Question about Intel Motherboard
Lan connector LAN wont work on ms-7060 motherboard sis 661fm2, it just quit working.
    Scholar:
  • 187 Answers
Have you checked the drivers? (e.g. uninstall then re-install) Does the Device Manager tell you whether or not there is a problem? (yellow apostrophe or red X) And the router you are connecting to? (assuming it is not giving an IP?)
Posted on May 25, 2008
I WANT FULL INFORMATION 15 K86 011000 671T MV.1.0 MOTHERBOARD?
CPU ? LGA775 socket for latest Intel Core 2 Duo / Pentium D / Pentium 4 / Celeron D processor
? Supports Hyper-Threading Technology CPU
CHIPSET ? SiS® 671 & 968
? North Bridge: SiS® 671
? South Bridge: SiS® 968
GRAPHICS ? SiS Mirage 3 graphic engine
? Share Memory: Maximum up to 256MB
MEMORY ? Single-channel DDR2 memory architecture
? 2 x 240-pin DDR2 DIMM socket support up to 4 GB
? Support DDR2 667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS.
For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
EXPANSION SLOT ? 1 x PCI Express x16 slot
? 1 x PCI Express x1 slot
? 2 x PCI slots
STORAGE ? Support by SiS 968
• 2 x Ultra DMA133/100/66 devices
• 2 x Serial ATA 3.0Gb/s devices
• RAID0 & RAID1 configuration
AUDIO ? Realtek ALC660 6-channel audio
? Compliant with HD audio specification
LAN ? Broadcom AC131 10/100 Lan Phy
REAR PANEL I/O ? 1 x PS/2 keyboard & PS/2 mouse connectors
? 4 x USB ports
? 1 x VGA port
? 1 x Serial port (COM1)
? 1 x RJ45 LAN connector
? 1 x Audio port
INTERNAL I/O CONNECTORS & HEADERS ? 1 x 24-pin ATX Power Supply connector
? 1 x 4-pin ATX 12V connector
? 1 x IDE connector
? 1 x FDD connector
? 2 x USB 2.0 headers support additional 4 USB 2.0 Ports
? 2 x Serial ATA connectors
? 1 x CD in header
? 1 x Front panel audio header
? 1 x Front panel switch/LED header
? 1 x SPDIF out header
? CPUFAN/SYSFAN connectors
SYSTEM BIOS ? AMI BIOS with 4Mb Flash ROM
? Supports Plug and Play 1.0B, APM 1.2, Multi Boot, DMI
? Supports ACPI revision 1.0 specification
FORM FACTOR ? Micro-ATX Size, 244mm*220mm
Dec 21, 2014 | Computers & Internet
MSI MS-7060 ver 1 bios update
As old as this mainboard is, there would seem to be very little to be gained with a BIOS update. It will not provide any appreciable ability to upgrade components, and if you have used this board for any length of time successfully, updating the BIOS is questionable. Many people think that BIOS upgrades will solve all problems with the board....in most cases it only serves to fix bugs in the current BIOS, allow for a few later-models of the CPUs that are already approved for use, and upgrade firmware for the on-board amenities. Realistically, the only time a mainboard BIOS update is warranted is at purchase if there is reason to install the update to provide better performance. The risks of BIOS upgrade often outweigh the benefits; many of us are steadfast in the belief that "if it ain't broke, don't fix it".
Jul 12, 2014 | MSI Ms-7060 661fm2-v-lsr Socket 478...
Hi, Please can somebody help me ? I need drivers for motherboard Socket 478 Micro Star MS7060 V 1.2, Much grateful...
When I go to MSI support, and put in MS-7060, I get the
MSI 661FM2 V LSR/ILSR,
http://us.msi.com/service/search/?kw=ms-7060&type=product
Click on the blue - Download
Takes you to here,
http://us.msi.com/product/mb/661FM2-V-LSR---ILSR.html#/?div=BIOS
Hover your mouse cursor on the Download tab.
(Overview / Specification / Download / Support / etc)
In the drop down lost click on - Driver
In the OS: box it automatically has Vista listed.
Click on the blue Down Arrow to the right side of the OS box; then click on the Operating System you are using.
I'm going to choose WinXP 32-bit as an example.
