Question about Zyxel Computers & Internet
One of computers connected to the router lost the connection and now I can't get it connected again... there's written that everything is ok . But I cant open any web page. The other computer keeps working well so I cant get whats the problem and how I should solve it.
  • 3 Answers
Copy network configuration of pc that works juste change the IP adresse and verify that the getway is the same in bith pc and is the adress of router
Posted on Sep 28, 2010
My Internet is not working at all. I have tried disconnecting and reconnecting everything several times. I have been plugging the modem in first, waiting a few minutes and then plugging the other two
try going to your control panel, internet options, connections, lan settings and let your computer search for the connection. It may be lost
Dec 12, 2012 | Computers & Internet
I havent connect to the wi fi network ... i tried everything , which is written in the book,,.
To connect your computer to your wireless router and to protect your wireless network from unauthorized access, please click and follow my instructions :-
Normal 0 http://www.fixya.com/support/r3559128-wireless_router_security
Oct 24, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
The computer operating on the wireless link loses its connection.
Power surge is one reason that could cause this problem. It would help if you will connect your router to a surge protector and not directly to the power outlet. You can also update the firmware of the router if it is possible.
Jun 08, 2010 | Belkin (F5D7230-4) Router (587009)
Wireless-G WRT54G Router: I lost internet connection from router. Everythin...
Unplug both router and modem. Disconnect modem from router. Wait 5 mins and reconnect everything.
May 18, 2010 | Linksys Wireless-G WRT54G Router
Cant connect to my wirelessmodem
Try running the cd that came with the router again, since you reinstalled windows, the configurations for the router have been lost. If this doesn't help let us know and we'll work on it from there.. good luck!
Mar 14, 2009 | Dell Dimension 3100 PC Desktop
Connections fails and I have to constantly reboot the router
We have satellite Internet. They say everything is OK, but every few days I have to unplug my modem from the satellite, reboot, and everything is OK again. So I put a timer on mine, and it reboots every morning about 3.
Dec 22, 2017 | SMC Barricade 7004VWBR Wireless Router
Connection problem
The configuration on your Dlink may have been corrupted when the power was lost. Try to reconfigure your DLink router internet connection and your wireless network setting on the router.
Dec 20, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
I have a westell 327w router and when i connect it to the dsl lines it will connect through the ethernet cord only, and it wont let me connect through the wireless network. it keeps asking me for a key and...
Limited or no connectivity is because of the firewall on your computer. To remove that msg :(On windows xp):
start->control panel -> network connections -> 'right click' wireless LAN -> select properties -> advanced tab ->firewall settings -> select 'off'' ->ok ->ok.
The key for this router is written under the router itself. If that doesn't work, reset the modem by pressing and holding the reset button at the back of the router, for 10 seconds. This will reset the router settings to default, then try the key written on the sticker at the bottom of the router. You will have to re-configure the WAN settings after a reset.
Dec 11, 2008 | Westell Wirespeed VersaLink...
D-link di514
Try the DSL modem directly connected to the PC.No D-Link Router(powered off and disconnected). Verify that the PCcould surf/browse/connect to the Internet. Go to Start, Control Panel,Network Connections, right click Local Area Connection, Properties,scroll down to/highlight Internet Protocol (TCP/IP), Properties button.Get the IP Add, Subnet Mask, Default Gateway and DNS assigned to the PC(write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router.Go again to Start, Control Panel, Network Connections, right clickLocal Area Connection, Properties, scroll down to/highlight InternetProtocol(TCP/IP), Properties button. Tick "Use the following IPaddress". Enter this IP Add 192.168.0.10, Subnet Mask255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what youhave written down earlier). This will be your LAN IP settings. OK,close, save or whatever is applicable.
Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Usethe IP numbers previously assigned to PC that you have written down asthe router's WAN/Internet/Modem IP settings. OK, close, save orwhatever is applicable. Reboot router. Connect DSL modem to router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Aug 04, 2008 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
176 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
