It indicates that the player is fine but the power on switch is faulty. Please have it replaced.
Hi! If you can access the battery for removal please do it. The system will be resetted once the battery is removed and this may resolve the problem. HOpe this helps and thank you for using FixYa!
Thats the problem with players... everything is concealed. This issue came across me sometime last week and the cure was just turning the unit on and off several times. The second option is let the battery drain itself, recharge it, turn it on and see how it goes.
Since its not running anything this may take sometime to discharge. Give it atleast 48hrs. If it still doesn't work then the unit itself may have reached it's break point already.
If thats the case, it is surely covered with warranty and you may ask for replacement from the supplier.
I can see no way to access the battery. The top will no slide off, and there are no screws. Have another idea? Or maybe you know how I can get to the battery?
I appreciate you answering quickly, though.
Because the screen does not indicate if the unit is on or off, how can I get it to discharge? The only things it says are USB transferring, USB connected, or battery full. How long does it take one of these to discharge, assuming I have the unit turned on?
I hope not; it's only a couple of weeks old!
I appreciate all your help.. I will get it fixed. Thankx again.
