Question about HP LaserJet 1018 Printer
The hp laserjet 1018 has the front cover door open or the toner cartridge is missing.
  • 6 Answers
SOURCE: hp LaserJet 1000 series printer error message on front door cover and toner cartridge missing
hi..
ijust solved this issue
WHOA ...
my printer is HP 1020,, and i was printing a huge number of sheets, which USED TO GET STUCK IN AGAGIN AN AGIAN... coz, i was using a low quality damned paper..
now,, it began to gave error ,tht either the front cover door not closed , or its toner cartridge missing.
Well,, simple solution for me was (which is basic i think)
>> Remove the metallic plate on the back of the printer
>>there you 'll find , on the right side, near the socket for poer cable, a "lever" like thing, thats the lever for the "barrier" between the SENSOR... move it and u'll get an idea..
>> if its jammed ,, then free it..
(mine was stuck into dont know wht, and i freed it, and all is fine)
>> if spring adjusment is wrong, correst it(you may get idea by moving it again n again, whether it comes bbacl to its orgignal position or not...
> remore the tonor cartidge and insert it back while looking on the lever movements.... and you ll get whats the matter with it..
PLEASE note it,,, that i think,, the sensors are NEVER damaged !!! mind it.....my knowlegde says , sensors are hardly damaged ..
-----Adios.... Tauseem Omer...Ravian Kemcolian.
Posted on Sep 12, 2009
Chittaranjan
  • 62 Answers
SOURCE: Error message coming up: The HP LaserJet 1020 has
send your printer for service. seems like, one or two sensors are malfunctioning.
Posted on Aug 09, 2009
  • 42 Answers
SOURCE: hp laser jet 1018 giving
If you are using a non genuine HP cartridge, it is very likely it is defective and can not read the chip on the cartridge. Replace the toner with a Genuine HP cartridge.
Posted on Jan 17, 2011
  • 2385 Answers
SOURCE: The HP Laserjet 1018 has
Hello
You need to perform following steps:-
Open the door of toner and close it properly
take out the toner cartridge and insert as directed in manual
clean the electric contacts of cartridge and printer
otherwise you need technical assistance for repair
Good Luck
Posted on Jan 31, 2011
  • 45 Answers
SOURCE: the hp laserjet 1020 the
Open The printer Side Cover. Then Remove Back Plate Of Printer There is Senser On Back Side Check They Are moving or not there is spring in senser
Posted on Feb 07, 2011
How can fix this error. i seen this "the hp laser jet 1018 has the front cover door open or the toner cartridge is missing"
Hello !!
For tha particular error you are facing, here is the reason. These printers have a switch that triggers an interrupt when the toner door is closed. Usually there is an arm on the door that pushes the switch. It is quite sensitive and delicate. Then sometimes there is a tab on the printer's toner and if that breaks off then that error will be generated.
But in your case as you have not removed or inserted the toner, I think option 1 is applicable to you.
Now, if this printer is in warranty you should send it to HP for Free repair/replacement.
and chek BLOW links too for paper jam and cleaning
Paper jam Message Displays for HP LaserJet 1018 1018s 1020 and 1020 Plus... Cleaning the Printer
Dec 23, 2014 | HP LaserJet 1018 Laser Printer -...
Ghow to close front cover door of HP Laser jet 1020
If it does not easily close it usually means that the toner cartridge is not setaed properly. Gently remove the cartridge and reinsert. It should go further in and you should then be able to close the door easily.
Oct 04, 2013 | HP LaserJet 1018 Printer
HP LaserJet 1020 won't print. Error: HP LaserJet 1020 has the front cover door open or the toner cartridge is missing. The door is closed and the toner crtridge is installed properly. I tried to upgrade...
Did this just suddenly happen or was it after you replaced the toner cartridge or opened the door?
I have found that if the toner cartridge is not completly positioned into the printer, it can give this error.
Feb 23, 2011 | HP LaserJet 1020 Printer
The hp laserjet 1020 the front cover door open or the toner cartridge is missing
Feb 07, 2011 | HP LaserJet 1020 Printer
The HP Laserjet 1018 has the front cover door open or the toner is missing
Hello
Good Luck
Jan 31, 2011 | HP LaserJet 1018 Printer
Hp laser jet 1018 giving error that front door is open or toner cartridge is missing
Jan 12, 2011 | HP LaserJet 1020 Printer
Missing catridge or door open
when you put new 12A cartridge. you have to align it trough by the option.
Feb 17, 2009 | HP LaserJet 1018 Printer
Error message "cover door is open or printer cartridge is missing"
Try to find the latch in the cover that presses a switch to indicate it is closed it is usually a small stick projection at the sides of the cover. Replace the cartridge it should fit snuggly then try it again.
May 28, 2008 | HP LaserJet 1018 Printer
546 people viewed this question
Seeker5211
Seeker5211
