Question about Dryers
How do you change a whirlpool dryer belt. Model lg5601xswo
  • 2976 Answers
SOURCE: UNABLE TO GET AT WHIRLPOOL DRYER BELT SO I CAN
You will have to take the back off and pop the top up. To pop the top, insert a stiff putty knife into the joint where thr top meets the front, about 2 inches in from the sides. Push inward to release the catches.
Posted on Feb 20, 2009
SOURCE: How to install a belt on a Whirlpool dryer model LEW0050PQ?
The tech I paid to replace the belt opened the case from the top and the back, and pulled the drum back away from the front, keeping the drum attached to the back panel. This exposed the motor and the broken belt, which had been cut by the motor drive wheel, probably because the drum was too heavy. Don't you just love renters?
Posted on May 15, 2009
Maytag317
  • 1136 Answers
SOURCE: Burning Smell from Belt on Whirlpool Dryer
Hi, You need to check and see if the belt has slipped off of one of the pulleys. Was the idler the wheels style or a glide style?
Make sure the grooves in the belt are facing the drum and they are in the grooves of the motor pulley.
Please let me know if this helps and if I can assist you further.
Vic
Posted on Jun 01, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: how to change a belt on whirlpool dryer
Check out this page for good information on changing the belt. Good luck with your repair!
Posted on Mar 02, 2010
  • 15 Answers
SOURCE: changing dryer belt
The drive belt goes around the drum near the rear. It does not use a special groove; it just runs on the surface of the drum. You will need to remove the drum to gain access to the broken belt, motor, and idler/tensioner pulley. It will make more sense when you remove the drum and view the motor pulley and belt tensioner. With a helper, install the new belt around the motor pulley and under the tensioner, then fit it around the drum little by little as you reinstall the drum. Make sure the drum is positioned properly on its rear support wheels, then manually support the front end and rotate the drum slowly by hand. It should rotate freely and the belt should start to track straight as it realigns itself on the drum. If it tracks well, reinstall the front panel, door, top, etc., and check operation.
Posted on Jun 27, 2010
How to change the belt on a whirlpool AWZ7814 AL
These dryers have common roots with lots of other brands. You should be able to see what you need via either video:
How to Change Dryer Belt on Whirlpool Dryer or in Instructables
How To Replace Dryer Belt on Whirlpool Models
Nov 18, 2015 | Whirlpool Dryers
How to change dryer belt
You have to remove the drum, by disassembling the dryer. That process depends on the model.
Jul 19, 2014 | Whirlpool Dryers
The belt is broken and we need a replacement for it.
Hi and welcome to FixYa, I am Kelly
Go to any of these sites and enter your model number:
http://www.searspartsdirect.com
http://www.appliancepartspros.com
http://www.repairclinic.com
If you have difficulty locating your belt I need your complete model number and will use those same sites to find your belt for you. There are 2 different sized belts for a whirlpool dryer depending upon the model number. 27 inch dryer and 29 inch dryer.
Download this manual to help you change the belt:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
The order of removal is the toe panel, top and then the front panel to gain access to change the belt.
Toe panel (page 15 / pdf file page 20)
Top panel (page 14 / pdf flie page 19)
Front panel (page 19 / pdf file page 24)
Make sure you inspect the drum seals (felts) and the the drum rollers in the process of changing the belt.
The manual link I passed is for the 27 inch dryer but access is exactly the same for the larger dryer.
Thanks for choosing FixYa,
Kelly
Mar 30, 2011 | Whirlpool Dryers
How to change a belt on whirlpool dryer Model LER4634EQO
Mar 01, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Changing a belt is it a major job or as easy as taking the back cover off and replacing the belt? Whirlpool model #GHW9100LW1
For the model you have listed, changing a belt cannot be accomplshed by removing the back of the dryer. The following link explains step-by-step how to replace the belt on your dryer:
http://www.fixya.com/support/r3059469-install_dryer_belt_kenmore_elite
This can be a tedious process, but isn't difficult if you follow the steps provided. If you have any questions along the way, please let me know. I hope this helps you.
Oct 26, 2009 | Whirlpool GHW9100L Front Load Washer
How do you change the belt on a whirlpool model m52306940
This video will show you the basics. It's not the same as your machine but it's about the same deal to change a belt in any dryer.
Oct 02, 2009 | Whirlpool Dryers
Vic
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Whirlpool oaisis dryer will pwr on, but when start pushed-clicking noise and dryer won't start. Must pwr dryer back dwn to be able to change any timer setting, but dyer still will not start. ????
Model is 110.6705 Oasis Kenmore elite. Have removed back cover and have found drive belt broke. is there a seensor to shut motor dwn if belt breaks? Will order belt replace and see if thay resolves issue. Thanks
PS
No code given.
Oct 16, 2008 | Whirlpool Dryers
Dryers Logo
62 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
