Question about Emerson InSinkErator 2-1/2 Gallon Point-Of-Use Water Heater...
I am looking for a heater element for an insinkerator w152 do not have a parts break down for part #
2 Suggested Answers
gary1121
  • 332 Answers
SOURCE: How to replace heating element for InSinkErator W154 water heater
take the front cover off, it is just snaped on, there you will see it, depending on the age of the unit insinkerator will replace it for free, you just have to install it, but for the most part it might be cheaper to change the unit
Posted on May 30, 2009
Insinkerator water heater w152 smoke from power switch
Disconnect(turn off the breaker) the electricity from the unit. There is a short that will cause a fire.
Cause of the short will require investigation
Jul 13, 2014 | Rheem 65 GAL ELEC Water Heater 6YR Self...
Water heating not heating water
The Emmerson W152 is ordinary 1-year warranty 120Volt electric storage water heater, except with bronze tank. The bronze tank will not rust, and therefore tank does not have anode rod, and tank has 5 year warranty.
http://waterheatertimer.org/pdf/Emmerson-point-of-use-water-heater.pdf
Actions to take:
1) Check circuit breaker.
2) Emmerson plugs into 120V outlet. See if outlet works for other 120Volt light or can opener.
3) Turn off power and do following:
4) Open cover on water heater, and press in reset button.
If reset will not reset, then replace thermostat with ordinary generic thermostat from hardware store.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
5) If reset button is not tripped, test element.
6) Emmerson has 1500 watt element, and correct ohm reading at 120 volts should be around 9.6ohms
http://waterheatertimer.org/How-to-test-water-heater-element.html
7) This element is 7" long, and is also generic, and should be available at hardware, or plumbing supply, or Google-search 'Emerson appliance water heater element.'
Jul 29, 2012 | Emerson InSinkErator W-152 Point-Of-Use...
The heating unit is tripping the main breaker.What do I do?
Check the current if it is over rating replace it. I am assuming you are talking about a branch circuit. If not run do not walk to the nearest electrician, you have serious problems.
Good luck,
Gil
Feb 24, 2010 | Emerson Insinkerator 2.5 Gallon Water...
Brownish water from insinkerator
sometimes with well supply you are better to have two filters one outside easy access then another as supply enters your property best of luck
Nov 02, 2009 | Emerson InSinkErator - Water Heater - W152...
The water from the instant heater smells bad. I've changed the filter but the odor remains. What is this?
if the water supply from other outlets of the house are fine, the unit itself developed some mold or other contamination from period of non use. it will need to be flushed
Sep 08, 2009 | Emerson Insinkerator 2.5 Gallon Water...
Leak in the bottom of insinkerator 1-81 near reset button there are two little flange looking things one is leaking rapidly when water is on
depending on the age it sounds like you may have to replace the unit,, insinkerator is the best on the market so when they leak it;s time for a new one ,, if not to old and under there warranty they will send some one to ifx it just call the 1-800 number on the unit
Jun 13, 2009 | Emerson Insinkerator 2.5 Gallon Water...
May 12, 2009 | Emerson InSinkErator W154 Water Heater
Can a insinkerator hot1 be hooked into a low
there shouldn't be a proble it actually would work less if you are getting low pressure,, but how did you come to the conclusion that it is low pressure,, do yo have a guage, you should not loose that much pressure on any fixture
Mar 27, 2009 | Emerson Insinkerator 2.5 Gallon Water...
THE INSTA HOT HEATER KEEPS TRIPPING THE BREAKER?
Hire an electrician.  The breaker needs to be replaced or the wiring in your house is not able to handle it.  I believe most need 2-30amp breakers.
Mar 03, 2009 | Emerson Insinkerator 2.5 Gallon Water...
THE INSTA HEATER KEEPS TRIPPING THE BREAKER?
Is this a new install or is this something that has just come up? If it is a new install, the amperage on the breaker is too low. You will have to call an electrician to come in and check to see if the romex wire is large enough to handle a higher amp breaker. If not, it could be that the breaker has become weak and tripps prematurely. If it's not the breaker its self then the heating element is bad on the unit.
Emerson InSinkErator 2-1/2 Gallon Point-Of-Use Water Heater... Logo
93 people viewed this question
Top Emerson Water Heaters Experts
Donni Steen
Gil Shultz
ray gallant
Are you an Emerson Water Heater Expert? Answer questions, earn points and help others