(XP 32)
Drivers that are listed with a .zip on the end.
These are ZIP files. A ZIP file is a compressed file. It is used to send large amounts of information more easily.
The file after downloading has to be 'unzipped', or also stated as uncompressed.
Let's use the VGA driver file for an example;
SiS 650/650GL/651/661FX/740/761GX/67x VGA Drivers
To the right of the subheading Download, click on the blue -
sis_vga_xp_mb.zip
On the next page click on the country name nearest yours.
A small window will come up -
Opening sis_vga_xp_mb.zip
Make SURE there is a Green dot in the small circle, to the left of - Save File.
If not; left-click in the small empty circle to the left of - Save File
Now go below in the window, and click on OK.
A small download window will come up.
Allow the file to FULLY download, then DOUBLE-click right on the file name.
In the next window go to the far left, and click on -
Extract all files.
At the bottom of the next 3 small windows click on Next, Next, and Finish.
Restart your computer if not asked to do so.
(Close all windows, go back to your desktop screen.
Start > Turn Off Computer > Restart, for WinXP)
With a driver file ending in .exe it's different.
(Execute)
After you DOUBLE-click on the file name, just click on Next, Next, and Finish, at the bottom of the 3 small windows.
For additional questions please post in a Comment.
Regards,
joecoolvette
(Looking at the driver files you can see the Micro Star International 661FM-LSA/ILSA, is also the MSI MS-7060 )
Jan 14, 2013 | MSI 661FM-L, 601-6540G-010, Microstar P4...
How to reset bios password?
remove the cmos battery for 24 hrs. then put back
Dec 16, 2012 | MSI Ms-7060 661fm2-v-lsr Socket 478...
Lan card problem
what problem you have faced with LAN. if your LAN not work then install a new one, or if slow then try update the latest driver. if any thing else please provide details.
Jul 30, 2011 | MSI MS-6580 Motherboard
Sounds and lan
go to
http://support.asus.com/download/download.aspx?SLanguage=en-us
select motherboard
select socket 478
select p4s333-m
click search
select your os and then select to download the sound and lan drivers
Sep 24, 2010 | ASUS SiS Chipset P4S333-M...
Pci simple communications controller could not find a driver so there's no internet, board is an Asus p5smxse with 2 chipsets, one on the north and the other on the south. sis 968 and sis 671fx
Enter your bios and make sure you're lan is [Enabled].
Open the link provided below;
http://www.asus.com/product.aspx?P_ID=fLSzpcTDJYT0rgS6&content=download
Choose you're operating system from the drop down menu.
There is one LAN driver, Sis Driver V2.0.1039.1070 for Windows 2000/XP/2003/XP 64bit/2003 64bit. Create a folder on your desktop and name it LAN. Download the LAN driver into the LAN folder. Uncompress the zip file, keep the uncompressed file within the LAN folder. Open windows device manager. Find the pci simple communications controller. Right click on it once. From the pop-up menu left click, update driver. Follow windows instructions. Find the Lan folder on you're desktop and open it. Left click once on the newely created Lan folder so it is high lighted. Click OK. Windows will find the correct software and install it for you. When finished restart you're system. Check windows update for hardware and software updates after windows restarts.
More often than not (pci simple communications controller) points to an audio driver missing but LAN controllers are included.
Cheers!
Mike
Jan 09, 2010 | ASUS Computers & Internet
Ineed cd support for MSI 661FM2-V (MS-7060)motherbord, because i lost the original and now i want to install xp sp2 on sata HDD
you can get manual, driver, bios for your motherbord at the MSI mainboard website http://global.msi.eu/index.php?func=proddesc&maincat_no=1&prod_no=158
choose XP driver
Succes with installation
I hope this information is helpfull
Aug 29, 2009 | MSI 661FM2-LSR (7060020R) Motherboard
Drive SATA 3.0 Gb not detected by msi 7060
3GB Sata driver? i dident know there existed so smal drivers
Anyway, if your bios dosent detect the driver u probably need to update the bios drivers.
Go to MSI site:
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=158
Instal LIVE UPDATE and let msi check you computer for laterst drivers u need to instal
Nov 20, 2008 | MSI 661FM2-LSR Motherboard
Intel Motherboard Logo
299 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
