Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Can't find manual, drained oil, how much do I put in now
    Scholar:
  • 150 Answers
It probably takes between 1.25qts and 1.5 start at 1.25 and use the dipstick it is marked. Be patient do not overfill
Posted on Sep 28, 2010
How do i change the oil?
Details vary according to the model, but generally:
1. Run the motor long enough that the crankcase is warm.
2. Put the bike up on the center stand.
3. Put a plastic dish/bowl that will hold a few liters underneath the oil drain (usually a bolt on the bottom of the crankcase, check a manual for exact location. )
4. Using the correct wrench, loosen the oil drain.
5. With rubber gloves on, hold the bottom of the oil drain bolt with one hand while you remove the bolt from the bike with the other hand. If the bolt (which may be magentized) has bits of metal clining to it, remove these with a cloth or paper towel.
6. The oil will drain into the pan. Rock the bike back and forth gnetly to get the last few drops out.
7. Now locate the oil filter and remove it (check manual again for how to do this). Replace with fresh filter.
8. Replace oil drain bolt, tightening to correct setting.
9. Fill with fresh oil to the correct amount. Bike should be ready to go.
10. Put used oil into container with lid, have it recycled at a grage or auto service scentre.
Nov 23, 2014 | Motorcycles
I need a step by step (for dummies) procedure to change the manual transmission fluid in my 96 Tacoma 4cyl?
First Look under transmission for a drain plug like a Bolt size Then Open your Hood Check On the side for Oil gauge... From that Oil Gauge after draining your old Oil ...Put Back Your Bolt ..Then Find a little Funnel to put our new Oil throw that Oil Gauge.. Transmission Oil For Manual Transmission Only From Canadian Tire ...Good Luck
Oct 09, 2010 | 1997 Toyota Tacoma
Oil change procedure on BMW R 1150 R 2002
Things you will need, Drain pan, 5 quarts oil, BMW oil filter, oil drain plug seal, can of brake cleaner, allen head wrench that fits your drain plug, a oil filter wrench for R- Bike filters, ratchet with a drive that fits the oil filter wrench, paper towels, latex gloves, funnel that fits into the oil fill plug hole. I also keep an old blanket around so I can lay on the ground. Warm the bike up for 5 mins then turn off. Get the bike on the center stand. Position your drain pan under the drain plug . I like to lay out everything im going to use on 4 or 5 paper towels . Remove the fill plug on the top of the left cylinder, set it on the paper towel to keep crud off it. Take your allen head wrench and loosen the drain plug , if you using an open pan to drain your oil , be prepared to fish out the drain plug, it will fall into the oil drain pan. Let the oil drain for 10 minutes. Take some brake clean and spray it all around the area of the oil filter to get rid of all the crud. All the dripping **** should flow into the drain pan if you bought one big enough. Buy drain pans that you can reseal when your done, put it in the car and take it to a recycling center. Put the oil filter wrench onto the ratchet. This oil filter wrench will slip into the filter slot under the engine. Just turn the ratchet untill the filter comes off. Should be clockwise. After the filter is removed, spray brake clean into the filter housing area to get rid off the **** and oil, wipe down with a paper towel and reach up into the filter housing to get all the ****, one final spray off brake clean should clean everthing out.
IF THERE IS NO MORE OIL COMING OUT OF THE DRAIN PLUG, put a new sealing ring on the drain plug and tighten up , snug not TIGHT.
Now before you put the new oil filter on , open up a quart of oil and fill the oil filter up about 90% with new oil, put a little oil on the rubber seal, put the the oil filter into your filter tool and insert the tool and filter up into the filter housing. Do this be hand so you will not strip the filter housing threads. The filter should go on very easy and you should be able to turn the filter at least 3-4 turns until its hand tight, Finish off with the ratchet, SNUG NOT TIGHT. Finish off with a little brake cleaning on the bottom of the engine housing to clean up any oil. Put the funnel in the fill hole and put in 3 quarts of oil. Read your owners manual for your oil capacity. There is a sight glass on the lower left side off the engine under the cylinder. Fill with oil until the oil level is in the middle of the sight glass. Put you fill cap back on. Turn you engine over a couple of times put dont let the bike run for more than 5 seconds, let the bike sit for 2-5 minutes to let the oil level settle, then check the oil level in the sight glass, it should be in the middle. if you dont see any oil in the sight glass after 2-5 minutes add a little oil at a time until the oil level in the sight glass is in the middle. Start the bike agian for 5-10 seconds , then check the oil level in the sight glass. You should be good to go. email me for any questions
Apr 13, 2010 | 2002 BMW R 1150 R
I have a 1993 Plymouth laser and have never changed oil before, but watched, not sure what to do.
