I have a Dimplex DWH2010TA which I bought at Home Depot several years ago. I am only now installing it and I have lost the instruction manual. This covers carpentry work and electrical installation. I cannot find this model listed on the website. It is an "in wall" mount 1k/2k heater. I hope you can find the manual for me. Many thatnks. James Butler
aborcass
  • 2651 Answers
SOURCE: Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Posted on Apr 03, 2008
Agent Don
  • 310 Answers
SOURCE: Through the wall vs. window installation
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Posted on Apr 15, 2008
Coldcut
  • 1554 Answers
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Posted on Jun 13, 2008
SOURCE: Instruction Manual
I had the same problem. If you are in Australia, the Dimplex Customer Service number is 1300 6739 033. I phoned and they are mailing me the instructions. Maybe don't say you bought the machine at a garage sale.
If you are not in Australia, try the way I did to get your local customer service number - Google the product number and go to the Dimplex website, and there should be a "Contact Us' button with a phone number or mailing address.
Pat
Posted on Jun 23, 2008
mohammed387
  • 1952 Answers
SOURCE: I need to install my Dimplex baseboard heater
homeappliance.manualsonline.com/ex/thread/view/idThread/1430162 - 30k -
Posted on Jan 10, 2009
I purchased a hot water heater about two years ago from home depot and lost the reciept. I need to track the purchase by the serial number can that be done
1) Look for brand name of your heater on following .pdf file:
http://waterheatertimer.org/pdf/Find-Age-of-water-heater.pdf
2) Home Depot sells GE heaters made by Rheem.
I am assuming that serial number starts with 1209, and that year of manufacture is 09 for 2009.
3) These water heaters have glass vial that breaks when combustion chamber experiences overheating due to dirty combustion parts, clogged air intake, exposure to flammable vapor.
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
4) Water heater warranties are usually first-year: full parts, labor and tank. After first year: parts and tank but no labor.
Warranty may be pro-rated and the value diminishes as water heater ages.
http://waterheatertimer.org/How-to-maintain-water-heater.html
5) Warranty may not apply is customer has not followed installation and maintenance as shown in product manual, such as checking anode rod, and yearly service by trained technician.
Dec 06, 2012 | Water Heaters
Hi I have just bought a Dimplex Electric Eco Oil-Free Heater, it didnt come with instructions on how to use the time and Im bewildered, Any instruction would be greatley appreciated
Karin, here is a link to the Owner's Manual for your new heater. You can download & print it for future reference. Also, if you haven't already done so, register the 5 -year Warranty, so that it will remain in effect.
Owners Manual Link:
http://www.dimplex.co.uk/assets/kb/operating_instructions/0/Cadiz_Eco_Instructions_Issue_0.pdf
I hope this helped you. Please let me know. Thanks.
Jun 16, 2011 | Heating & Cooling
My 600 watt 12 volt transformer timer for out door lighting does not keep time properly. HOw do I get and install a new timer?
1) Amazon sells 600Watt power pack:
http://www.amazon.com/Malibu-8100-9600-01-Voltage-Power-Transformer/sim/B002ZRPM4A/2
2) I bought new 300Watt Malibu power pack at Home Depot about 2 months ago.
Near the lighting section.
My new power pack has electronic time clock, so no more 'slow clock.'
I think Home Depot had 600Watt.
Lowes carries different brand.
3) Manuals for power packs at Malibu lights.com
http://www.malibulights.com/customer_service/owners_manuals.aspx
4) Tips for buying and taking care of power pack:
-Match up wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
-Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
-Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
-When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
5) How to install power pack.
Before unplugging old power pack, check which bulbs are not working.
Replace bulbs using phillips screwdriver.
Unplug power pack.
Notice how wires are connected to power pack, write down terminal connections.
Some power packs have three terminals ... extra terminal is for additional photoelectric eye.
Use pliers or screwdriver to disconnect wires.
New power pack has has same terminals.
Plug in power pack.
Read instruction manual before connecting wires.
Save instruction manual because a few years that manual won't be around as products change.
Dec 03, 2010 | Malibu Intermatic Inc. ML121RT Low...
We bought a new ryobi from home depot 5/23/10 with a 1 year warenty now the thing will not start my husband changed the spark plugs still nothing the fule bulb will fill still nothing starter fluid still...
If you have followed all of the instructions in the owner's manual for starting, then take the saw back to Home Depot for warranty exchange or service. Good luck!
Aug 07, 2010 | Ryobi Garden
Instructions guide
http://www.hasbro.com/common/instruct/GuessWho.PDF go to the link I supplied and it will give you the manual. You can print the manual off.
Thank you
Apr 26, 2010 | Toys
Is third time a charm. Again several years ago I
Here is the owner's manual for your DVD machine. This is a VHS recorder but not a DVD recorder. To record VHS tapes to DVDs, you will need a DVD recorder.
You will plug the yellow video out connector on the VHS to the yellow 'Video in' connector on the DVD Recorder. Do the same for the red and white audio connections, out on the VHS, IN on the DVD Recorder. Connect your TV to the DVD recorder so you can see the picture you are recording.
Mar 31, 2010 | Televison & Video
Please help me to get the manual. dimplex thermostat, or i need help to stall my thremostat
Dimplex products are typically sold at most Home Depot and professional electrical supply houses. However, they rarely will have all the literature for those products in their stores.
Dimplex once provided an online list for all their heaters and thermostats, but no longer have the product manuals available on their website for customer download. They make both 120V-AC and 240V-AC versions and several different models, so I can't safely provide you with the wiring connections, since each installation is different and depends on the type of thermostat and heater(s) being utilized.
So now that I've given you the bad news, let's move onto the good news!Dimplex now uses an online request form for customers to get manual and literature on all their products. They'll send you the manual for your Dimplex product free, once you submint the request.
Here's the link to the request form for you to fill out and submit, just have your model number handy and you should be all set.
http://www1.dimplex.com/customersupport.aspx
Hope you find this Very Helpful and best regards!
Sep 18, 2009 | Dimplex Heating & Cooling
We bought the weisser lock several years ago and never did set the combination and use the keypad. We have lost the instructions how to even set it up for the first time.
Here's a free manual you can print out with complete installation and programming instructions you can keep for addressing any other concerns you might have in the future.
I thought this might be easier for you to work from, since you might have to reset the lock prior to entering in your codes, etc.
It is easy and straight forward to program and use.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful - Best regards!
Aug 05, 2009 | Weiser Lock POWERBOLT ELEC DEADBOLT
Instruction Manual
Pat
Jun 21, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
