Question about Creative Labs GigaWorks S700 Computer Speakers
Creative GigaWorks S700 system purchased new and installed on a computer system about 4 or 5 years ago. The BEST audio system I've ever had! The S700 system was transferred to a new computer about 14 months ago and it again worked as designed without any problems. Recently the audio would not come on after the morning "boot" but eventully the audio turn on, without intervention, in an hour or two. Troubleshooting: 1. Determined the computer audio output (green coded) worked. (DISCONNECTED the S700 system and DIRECTLY WIRED the audio output to the computer's monitor speakers) . 2. Found the Creative 'Audio Control Pod' Power Indicator light OUT but noted that it would return ON without intervention after a period of 2 or 3 hours . The Creative System would then work as designed and fail at the next reboot. 3. Disconnected, repositioned and reconnected all S700 cables to the computer. 4. Turned the S700 Subwoofer panel power "ON" and noticed the green "Power" panel indicator light "Flashing." The Audio Control Pod Power indicator remained "Off."
  • 99 Answers
SOURCE: Gigaworks S750
If you check the Creative forums there is a thread there where a few people have started to fix problems like this permanently and they have helped quite a few people fix their problems. I would only suggest checking it out if you have any electronics experience (soldering, and basic troubleshooting minimum). Otherwise I would send it back but keep in mind that this is one of a few common problems with the S750's and you are likely to have other problems in the future unless you take measures to fix the problem that creative has not.
I would also like to point out that your problem would be a short on one of the amp boards after the power regulators, very likely one of the STA575 amplifier ICs. Those are not easy to find but it is possible to find replacements.
Posted on Dec 16, 2007
SOURCE: Audio control pod
I have a similar issue too, but my problem is that the sub has green light, and my control pod has an 'off' light, but it won't turn on :(
Posted on Jan 25, 2010
SOURCE: I have a Creative Gigaworks S700 (subwoofer) with
first fuse as standard is in the plug to the power adapter. The second fuse is located at the back of the box where the power lead goes into. It is covered so look closely you just need something flat to open it. I have the S750 and that is what im basing this on but if the s700 is the same then you will find this helpful. Sorry did not notice this before.
Hope this helps.
Posted on Mar 01, 2010
SOURCE: I have a Gigaworks 750,
I did fix this problem and the whole bunch of other ones with the s750 system.
"light is flickering" is a very common! It shows that there is a problem with STANDBY power supply:
1) Yellow glue became conductive (needs to be completely removed)
2) Capacitor malfunctioning C61 (68uF 450)
3) mine had TH1 cracked (replaced from PC power supply) and D9 diode.
If this successfully fixed, you will be able to get 2nd stage power supply on (Relay or power on button)
If you will have problems there, there is a whole bunch of test needs to be done (capacitors, IRF740 etc.)
Posted on Sep 24, 2010
  • 159 Answers
SOURCE: i need to connect a
I wasn't sure if you were looking for the manual (connection instructions). If so, here's the manual:
http://ccftp.creative.com/manualdn/Manuals/TSD/7676/Creative%20GigaWorks%20S750%20Users%20Guide%20English.pdf
It's possible that your computer doesn't have the proper connections to connect these speakers. If that's the case you will need to upgrade your sound card.
I hope this helps and I which you the best of luck!!
Posted on Mar 01, 2011
Crackling from Creative Tech Gigaworks T40 2 speakers
I do also get this same issue, They were working just fine, and 4 or 5 months ago, the right speaker crackles, if i unplug the right speaker all is fine. But as soon as I plug the right speaker in, i get a cracking sound. Have you solved this ussue?
Oct 28, 2012 | Creative Technology Gigaworks T40 2...
I have a Creative Gigaworks S700 i have checked both fuses still no power to control box
Stupid question: does the sound still work? it could be the LED just died after continual use (rare, since they last a long time, but not uncommon).
If not... it could be the controlling circuit board died. In which case, unless you have electronics repair experience, it would be probably more worthwhile to just replace the speakers, as pricey a model as it is.
Mar 23, 2012 | Creative Labs Gigaworks S750 Computer...
I need to connect a gigaworks s700 to my computer but i dont know how to.
Mar 01, 2011 | Creative Labs GigaWorks S700 Computer...
I have a Creative Gigaworks S700 (subwoofer) with no power out. LED off. Fuse ok.
Hope this helps.
Dec 11, 2009 | Creative Labs Gigaworks S750 Computer...
Creative labs gigaworks g500
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&Item=270456737725&Category=3702&_trkparms=algo%3DLVI%26its%3DI%26otn%3D1
Jun 21, 2009 | Creative Labs GigaWorks ProGamer G500...
Left front speaker works the rest dont and the sub makes a hum
Either you have it configured incorrectly this time around, or the settings are defaulted back to original on your DVR........ adjust your DVR sound properties/settings. and check all wires/connections as well.
Apr 20, 2009 | Creative Labs Gigaworks S750 Computer...
Gigaworks s750
Same problem just went out after about 4 years.... weak lifespan for a 500 dollar system
Feb 12, 2008 | Creative Labs Gigaworks S750 Computer...
Connecting Creative Labs Gigaworks S750 to Onkyo SR605 A/V Receiver
take those speakers to an electric shop and ask him for some special sockets.....
Jan 08, 2008 | Creative Labs Gigaworks S750 Computer...
Creative Labs GigaWorks S700 Computer Speakers Logo
113 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
