Question about Konica Minolta magicolor 2430 DL Laser Printer
Fatal Error code 17H is all it states.. will not print what does it mean and how do I fix it. Thank you
It is a rack rotation failure.
• The Rack Positioning Sensor is in the blocked state
when the Rack Motor remains deenergized.
• The Rack Positioning Sensor is not blocked a second
time even after the lapse of a predetermined period of
time after it has been blocked once while the Rack
Motor remains energized.
• The Rack Positioning Sensor is unable to detect the
deceleration control position after the lapse of a given
period of time after the Rack Motor has started while
the Rack Motor is turning.
• The count value of the edge of ON signal of the Rack
Positioning Sensor during each developing positions
are not a predetermined value while the Rack Motor is
turning.
Posted on Oct 31, 2010
Fatal Error 17H
Hi
Thanks for using FixYa. Error 17H means rack rotation failure. While replacing toners, one of them might not be sitting right and due to this cause, the cartridge is stalling the rotation of the rack. You need to remove all of the toners installed by selecting the properties of the printer. After that select "install toner" and reinstall all of them. Check for any physical damage on anything around the toner rack or a small piece of paper jammed in the right hand side of the toner rack.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Jul 23, 2009 | Konica Minolta magicolor 2300DL Laser...
Fatal error 17h
17H is the Rack Rotation error. If your toners are not rotating correctly, or if you have the wrong type (IE 2400 series toners in a 2500 series printer) you will get this error.
Feb 18, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Fatal Error 17H
If the machine is under warranty then take it back to where you purchased it, or contact konica minolta directly and push for machine replacement.
Nov 01, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Where are the toner cartridges in magicolor 2300 dl
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing
rack rotation
open door, remove waste toner box then you have to find a small switch in left side and push it wit screwdriver or something, then you can rotate the toner rack manually. then install the waste toner box again and power up printer.
Sep 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Fatal error 17H
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing rack rotation
<Remedy>
Electrical components for detection of the malfunction
Rack motor (M2)
Rack clutch (CL1)
Rack home position sensor (PC4)
Master board (PWB-A)
Controller control board (PWB-P)
Rather than try to explain in more detail i can forward you the service manual (4.17mb) if you update with an e mail address
Jun 05, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Minolta Magicolor Fatal Error
Remove each of your cartridges one at a time and see if you can spin the toner rollers by pushing on the little white plastic gears with your finger. They will be tight but you should be able to spin the roller by moving the little gears around.
My printer started giving the Fatal Error Code 17H and I did all the removal of the four color cartridges and re-seating each of them to no avail. After removing each cartridge and checking to see if I could rotate the toner roller I found that the yellow cartridge was extremely tight. I took the cartridge outside and used a can of compressed air to blow all the toner off the roller and tapped the cartridge on all corners and shook it back and forth several time. Finally I was able to get the toner roller so that it would rotate when pushing the little white gears like the other three cartridges.
After replacing the cartridge in the printer it worked with no more error codes. Hopefully this will fix the problem until I can order a new yellow cartridge.
Keith
Jan 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Fatal error 17H
Try going through each toner cartridge again. The error is linked to incorrect rotation usually caused by badly seated toner cartridges.
Chris
Dec 06, 2007 | Konica Minolta magicolor 2300DL Laser...
Errors
Rack rotation failure, I'm not 100% that this is that error, but does the rack, where the toner are move ? if not, move it with manually a little bit then restart printer.
Nov 14, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
192 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
