Question about HP LaserJet P2015 Printer
My HP P2915 goes to "sleep" after a few minutes of operation, then can't wake up without being shut off, then turned on again. I assume I need a new circuit board, but don't know which one, and where to get it.
bschilz
  • 2049 Answers
SOURCE: My HP Officejet 6500 wirless
Solution one: Plug the product directly into a wall outlet to make sure the power source functions correctly.
1. Disconnect the power cord from the back of the product.
2. Unplug the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
3. Reconnect the power cord to the back of the product.
4. Try to print again from the computer.
NOTE: If the product prints when plugged directly into a wall outlet, the power strip or surge suppressor might not allow enough voltage to reach the product.
If the issue persists , continue to the next solution.
Solution two: A semi-full reset returns the following settings to the factory defaults:
· User menu settings · Telephony parameter values · Country and language selection · Fax memory · Fax journal information · Speed dial and broadcast lists · Personal header information · Junk file numbers
1. Press the Power button to turn off the product, and then unplug the power cord from the wall outlet.2. Disconnect the power cord from the back of the product, and then wait 20 seconds. 3. Plug the power cord into the wall outlet. 4. Press and hold # and 6 while reconnecting the power cord to the back of the product. Press the Power button to turn on the product, and then follow the instructions that display on the control panel to select the product settings.
Posted on Oct 02, 2009
  • 223 Answers
SOURCE: goes to sleep after a few hours of no operation.
This is a problem with either the formatter board or the dc controller, try doing an nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years.
Al
Posted on Sep 30, 2010
SOURCE: I have an officejet 6500
have an officejet 6500 wireless printer and the printer goes to sleep and wont wake up without unplugging it
Posted on Nov 07, 2010
puertobori
  • 7733 Answers
SOURCE: have an officejet 6500 wireless
Power Save Mode.Just press the on/off button or wait for the printer to wake up when you start a print job.
SOURCE: HP C310 Printer goes into sleep mode in 15 min of
open the my computer folder then open the printer folder then open the settings tap you can turn the enegry setting off no more going to sleep.
Posted on Dec 30, 2010
How to turn iPod of
Well, to turn it off normally, just HOLD the sleep/wake button for 6 seconds or so and sliding the power-off button. To turn it off completely, as in a frozen state, hold BOTH the SLEEP/WAKE button and the HOME button for about 6~10 seconds and it should shut down without asking you to slide to shut off.
Apr 13, 2014 | Apple iPod Audio Players & Recorders
Printer not responding hp photosmart 6525 after going into sleep mode
My printer will not print after sitting for about 30 minutes. As soon as I turn it off and then back on the job I previously sent, prints out. I tried changing the amount of time before it goes to sleep but this does not correct it and does not seem to be related. You can hit the check mark to wake it up but it still will not print until turned off and then on. Source: How do you turn off the sleep mode in a HP 3600 printer?
This is the only solution is see and it didn't solve the problem
Nov 30, 2013 | Office Equipment & Supplies
Windows sleep mode problems
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Dec 21, 2012 | Computers & Internet
I have an officejet 6500 wireless printer and the printer goes to sleep and wont wake up without unplugging it.
Nov 01, 2010 | HP Officejet 6500 Wireless All-in-One...
HP f2105 monitor going into sleep mode on it's own
Does it do the same when you use this monitor with other PC, new VGA cable, just need to narrow down the problem first before start taking the monitor apart.
See pictures of what usually goes bad (mostly failed capacitors) with monitors:
http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further
Apr 03, 2010 | HP f2105 21" LCD Monitor
Have a new HP Pavilion entertainment pc with Windows 7.
I also have a HP Pavillion dv9260 , had the same problem, HP help live said the video board, which is an intergral part of the mother board is bad....burnt out...needed to replace the motherboard and they won't stand behind them...I was out of luck $400.00 to repair and stories are that it won't last long even if you do...so here it sit's basically $2400.00 dollars worth of scrap parts........
Dec 27, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
My laptop goes to sleep but will not wake up. I
well maybe the power settings are wrong it happened for a while on my computer until I set custom sleep settings but then again im using a desktop
Nov 23, 2009 | HP Pavilion tx1000z Notebook
How do I wake up the monitor when it goes to sleep when not used for a short time.
slapping it around usually works. "just a joke!"
tapping a few keys on your keyboard and moving the mouse will usually wake the monitor from sleep mode.
Nov 11, 2009 | Office Equipment & Supplies
Laptop will not start
It's possible the video card is burnt out from over heating.If it is you need a new motherboard.
Jun 01, 2009 | HP Compaq Presario F730US Notebook
HP LaserJet P2015 Printer Logo
69 people viewed this question
Seeker5211
Seeker5211
