Question about RTO Pelouze Scale With Remote Display - 400-Lb/180 kg Capacity
Have a pelouze model 4010 when i turn it on it says e1 ????????
2 Suggested Answers
SOURCE: how to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Posted on Aug 26, 2010
What does the EPS stand for on 4010
Future tip, include FULL 'YEAR MAKE AND MODEL'.
The MULE 4010 Trans4x4 is built with reliable standard features such as selectable four-wheel drive, Electric Power Steering (EPS) system and a powerful engine equipped with Digital Fuel Injection (DFI®) that works in conjunction with a fully automatic transmission and locking rear differential.
2015 KAWASAKI MULE™ 4010 TRANS4x4®
https://www.kawasaki.com/Press/Release/2015-Mule-4010-Trans4x4
EPS stand for on 4010 Google Search
Oct 16, 2017 | Cars & Trucks
Pelouze 4010 display only says 4010
This is not a camera - please repost in a more appropriate forum.
Apr 17, 2017 | Cameras
How to calibrate rubbermaid 4010-88 digital scale
Pressing the ZERO button will set the display to zero.
Here is the Spec Sheet
http://www.rubbermaidcommercial.com/rcp/products/detail.jsp?rcpNum=4010-88
If you think it is no longer accurate you would have to get an engineer in to reset it. Here is the Calibration Certificate.
http://www.rubbermaidcommercial.com/rcp/ObjectServer?table=PDFs&id=660
Dec 29, 2015 | Rubbermaid Pelouze 4010-88 150 lb. Digital...
Fix my pelouze fs6 scale
Based on its appearance I'm guessing that you need to unplug it and open it up. Clean it as well as you can with a stiff brush and an electronics safe cleaner. Roaches are the most likely cause of your scales failure!
All the above may be fruitless, it may not be possible or worth the cost to repair.
Time for a new scale! You must keep it clean and turn it off and disconnect it when you aren't using it. Roaches like warm damp dirty places!
Apr 03, 2014 | Health & Beauty
I need to get an operator's manuel.
At the website www.samsungcamera.com site you can download the manual and the driver for the Samsung Digimax 401 and the Digimax 4010 which are the same camera.
To get there go to the site and click on SUPPORT then at the bottom of page select page number 9 or in SEARCH type in 401 which will take you to the Digimax 401. DON'T FORGET THE DIGIMAX MODELS 401 AND 4010 ARE THE SAME. I proved it since I compared my 4010 manual to the PDF for 401 and page per page identical. You will have to select a language for the manual and assume also for the camera driver. I found that the Samsung site was not user friendly when I first used it looking for the 4010 model which is not listed but the 401 is there.
Hope this helps.
Dec 14, 2010 | Samsung Digimax 4010 Digital Camera
What is an E1/
see the relationship between the E-carrier system, the T-carrier system, and DS0 multiples, see digital signal X. E1 (or E-1) is a European digital transmission format devised by the ITU-TS and given the name by the Conference of European Postal and Telecommunication Administration (CEPT). It's the equivalent of the North American T-carrier system format. E2 through E5 are carriers in increasing multiples of the E1 format.
The E1 signal format carries data at a rate of 2.048 million bits per second and can carry 32 channels of 64 Kbps* each. E1 carries at a somewhat higher data rate than T-1 (which carries 1.544 million bits per second) because, unlike T-1, it does not do bit-robbing and all eight bits per channel are used to code the signal. E1 and T-1 can be interconnected for international use.
Mar 22, 2010 | RTO Pelouze Scale With Remote Display -...
How to calibrate a Pelouze model 4010 scale with a
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
PELOUZE 4010 SCALE READOUT FAILED
my pelouse when i turn it on it stays on 0.0 when i put weight on it stays on 0.0 it then goes of i need help to get it to work
Jan 28, 2009 | Office Equipment & Supplies
RTO Pelouze Scale With Remote Display - 400-Lb/180 kg Capacity Logo
Top RTO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
