Question about HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Series (chassis bottom)319470-001 (319470001) CD-ROM Drive
DVD/CD reader writer
Hi i am having a problem with my dvd/cd reader writer in that it wont alway open up cd's and when trying to copy cd's to i tunes it is ony copying at x.01 speed. If it need a one inserted how do i go about this. thanks
  • 868 Answers
Re-install the software and read the manual that it gives you.It will give you a list of options so you can fine tune your player.
Posted on May 24, 2008
    Sergeant:
    Champion:
  • 230 Answers
It may be fault of the dvd writer and also uninstall the nero and then reinstall it .................
  • balachander megavarnam
    balachander megavarnam May 24, 2008
    after that try copying to cd the itunes. mostly it will be the fault of the dvd writer
Wont read cd
Sounds like the CD-ROM drive is "dead".
Costs about $30 for a new CD/DVD reader/writer.
Installation is extra.
Feb 01, 2014 | Compaq (120192-B21) CD-ROM Drive
Error 0a-0224-0000
Dear Vincent,
The 0A-0224-0000 is a "File Copy Failed" error. It means that either the computer was not able to read from the CD/DVD or it finished reading from one CD/DVD and was expecting to read data from the next one (when you have two or more recovery CDs/DVDs). If you have more than one recovery CD/DVD, as soon as you see the CD/DVD reader LED (light) stop flashing, eject the CD and insert the next one in the sequence, doing so till all recovery CDs/DVDs have been read.
If you cannot eject the DVDs by pressing the eject button (some DVD writers only allow you to eject the disc after finishing the whole operation) you will have to straighten up a paper clip and insert it in the small hole close to the eject button to force it open and change the CD or DVD (do a Google search for "how to open a CD or DVD drive with a paperclip, in order to better understand how to do it)".
Hope this helps!
Oct 31, 2013 | Toshiba Computers & Internet
I have a HT-DT-ST- RW/DVD GCC 4480B it will burn cd-r but it wont even read dvd-r I just want to burn dvd-r but it wont even read blank one
> CD-RW / DVD-ROM
Sorry, but this device is not a DVD-writer.
This device _should_ read (non-blank) DVD media.
If it does not, then the cheapest solution is to spend $40
to buy a new CD/DVD reader/writer.
Oct 26, 2010 | LG GCC 4480B CD-RW/DVD-ROM Burner
My cd dvd-rom can't read cd's or burn cd's
If it is working correctly, it should read both CD and DVD disks.
If you have a "combo" drive (DVD-reader and CD reader/writer), it should burn CD disks.
If it is not working correctly, spend $40 to buy a replacement CD/DVD reader/writer.
Sep 12, 2010 | Computers & Internet
I purchased a plextor px-870a dvd/cd writer to replace the cd writer in our computor it is a dell with a dvd player in the top slot and a cd writer in the next slot down but the cd writer stoped working so...
On the back of a CD-writer or a DVD-writer is a small grid (2 rows) of gold pins.
Each vertical set of pins is labelled: MA(ster), SL(ave), and C(able)S(elect).
Be sure that one drive has a small jumper between the MA pins,
and the other drive has a small jumper between the SL pins.
Was there any software on CD-ROM that came with the DVD-writer,
e.g., software to play DVDs, and software to write CDs and DVDs?
To "play" a DVD, you'll need that software.
To "play" a music CD, Windows Media Player will suffice.
Nov 23, 2009 | Computers & Internet
The pc wont let me burn the imesh tunes on to cd.it says error.how would i know if i have a re-writer
if the cd has been written to already, you cannot write on it again. If the cd says CD +/- R, then it is not rewritable, look for a CD that says +/- RW. If it doesn't say either of those, a regular cd looks light grey, while a rewritable is usually a lot darker.
Oct 26, 2009 | Dell Dimension 2400 PC Desktop
I tried to reload the SD memory with the original DVD Nokia -Route 66. The SD has been reformatted but reloading does not work. Program cannot find SD memory.
Hi, this comes very late - just surfed inn - but may be help to someone. To reload R66 from your cd/dvd don't download it, follow these steps in stead:
1. Insert the memory card into the memory card reader/writer.
2. Format your memory card in FAT (not FAT32).
3. Insert the CD/DVD into the DVD drive. Select 'Browse Contents' in opened Route66 window.
4. Select and open 'MemoryImage'
5. Select the folder 'R66' and copy it to the formatted memory card.
6. Remove the memory card from the memory card reader/writer and insert it into the Nokia 330 device.
Now it should work, at least worked for me.
Jul 29, 2009 | Nokia 330 GPS Receiver
MY HP 840i dvd-rw can read CD but can't read DVD
if you have cd writer and dvd rom then change your cd drive with cd/dvd writer because in the case of cd writer and dvd rom it gives error but sometimes the dvd play also but computer freeze from sometime and when we copy data then give us error messages i give you suggest to buy new cd/dvd writer
Jun 29, 2009 | HP Computers & Internet
Dvd writer wont accept dvd-r
If you have posted the correct model of writer, then it only supports the writing of DVD+R and DVD+RW discs, but CD-R and CD-RW disc writing are supported, and it should play all forms of DVD, so it won't burn DVD-R and RW discs, but if it wont play all types then try a cd/dvd cleaner, but to be honest when writers start playing up the lens is normally faulting and a replacement drive will be required.
Jun 18, 2007 | HP DVD Writer (ds703a) (DS703A) DVD+RW...
Computers & Internet Logo
82 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
