Question about Kuppersbusch EEB65000MX Electric Single Oven
The oven wont heat up and i beleive there are two fans but the one at th back wont heat up
  • Kuppersbusch Master
  • 3,463 Answers
If the fan is working o/k then thit is usually the oven element that is faulty.
Located at rear of oven compartment behind a removeable cover.
Posted on Sep 28, 2010
Oven Wont Heat up
have an electrician check the oven element as it may be burnt out
Mar 07, 2016 | Ovens
I have a GE microwave/convection oven that the lower oven wont heat, fan comes on top microwave works but the oven wont heat
First reset your breaker, then check your wiring in the back of the oven. You may have just a wire loose.
Feb 24, 2013 | GE Profile JT965 Electric Double Oven
My candy oven r43/3xuk wont switch on. The power
If the fan is working o/k then it is likely to be a faulty oven element if it is a
electrically heated oven.
If it were the timer, not even the fan would work.
Mar 28, 2010 | Ovens
The oven wont turn on,fan works but heat wont come on
Most likely you have a faulty fan element- this is a round element that goes around the fan at the back. To check- Disconnect from power(easiest way is to switch off oven at fuse board). Remove rear panel inside oven (held on by screws), and visually check element- often you will see a blow mark on the element. Element is easily changed, although sometimes requires oven to be removed to access element wires from the back. Proceed if you are a confident DIYer, otherwise call a local service agent. Elements are readily available for $75-$125 depending on the retailer. Can give further advice if you provide a model number. Good luck!!
Mar 10, 2010 | Fisher and Paykel Ovens
Indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Oct 23, 2009 | Ovens
Oven problem- grill works but the fan assist wont heat up
possibility is that the wire that link the oven element and that of grill is loose or burnt
Sep 25, 2009 | Ovens
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Apr 05, 2009 | Belling XOU252 Electric Single Oven
Whirlpool oven
There is a fan in the oven, it is behind a panel at the rear.It will be a loose fan or worn bearings, or fan catching grill
Nov 09, 2008 | Whirlpool RBS275PD Electric Single Oven
Fan assist wont heat oven
the ring element may have blown. if it works ok with the top and bottom elements, (the convection oven) then it is likely the element surrounding the oven fan.
Jun 25, 2007 | Baumatic B187 Stainless Steel Electric...
Kuppersbusch EEB65000MX Electric Single Oven Logo
258 people viewed this question
Top Kuppersbusch Ovens Experts
ashburton
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you a Kuppersbusch Oven Expert? Answer questions, earn points and help others
