Question about Brother IntelliFax-2820 Laser Fax
HOW LONG SHOULD A DRUM LAST - Brother IntelliFax-2820 Laser Fax
    Problem Solver:
  • 17 Answers
At least 5000 to 20000 copies for smaller machines
Posted on Sep 30, 2010
Model 600. Why is it dropping toner near transfer corona unit?
When is the last time the developer and drum where replaced? When the last time was a PM done? Very 250,000 copies a PM must be done? Which replaces the Corona Wires, Developer, Drum, Corona Grid, Web roller for fuser (Hot Part). Also during the PM the Tech should clean the toner out of the Waste Toner collection unit on the image unit. also clean the area around the drum and developer roller.
Oct 28, 2015 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub 3010 cof 32
When was the last time the developer and drum where replaced? Does the machine say "REPLACE DRUM in the upper left corner of the operation screen? More then likely your drum and developer need to be replace if not those then the DEVELOPER CARTRIDGE NEED TO BE REPLACE when was the last time that was replaced? Every four drums the developer cartridge needs to be replaced. When the developer was replace was a F8 run from service mode?
May 16, 2014 | Minolta Office Equipment & Supplies
C 2811 biz 951
drum or drum sensor/board or control board, last time drum area was cleaned and sensor was cleaned? Clean all area around drum
Apr 26, 2014 | Konica Minolta Office Equipment & Supplies
Why does the drum need changing
The drum is where the images are created, a good drum means good printing quality, is sensitive to light, do not expose to sunlight directly and also expose to the light as less as you can. Other Brands of printers has the drum in the cartridges, every time that you replace the cartridge actually you are replacing the drum, but usually the drum last longer than the toner, Brother allows user to change drum when its need it, for example this drum last about 17,000 pages if you are not concern about quality you can reset the drum and keep using until the quality is not enough for you.
Aug 31, 2013 | Brother HL-4070CDW Printer
MY HP LaserJet 2840 has a brand new Toner cartridge. Now it won't print at all and we are getting a "OPC at end of life" prompt. What does this mean?
Imaging drum reach 20,000 (black only) or 5,000 (color), replace the image drum.
Supplies life
The life of the imaging drum depends on the number of black-only or color pages that print jobs
require. Imaging-drum life is also affected each time the device calibrates because calibrating causes the imaging drum to rotate. Imaging-drum life is measured in terms of number of rotations rather than number of pages printed.
The type and length of print jobs also affects drum life. A series of short print jobs uses more drum
life than an equivalent number of pages printed in a single large job. To extend drum life, print
multiple copies of a print job at one time rather than sending the same job to the device multiple times.
The life of a print cartridge depends on the amount of toner that print jobs require. When printing text at 5% coverage, black print cartridges last an average of 5,000 pages and cyan, magenta, and
yellow print cartridges last an average of 2,000 pages. High-capacity cyan, magenta, and yellow print cartridges last an average of 4,000 pages. (A typical business letter has 5% coverage.)
Aug 18, 2011 | HP LaserJet 2840 Printer
JUST REPLACED THE DRUM IN NOV, 2010 AND THE LIGHT IS ON AGAIN. HOW LONG SHOULD THE DRUM LAST
I don't think you need another drum. The drum should last a long time. Sounds more like you have a short in the light switch.
This sounds like some cars that the check engine light always goes on for no reason.
Jan 24, 2011 | Brother HL 5250DN Laser Printer
I get vertical lines in the center of the paper when making copies
Most likely the drum unit. You can run a test for this by making 10 copies of something. Then compare the last copy out with the first copy out. If the lines down the center are worse/much worse on the last copy than they are on the first copy then the problem is 99% sure to be the drum unit. Now if the the drum is in good enough shape you can save a bunch of money by having the drum unit cleaned and a new drum cleaning blade installed. This is the case in most instances. Sometimes you may have to replace the drum unit as a whole.
Drum cleaning blades are $25 or less. The whole unit is in the hundreds of dollars.
Good Luck and Thank You for using Fixya.
Mar 16, 2010 | Canon NP 6050 Copier
Heating works but drum doesnt turn.
Try turning drum, or remove top from dryer to confirm if belt has gone. When turning drum there should be some resistance as the belt fits around the drum
Feb 18, 2010 | Whirlpool LER4634J Electric Dryer
How could improve the laser printers (hp1020)drum's life ?
Generally speaking the lower coverage you print the longer the drum will last because it is not discharging and charging the entire thing the all of the time.
However, this gain may be negligible because it also depends on the quality of paper used and the drum type. For instance OPC drums last a short time compared to a-Si drums. So there are small things you can do but if you can't change what you run you are about stuck with that drum life.
Keep in mind that some sites may tout that their drums last longer but always take non OEM specs with a grain of salt.
Apr 05, 2009 | OKI C5100n Laser Printer
Print quality
Ghosting can :
1-prints on the fuser roller, check if yes try cleaning it off, wait until it cools off
2-blanking lamps dirty or not working,(deletes image off the drum, before it gets ready to accept a new one)
BL mirror-(new image)
drum
3-Bad drum (although I doubt it this far in the process.)
Sep 05, 2008 | Ricoh Aficio 1013F Copier
Brother IntelliFax-2820 Laser Fax Logo
296 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
