Question about Bissell Vacuums
My new bissell pro x will not suction water, it worked the first time I used it but will not work today when I tried to use it.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 28, 2010
I bought a bissell pro heat pet tried to use attachments there is no suction i am unable to use it because of this
Check the lever that closes the valve to switch the suction from floor to tools to make sure it's working properly.
Feb 13, 2018 | Bissell Vacuums
Royal pro series carpet cleaner, new only used once. Tried today and sprays water but won't extract. Nothing in dirty water tank.
Inspect where the suction comes the machine into the water tank and through the tank to the nozzle assembly. If something isn't seated correctly or isn't working properly it could cause a suction loss.
Dec 01, 2017 | Royal Vacuums
Used bissell how do i know if parts are missing
The main water tank is two staged; you put clean water in and the flexible bladder allows the machine's pickup suction to fill. This removes the need for two tanks (but it's harder to clean out the suction tank area). Just remember to clean the filters each use. There's one on the underneath of the clean water tank cap and one under the FLOW INDICATOR cap. You may need to get a User's Guide. Try calling the Consumer Care at 1-800-237-7691 Hope that helps.
Apr 03, 2015 | Bissell Vacuums
I can't get the brushes to rotate and the water to spray on the bissel pro heat 2x.
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 24, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell pro heat 2X has stopped dispensing water from the tank, the suction is working and it seems to be dispensing the detergent, so it is not rinsing or washing with water. I have cheaked to see if...
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 19, 2010 | Vacuums
When I am cleaning carpet, the water spray works
I have a Proheat 2X and had the same problem. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
Apr 19, 2010 | Bissell 25A3 Upright Vacuum
No suction and brushes not turning
heatman101
43q3
Sep 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Carpets soaking wet
turn dial in front on the water tank to floor not tools and thats should do it...go to bissell.com to read and print manual so you can double check everything
Feb 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No suction
I had exactly the same problem with my five-year old my Bissell 7920, and it's probably a broken pump belt.  See page 19 of your instruction manual for how to replace.  The Bissel ProHeat belt accessory pack costs $3.99 and you get a pump belt and a brush belt.  Since you have to first remove the brush belt to get to the pump belt, you might as well replace both. The first time I did this it took me 15 minutes, but now that I know the drill, doing a belt replacement would take about 3 minutes.
Apr 10, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Vacuums Logo
64 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
