Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune electric dryer
How do you lift the top to replace the baffel
  • 525 Answers
Warning! Disconnect power before servicing!
1.Open the door and remove the screws holding the door, then pull outward on the door to disengage the hinges.
2, Remove the screws on the opposite side of the door opening.
3. Pull outward on the lower part of the front panel to disengage from the top.
4. Remove the screw from the top left and right corner top retainer bracket.
5. Rotate the retainer brackets toward each other to disengage the top from the side panels.
6. Lift top.
Posted on Jun 03, 2008
NEED TO TAKE TOP OFF OF NEPTUNE DRIER MDE6800AYE BUT CAN NOT LOCATE SCREWS TO LIFT TOP OFF
there are no screws.the lid needs to be lifted by placeing a flat tip screw driver and push the clips in on the front they are located about one inch in from either side of the dryer push them in and the lid will pop up
Sep 12, 2010 | Maytag Neptune MDE6800 Electric Dryer
Model #MDE8057AYW I need to know how to get the lid off so I can see if I need a new belt
1.Unplug the electrical cord of the Maytag electric dryer from the electrical outlet.
2.Open the dryer door and locate the four screws on the inside,unfastening the screws with a screwdriver.
3.Pull on the corners of the top front panel,rolling the corners forward to release the clips.
4.Tip the front panel straight out and slide it up until the panel comes loose of the clips.
5.Set the front panel aside and slide the top of the dryer forward.
6.Lift the top of the Maytag electric dryer up,tilting it back and resting it against the wall.
Aug 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Apr 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
How do you remove the top off of a maytag neptune dryer 5500 series?
Take off the 4 phillips head screws around the door. the 2 sides will fold out, pull and the bottom panel will follow. after you have removed the panel you will have access to the frame. you will need to remove the top 2 5/16th screws. you will then lift the top panel and have a access to the top of the drum.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The fin on the Neptune Dryer has come loose and I need to remove the side panel on the dryer to replace the two screws that hold one of the three fins in place. It would be simple if I knew exactly how to...
Remove the 2 screws holding the door and the 2 screws on the other side of the door opening . Pull the front panel foreward and lift off . If still not enough room to reach under to tighten , remove the 2 screws (1 on each side , holding the top down , then lift top . DISCONNECT POWER BEFORE DOING ANY WORK .
Aug 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
One of the baffles broke off the tumbler and need to replace it
correct no repair guy neede unplug the unit so you dont get electrocuted happen to me once dont let it happen to you. remove the front panel than undo two screws at top of cabinet to release the top rotate the drum so the baffel you are replacing is at the 12 oclock position insert the baffel rub the screws thru the factory holes at top of unit if the holes are stripped dont be afraid to throw a washer in with the screw and dont over tighten because they will stripp out the plastic baffel . reasemble and your done takes about ten minutes
Aug 13, 2009 | Maytag HYE3658AY Electric Dryer
Maytag neptune MPG5500AWW loose baffles but can't figure out how to lift top or front
Press a putty knife in at the top front corners. That will release the spring catches.
May 04, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Can't figure out how to get the top off
http://www.pcappliancerepair.com/model-display.php This one looks like a real puzzle. Open the door and look for screws holding the front on, the top seems to lift up once something is released.
Apr 26, 2009 | Maytag Neptune MDE4000 Electric Dryer
My neptune dryer sounds like screws are tumbling, one of the 3 dividers connected to the drum inside the dryer is loose and it is leaving black marks on clothes
Hello
Welcome to Fixya
My name is Huum,
You said, my Neptune dryer sounds like screws are tumbling, one of the 3 dividers connected to the drum inside the dryer is loose and it is leaving black marks on clothes
Those are the screws that hold the dividers to the drum.
The drum ha to come off to replace them. Big job!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Top Panel
there are 2 philips screws on the front panel 3" up from the bottomm remove screws and pull front panel from bottom then replace baffle scewes from the bottom
Sep 03, 2008 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
154 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
