Question about Ricoh Aficio 2027 All-In-One Laser Printer
I have a Ricoh Aficio 2045eSP and it didn´t work the network SMB to send scanned files to my pc with win 7. I´ve tried with win xp and it works! any upgrade or firmware to use? tks
Paper jams
Posted on Aug 08, 2011
Hello I'm in Brazil can not resolve error in my SC990 Ricoh Aficio 2045eSP. This error pops up after 10 copies or printing. Already exchanged cylinder, blade, developer and toner new. Please help me.
Why change the drum, blade, developer ????? You had problems with print quality?? I think it was just spending money ....
You have a network problem or machine firmware. To remove the doubts plug a laptop directly to the machine with a cable (Not necessary a croos cable). This may be a virus network or a broken swith.
Good luck
Feb 11, 2011 | Ricoh Aficio 450 Copier
How to install RICOH Aficio 2045eSP to network computer?
do you use a switch or a router on your area, and also may i know the OS that is installed on your PC..
thanks
Aug 06, 2008 | Ricoh Office Equipment & Supplies
Canoscan Lide 30 compatibility with Windows 7.
There are no official drivers for CanoScan Lide 30 for Windows XP, so your problem is obvious. I suggest you sending an e-mail at Canon including details about your scanner (date purchased, serial number in text form or scanned) asking them to develop driver set as this model is very trade and at shops since 2006 or 2007.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 27, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
Hi, I ma trying to connect my gestetner DSM415f to my home network. I have the wim open and hve pinged to be sure that it os being picked up. I am trying to set the machine up to scan. I am operating...
Folder must be fully shared, (full control for everyone.) create a user name and password that has admin priviledges. Enter this info in Config>File transfer>SMB.
Enter the path to the folder in the address book, in this manner> \\name of computer folder is on\name of directory\name of folder.
Sep 07, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
I have a Ricoh Aficio 2022sp that refuses to send scans via smc to ONE Vista PC. Other users have no issues. I have disabled virusscan and firewall and tested all securities and permissions. Still PC and...
Are you using ScanRouter or SMB (SMC?) ?
How are the others setup?
Does the laptop have connectivity to the machine (print,Webbrowser)
I've solved these poblems hundred of times
Aug 05, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Hi! i m using ricoh aficio 3224c as printer n scanner (smb) for my lan, its good, no problems. but when i configure it on the wireless network its not accessing the destination n shows "waiting" in...
The wireless network (router) has a different IP address, than your 'hard-wired" connection, so the destinations will need to be re-programmed to match the new IP address of your server (or individual workstations), depending on how it was set up.
May 03, 2009 | Office Equipment & Supplies
Dont know how to configure scanner on Ricoh Africo 2018d. It is set up as a network printer atm
There are a few ways, such as configuring "SMB", "Scan to "Email" and/or installing "Scanrouter", but they are too involved to explain here.
The other is the "Network Twain Scanner" which, once installed, you can use a program such as "photoshop" , or many other photo editing softwares to scan. Simply open the program, click "file", "Import" and you should see the scanner as an option, make your settings, and go.
You can get the software here. Just select your operating system. It will need to be installed on each PC:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x2015_18/x2015_18en.htm
Mar 06, 2009 | Ricoh Aficio 2018D All-In-One Laser...
HO TO FIND THE RIGHT DRIVER FOR RICOH AFICIO 250 COPIER
Goto ricoh-usa.com and select the correct drivers from the model number for your copier.
Use the PCL drivers only.
Oct 19, 2008 | Ricoh Aficio 250 Copier
Problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Jul 02, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2027 All-In-One Laser Printer Logo
364 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
