumper if needed. Install the trim ring or separately purchased dash kit as required. Put the "face-fixing" screws in to prevent removal of the faceplate if desired. Reinstall any dash trim removed and you're finished.
Hope this helps.
Jul 08, 2009 | Pioneer DEH-P3000 CD Player
Car Audio & Video Logo
286 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
