Question about OKI C5800dn Laser Printer
Fatal Error Code 928 - OKI C5800dn Laser Printer
2 Suggested Answers
copiersplusw
  • 136 Answers
SOURCE: fatal error 928 Oki C5500
Open the Unit Up, the Button on the Side opens the Printer. In the rear of the Printer you will notice the Element in the rear of the Printer.
It is usually hot. Well there is latches
as an Authorized Okidata Service Provider I believe these "TABS" should be the color of BLUE. release the tabs and the entire fuser come out just grab the handle that usually comes equipped with the fuser , it is usuallyon top just grap ir and lift it out. Install the New One and your Done.
Posted on Sep 13, 2009
OKI C711 928:fatal error
Just to confirm that Jeff Hughes is correct. 928 does refer to paper wrapped around the fuser rollers making the thermistor see nothing hence the 928. If there is no paper in the fuser then it will need to be replaced. Remember to turn the machine off when removing or replacing the fuser.
Nov 09, 2016 | OKI Office Equipment & Supplies
Is showing sc code 928
Search online for "error code (sc) 928 + your make & model"
Sep 04, 2015 | Office Equipment & Supplies
Error fatal 928 how to fixe it
Error 928: Fuser Motor Lock Error An error was detected with Fuser Motor rotation by overload. If rebooting the machine does not improve the symptom, you need to check the Fuser Unit.
Sep 09, 2014 | Oki Data Americas, Inc. OKI C 711n -...
928 fatal error
Thons is an issue with your computer (Windows right?)Try To do a registry cleaning with a free registry cleaner.
Aug 15, 2014 | Oki Electric Industry Okidata MC860 MFP...
928 FATAL ERROR
Fuser Motor Lock Error The fuser is not operating properly
Check to confirm that the fuser
is in position.
Replace the fuser.
Replace the fuser motor.
Jun 06, 2014 | OKI C5100n Laser Printer
Oki printer MC860 is displaying fatal error 928. What does this mean
This is a fuser motor lock error. Check that the fuser is installed normally. You may need to replace the fuser unit or the fuser
motor.
Dec 03, 2013 | Oki Electric Industry MC860 AllInOne Led...
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
Printer OKI C5650: "POWER OFF/ON 928:FATAL ERROR"
TRY REMOVING ALL CONNECTIONS & THEN RESTART.REMOVE CATRIDGE AND RECONNECT
Sep 24, 2010 | Office Equipment & Supplies
The printer is on and when I send documents to
Error 928 is generated by the "Engine" board that controls all of the motors, clutches and sensors in the printer. It indicates a Fuser lock motor error usually caused by the Fuser or Fuser motor not rotating. First step is to remove and inspect the fuser. This is at the rear of the printer, has a blue lock lever on both sides and lifts out. Any damage to the rollers can cause it to jam or if there is a sheet of paper wrapped around a roller. be careful when removing a fuser as these can be extremely hot, follow the instructions in the documentation that came with your printer to remove the Fuser.
Nov 01, 2009 | OKI C5500n Printer
'928 Fatal Error message' on OKI C5550MFP
928 - fuser motor lock error
take out fuser and check for paper stuck on roller
make sure roller can move
if roller is stuck or damaged, repalce fuser unit
Apr 11, 2009 | OKI C5550N Multifunction Printer - Color...
OKI C5800dn Laser Printer Logo
309 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
