Question about Hampton Bay Heating & Cooling
Gas boiler problem - Hampton Bay Heating & Cooling
  • Hampton Bay Master
  • 43,501 Answers
For a competent expert to be able to answer your problem, you will need to givea specific make and model of your unit.
Also include as much as possible about what you have already tried to do toresolve the problem along with exactly what is not working or what the unit isnot doing that it is supposed to do.
This will help us experts to be able to give you the correct advise the firsttime, without having to guess so much as to what is actually happening.
Thank you!
heatman101
Posted on Sep 28, 2010
After moving my gas meter from inside the home to outside and having a semi concealed meter connected we cant get the combi boiler to work properly we can get hot water and have the gas fire on but
your boiler needs a minimum gas pressure of 16 mb to light successfully. if your gas pipe has been extended it has to be able to flow enough gas. it may need upgrading to 28mm for even as little as a metre from the gas meter. if your central heating works ok when the fire is off then this is your problem
Oct 12, 2014 | Water Heaters
How do I relight a gas boiler, when the mains gas was turned off, for some months, without turning off the boiler fist?
If the gas has been turned off for awhile,the unit will have to bleed the air from the boiler before it is lit.
Oct 08, 2014 | Water Heaters
Why does my alpine boiler beep
Did you ever find out? Because ours is now beeping and there are NO answers online that we can find.
Jun 19, 2014 | Burnham Alpine Gas Condensing Boiler Wall...
Operating worcester bosch 240 gas boiler
  1. If there is no water on the floor, your crack is probably OK so far. The water thing is a worry though. NEVER fire a boiler that is low on water. Adding water to a hot boiler will crack it. Tell me all you can on what components you have in the water and gas lines.
Nov 15, 2013 | Weil-McLain Heating & Cooling
My ariston boiler is not working it just shows A 01 have reset but still nothing any ideas?
Basic checks:-
water pressure in boiler
gas supply on
Turn boiler on then:-
does the fan come on - u can hear this at the top of boiler
does the gas valve click on
has there been a burning smell near the lower front [check the pcb]
check the co-axial flue is ok with no gaps between inner & outer [rare but not unknown]
If it's a condensating boiler check the condensate outlet tube for ice blockage especially in current weather
Dec 27, 2009 | Water Heaters
The hot water and central heating wont work together
what size of gas line is going into boiler and water heater? is it black iron ? natural gas or propane? have you checked gas pressure at water heater and furnace ? if they work fine individually then you have a problem with incoming gas pressure. Call gas company and ask them if they would come out and check gas pressure.
Feb 03, 2009 | Water Heaters
Smell of gas with new boiler when on?
If you had it professionally installed i would call the company who installed it to come bac and fix problem...If you installed then i would check all the gas connections for tightness
Feb 02, 2009 | Heating & Cooling
Repressurizing my boiler
take your pick from video or text
How to Repressurise a Heating System with an Internal Filling Key ...
? 3:30
https://www.youtube.com/watch?v=zUsBw1ZpiKY
Oct 27, 2010 - Uploaded by Worcester, Bosch Group
This video shows you how to repressurise your heating system using your Greenstar gas boiler's internal ...
Repressurise Worcester boiler - YouTube
? 4:12
https://www.youtube.com/watch?v=K6fH4XfGgxo Nov 10, 2012 - Uploaded by Rory Macfarlane
This video demonstrates how to repressurise a Worcester combi boiler on the.
Product Troubleshooting Videos ' Worcester, Bosch Group
https://www.worcester-bosch.co.uk > Support > Troubleshooting > Videos How to repressurise a heating system with an internal filling key ... how to repressurise your heating system using your Greenstar gas boiler's internal filling key.
How to top your Worcester combi boiler up - Gas Care.
www.gascare-heating.co.uk/topping-pressure-worcester-bosch-combination-boiler/ Aug 4, 2014 - If the needle on the pressure gauge on your boiler has gone into the red or down to zero it means there is little or no pressure left in the heating system and it needs to be topped up ASAP. So here's Gas Care Swansea's guide to refilling your Worcester Bosch combination boiler through the internal filling link.
How do I re-pressurise my Worcester Bosch boiler? - My Plumber
www.my-plumber.co.uk/blog/how-do-i-re-pressurise-my-worcester-bosch-boiler/ Sep 1, 2015 - 6) Check the pressure on the pressure gauge. When it reaches between 1 and 1.5 bar, it is time to turn the white knob back to the right to close the valve. Be very careful not to over-tighten. 7) Turn the filling key to the left until the arrow lines up with the open padlock and remove the key.
May 12, 2017 | Heating & Cooling
Installing a boiler
Set the Miller to turn on at 7-10 degrees lower than your wood boiler. Make sure the Miler works by turning up the t-stat 10 degrees higher than room temperature first.
Sep 13, 2008 | Empire DV-215 Direct Vent Natural Gas...
Heating & Cooling Logo
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
AJMAL KHAN
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
