Question about McCulloch 26cc Gas Blower Mcb3208
How to ajust carb screws, will not start - McCulloch 26cc Gas Blower Mcb3208
    Scholar:
  • 71 Answers
A non-starting situation would rarely be any of the screws (or jets). Look more closely to:
1. Fuel line's broken or badly deteriorated (even within the fuel tank)
2. Spark plug fouled,
3. Muffler clogged with insect homes or carbon build up,
4. Gasoline that is older than 6 months,
5. Carburetor diaphragms, gasket and needle
Visually check #1, 2 and 3 above, first.
Change fuel and retry.
If still no start: Insure you are getting a spark at the spark plug by grounding it the best you can to a metal surface and pulling over in a dim light. If spark, repost you issue indicating what you have done to date.
Posted on Sep 28, 2010
2 Suggested Answers
  • 56 Answers
SOURCE: ryobi bc30 idle and run probloms
mmarote, this is what I did to solve that problem....remove carb...take a hacksaw or dremel tool and cut or grind slots straight across the centers of both screws deep enough to get a thin bladed screwdriver in the slots....turn to adjust....et voila....
Posted on Jul 03, 2010
I have stihl ms 170, which it takes about 12 pulls or more to start, obviously is a common problem thier with this model, some think caused by thier zama carb, which can't be adjusted, only has one screw...
Fixed jet carbs are always a problem due to tollerences within the engine, fuel types and carb wear, which you cannot make a small ajustment to the carb to compensate for, you need to check the cylinder and piston are in good condition and has ample compression, if ok you may need to change the carb.
Aug 15, 2013 | Garden
My cr125 wont idel after stating can it be ajusted.
there is a little screw at the back of your carb next to your air box. kick your bike over and keep little revs on screw it clockwise (in) then start so slowly screw it anticlockwise (out) till your bike starts to rev a bit mor then release your throttle and it should tik over.
Aug 07, 2012 | 2003 Honda CR 125 R
Carb ajustment
Only Info I see is "Homelite Chain Saws" - not much to go on.
Most saws have two carb adjustment screws, Hi, and Lo.
Assuming the saw will start and run enough to warm up, then
adjust the Lo screw in, clockwise, until the motor starts to slow down,
turn only about 1/8 turn at a time. From the point where it starts to slow down, turn it out about 1/4 turn. This should give you a decent idle. Now pull the throttle, and see what happens.
A - Saw runs up to speed, but dies off, or starts to slow on it's own.
turn Hi idle screw out about 1/4 turn.
B - Saw speeds up, but runs sluggish, fat - not real hi end.
Turn Hi screw IN, about 1/8 or so, and try again, or adjust
while running at full throttle. (best way)
IF it won't run well, try turning both screws all the way in to seat them, then come back out about 1-1/2 to 2 turns. this should get you in the ballpark to set things up as above.
Once the saw is running well, adjust the idle screw to a smooth idle but slow enough that the chain stops moving.
Stay safe
Jul 01, 2012 | Homelite Garden
Diagram of carb to ajust the screws to make mortor work right
!. or
2.
Are where you might find details since you have not mentione make/model of your motor.
May 10, 2012 | Motorcycles
I just put on a new rebuilt carburator on my 460 v8 1987 xlt 250 ford truck 4 WH. drive. its a motorcraft stock holley. I cant seem to find a way to ajust it. Wont run smooth or idle? It was set up for...
You have two setting screws on front of carb, You start off by adjusting all the way to the left, Then back off 3/4 turn to both setting screws, Then you have to set your air fuel mixture by just slowly turn your setting clock wise do so until vibration go away. Sorry there is no easy way to explain, Good luck to you,
Apr 03, 2011 | Ford F-250 Cars & Trucks
Fuel ajustments on carberetter
to ajust your fuel inlet their is a screw on the side of the carb when you screw it in your leaning it out and out will richen it but you need to find the right ajustment because if to lean it out to much you will burn the piston but to rich will foul the plug
Feb 24, 2011 | Garden
Ryobi bc30 idle and run probloms; plastic ends on ajustment screws on carb keep you from ajusting carb. how can you ajust. can start with chock but will not run with chock off.
Jun 25, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Have a poulan chainsaw that won't idle/stay running and bogs down when you press the trigger control. Do you need a certain wrench to adjust carb??
no carb ajustment is done with a flat head screwdriver, first i would remove the card, disassemble it and blast it with compressed air because its probably just clogged up with varnish. to ajust the high low and idle screws bottom both out ( turn in all the way) then unscrew each one turn. from there start the saw and loosen in 1/4 turn at a time until it runs well
Apr 25, 2010 | Poulan Pro Chain Saw 46cc 20"
Can't keep my snow blower running under load, cleaned carb, but do not know adjustment procedure for a tecumseh 7.5 hp 15 year old snow blower
there should be an ajustment screw on the carb. turn it all the way in don't turn it hard then turn the screw back out 1 1/2 turn to start out with then after runing turn till it runs evenly.
Dec 20, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
McCulloch 26cc Gas Blower Mcb3208 Logo
246 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