Remove drain plug from oil pan to drain oil. Remove oil filter using filer wrench. Instatt new oil filter. Put oil drain plug back in. Check owner's manual for oil capacity, put all oil in minus one quart. Start engine let run for aproximately 10 seconds. put in rest of oil and check dip stick to ensure corret amont.
Oct 09, 2009 | 1993 Plymouth Laser
Can i drain the transmission fluid on a 05 suzuki forenza my self?
yes. HOWEVER, whe you refill it. make sure that you put in the correct type of oil. refer to your owner manual prior to putting in any old automatice trranny fluid as some tranny's require a sopecial type of oil, put in the wrong one and you fry your transmission. If its a standard, put in the correct weight of gear oil. Not trying to scare you, but i want to make sure that your REFER TO YOUR OWNERS MANUAL for the correct type of oil to put in after you drain it.
good luck.
Sep 27, 2009 | 2005 Suzuki Forenza
How can I change the gearbox oil on a peugeot 806 manual vehicle the reg is 1996 I have had to put in a different model and year on the form as my car is not available as an option. My car is definatley a...
MOST MANUAL TRANSMISSION BEFORE CHANGING FLUID YOU DRIVE CAR AROUND.TO WARM THE OIL.SO IT WILL DRAIN OUT EASILY.NOW SAFELY RAISE VECHICLE AND SUPPORT IT ON JACK STANDS.LOCATE DRAIN PLUG ON DIFFERENTIAL PORTION OF THE CASE.GET SOME RAGS ON HAND.AND A DRAIN PAN.PLACE THE DRAIN PAN UNDER TRANSMISSION. REMOVE THE DRAIN PLUG.LET THE OIL DRAIN.WHEN FINISH.PUT IN NEW GEARBOX OIL.
Sep 06, 2009 | 1991 Peugeot 505
I have a 1997 porche 911 cab, I have never changed the oil and filter myself. Is it hard and how do you do it Thanks
Gravity does all the hard work. If you can figure out how to work a wrench, you can change your own oil. I'd pickup a repair manual, it will have the basics that tell you how to do a tune up/oil change etc.
You should also google Porsche groups, I'm sure there are a lot of greasemonkeys hanging out there who love to train noobies.
Its not difficult, but you need to make sure you have the right filter, and know where the drain plug is, before you get started.
Basically you drive the car a bit to get the oil warm, then you park it and set the brake. Put a drain pan under the oil pan near the drain plug. Unscrew the drain plug, wear rubber gloves, the oil will be hot, let the oil drain into the pan, now fish around in the pan for the drain plug that you dropped into the hot oil cause the oil was burning your fingers, when you find the drain plug, clean it off with a paper towel and open a beer. Now you need to remove the old oil filter, they usually either unscrew or are in a cannister, that service manual I told you to buy will tell you where it is and how to remove it. now open another beer, and put the clean filter in wherever the old filter came out of. Best to order a pizza now or you'll be drunk by the time you get this job done.
Okay clean filter is on, time to put the drain plug back in the oil pan, if its an aluminum pan, you probably should use a torque wrench to make sure you don't overtighten it and strip the threads, otherwise just put a new lock washer/crush washer on the plug (it should come with the filter)
Now add some quarts of your favorite oil after opening one more beer. That manual you bought will tell you exactly how many quarts of oil your engine will hold.
After its all together, check the dispstick to make sure you have enough oil in your car, then start the engine and move the car, look underneath for oil leaks, thats a sign that the drain plug isn't tight enough.
Take it for a test drive as soon as you sober up from all the beer. Easy peasy.
May 09, 2009 | 1997 Porsche 911
Where do you drain oil on honda gx25 mantis
jj505 has good and bad information.
Honda GX25 is a 4 stroke motor, with oil lubricated crankcase.
Oil drains out the filler.
Oil and gas do not mix on this four stroke.
The PDF below is the Honda manual.
http://www.smallenginewarehouse.com/images/manuals/GX25-35.pdf
Apr 12, 2009 | Mantis 4-Cycle Tiller
Changing oil and filter
If you have never changed your oil before use care:
0.) Safely Jack up vechile
1.) remove oil filler cap
2.) remove oil drain plug on oil pan
3.) Let oil drain into a container
4.) Flush a quart of through with the drain plug removed to get any deposits out.
5.) remove and drain oil filter
6.) install new oil filter(make sure you put some oil on the filters gasket by hand)
7.)Install oil drain plug
8.) Re-fill with oil
9.) Put oil filler cap back on
Hope this helps and again use with care if you have never turned a wrench before, people get hurt easily by being careless while working under a car.
Jun 27, 2008 | 2005 Mercedes-Benz E-Class
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
23 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
