Question about Dishwashers
I have got a leisure dwlt 65 dishwasher and it just keeps showing a red light on the left hand side and isnt waorking atol?
4 Suggested Answers
SOURCE: Bauchnecht GSF 5343 dishwasher
I used to work for Bauknecht years ago.
I dont remember that machine, but it could be an indication that your salt dispencer needs refilling.
Posted on Jun 10, 2008
scottowa
  • 87 Answers
SOURCE: red light flahing on right hand side of contols on the door
If it's the model I'm thinking of that can just be a blip in the software or it means the heater isn't working. I assume it's flshing 7 times? Press heated dry then skip a button to the right and press the next one then back to heated dry back to the last button and do that a toal of three times. All the lights should come on wait about 30 seconds and press cancel. It should make that error go away. If it comes on again during the next cycle it's probably a problem with the heater. Clearing it out at least you can use it. I don't remember the exact buttons to do that special code becuase I just know the sequence by heart but there should also be instructions on how to do it on a tech sheet that's under the bottom panel if you take it off. Good luck. Let me know how it works out for you!
Posted on Apr 05, 2009
  • 72 Answers
SOURCE: CW494 dishwasher adds water, stops then beeps,
you probably need tech sorry
Posted on Jan 20, 2010
Dwlt 48 integrated.Dishwasher wont start cycle...can hear it trying but no water coming in. Filter seems blocked but have no idea how to get to it to clean it.
Might be a clogged filter. Try searching on youtube for a video I saw called KitchenAid Dishwasher Repair. He documents taking out the racks, tools you'll need and what to do. Hope this helps, good luck.
Aug 09, 2016 | Dishwashers
Whirlpool dishwasher just keeps filling? help please
check on the floor of the dishwasher on front left side. There should be a round float that is the overflow cut off. \make sure that it will go up and down. This is what shuts off the water.
Mar 07, 2014 | Whirlpool Dishwashers
Dishdrawer door comes ajar
It is also likely the drawer has come off the gliding rail at the right.
You will have to pull the drawer out from the housing and check. Not sure if you have a standalone unit or integrated with the kitchen cupboard. The instructions to pull drawer out are available in the installation manual. Select the correct model from this site .
http://www.fisherpaykel.com/au/support/user-manuals/
Dec 08, 2013 | Fisher and Paykel 24 in. DS-603 Built-in...
The light keeps flashing an going beep beep dishwasher isnt doing it's job not washing
On my dishwasher if I hold down the start button for a few seconds it resets the cycle could you do that with yours as mine is a different make?
Feb 02, 2013 | Dishwashers
Trying to start it have put it on the 60-70 Green light is showing 03 with a red star light lit up in the same panel and dishasher isn't going.
You have an interlock problem,there is a switch that isnt being made ,probably the door switch since it gets the most work
Feb 15, 2011 | Whirlpool 24 in. ADP5966 Free-standing...
No water enters, the dishwasher runs but just sounds like a buzz the entire cycle. It's a Bosch, about 3 years old
check and see if there is water in the base by removing the toe kick. if so then it activated your float micro switch. clear the water from the base. i use a wet vac, but if you don't have one just soak it up with towels. once that styrofoam piece on the left side of the base isnt submerged in water anymore then it should start. it could be a broken hose or bad part. check hoses if you have a rat or mouse lingering. otherwise i have also seen flexable cutting boards blocking the condensation hole on the inside of the tank on the right wall. if you think it was that then just keep those flexy cutting boards on the left side or top rack.
if no water is down there.. then where that styrofoam piece sets on the left side. find that red plastic rod and flip it upward a few times to un-stick the float switch with the dishwasher unplugged first of course.
Jan 17, 2009 | Bosch SHU3036UC Dishwasher
Leak from a De Dietrich Integrated Dishwasher has caused 3 red lights on the left of the Control Panel to flash and also a Blue Light on the right hand side of the Control Panel to flash. On resetting...
Pull the built in unit out and tilt towards the rear right leg and the water will drain on to the floor. The Dishwasher then restarts but the anti flood sensor will reactivate after 2-3 more washes. Do not know final fix yet.
Oct 05, 2008 | De Dietrich Dishwashers
May 04, 2008 | Dishwashers
Whirlpool adp591 red light on
i kid you not tara.if the electronics have failed,you may as well throw the dishwasher away and buy a new one.sorry
Dec 21, 2007 | Whirlpool 24 in. ADP5962 Free-standing...
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
