Question about Panasonic KX-T7730 Corded Phone
HOW DO I GET THE INTERCOM TO HAVE A TONE ALERT
  • Panasonic Master
  • 2,460 Answers
It's done in programming so the AUTO ANSWER button can control it. It needs to be dark and you need to tell the phone it's a TONE CALL. In a TA series that's done via (without picking up the handset) press PROGRAM 41 STORE. (42 is VOICE CALL and the button becomes the MUTE key).
Now, the AUTO ANS button toggles between ringing on the intercom and Voice Announce with Handsfree Answerback when lit.
Carl
Posted on Sep 28, 2010
I have a Panasonic Keyphone Model: KX-T7750, having problem with alert of intercom/incoming calls. No ring tone but with flash light and intercom light on. May I know how to fix this. Thank you!
Calls are signalled in two ways. First, check the Ringer switch on the left side of the phone. It's a 3 position switch OFF/LO/HI. If the outside lines are blinking the MESSAGE light, then the ringer is probably turned off. If your intercom calls are toning but not ringing, you may have the AUTO ANS light lit. Press it until it's off and intercom calls will either start ringing or send an audible tone.
If it tones, then you have a programming problem where intercom calls are set to tone instead of ring. That's corrected in system programming.
Carl
Apr 25, 2011 | Panasonic KX-T7730 Corded Phone
How to change message tone
You can try two different approach to change the message alert tone:
1) Go to menu display and light and press for widget
2) Tick sound settings box and click out to main screen.
3) pull across the little tap at the side of the screen and press the phone icon.
4)At the top right hand side click the little box and scroll down to New message
5) You will see a box containing Message alert type and another box with Message alert tone.
6) Just select a tone or go search for one by selecting sounds.
or
  1. Go to profiles
  2. Select new messages from the drop down list on the top right corner,
  3. Select message alert tone, choose sounds go to gallery and then
  4. select the tone that you want to set as message alert
Feb 25, 2011 | Samsung SGH-S5230 Cell Phone
INSTEAD OF RINGTONE, I GET A SINGLE BEEP
your phones alert tone was set to beep once, to change this go to profile settings then open the activated profile such as general>personalize>message alert tone then now choose the ring tone you want to use as message alert tone..
Jan 30, 2010 | Nokia 6101 Cellular Phone
How can i change my message tone on my samsung f480 from the standard tones set on the phone
Instead of changing the ringtone settings, tap the message alert tab (in the top centre of the display).
A set of message alert settings appears . You can change the Message alert type, if you want to, by tapping the panel and choosing the appropriate option.
To change the Message alert tone, press the Message alert tone panel .
In the menu that appears, press Change.
Then choose one of the options Use effect tone (one of Samsung's pre-loaded effects) or Use my alert tone (allowing you to choose from your own sounds) .
In this example, press Use my alert tone.
Press the Sounds option. In a similar way as changing ringtones (above) you now have the choice of choosing from your Music files, Ringtones that are loaded onto the phone, or My voice clips .
In our example, we'll again choose a file from our Music folder.
Press the Music option. A list of suitable MP3 tracks appears.
Tap the one you want in order to highlight it.
Press Options, then tap on the Select menu option to install it as your message alert .
You are now taken back to the Normal profile settings, where the Message alert tone has changed .
To save this change, press Options and then Save .
Alternatively, press Back and you will be asked whether you want to Save? Press Yes
Jan 12, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
How do you get the intercom off?
Not sure what you mean by "off". What is it doing and what do you want it to do specifically? Is it sending a tone or alert when an extention phone is called via intercom?
Oct 08, 2009 | Panasonic KX-T7731 Corded Phone
Change message alert tone samsung l700
can i change my message tone to alert tone
Jul 16, 2009 | Samsung SGH-L700 Cell Phone
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 | Nokia 3100
I have a problem that . i cant change sms tone except the samsung mobile tone .which is inbuild. how could change this,...
SETTINGS>>PROFILE SETTINGS>>SELECT YOUR DESIRED PROFILE>>MESSAGE SETTINGS(RIGHT POINT OF YOUR SCROLLING BUTTON>>MESSAGE ALERT TONES>>CHANGE>>USE MY ALERT TONE>> EXPLORE>>> SELECT AND SAVE>>> YOUR PROBLEM IS SOLVED!!!!!!!!
Mar 17, 2009 | Samsung SGH-L700 Cell Phone
Message alert tone
u can't d900 is not programed to have other msg tones except for d ones already in
Sep 25, 2008 | Samsung SGH-D900 Cellular Phone
Voicemail alert tones
I think that there is just a generic message alert tone setting applies for both vm and text. If your voicemail alert tone and message alert tones are the same, this is probably the case. I have searched the menu on my phone and haven't found any setting to change vm tone specifically.
Feb 14, 2008 | LG Shine KE970 Cellular Phone
Panasonic KX-T7730 Corded Phone Logo
113 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
