Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Water is leaking from my washing machine when I am washing clothes and I keep getting the LD error code and UL but it is not unbalanced.
  • 20 Answers
Grab hold of the inner basket & pull up & down. Does it move up & down? If not clothing is stuck between the inner & outer basket. Tilt the unit back & use a flash light & shine it through the clear plastic & see if you see clothes in it.
Posted on Sep 29, 2010
Ul is displayed what does this mean
UL Stand for unbalanced load
probably the balance rods washer has 4 of them and they work like shocks for the tub and if they go bad than they allow the drum to spin wildly.
Jun 03, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
UL bravo error code
Unbalanced load? Don't over stuff the washer. The load sensing moves the drum back and forth at the start. If it can't balance the load it will err.
Oct 16, 2013 | Maytag Bravos MTW6600T Top Load Washer
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Wtw6600 washer has UL code and has trouble agitating and spinning.
The UL code means Unbalanced Load. Open the lid and move your clothes around so they are distributed evenly. Your spin cycle will then work normally.
Apr 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer has an error message "uL", the washer is full of clothes and water; but won't do anything...what should I try?
Unbalanced load uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the load.
If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute
the load.
Mar 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I receive a UL code on my Cabrio and it the clothes are very wet after spin cycle...
The ul error code means unbalanced load.If the load in the drier is much more than it can take, the system will not perform its operation. I can suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on washing machines and other appliances. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad.
thanks for rating good luck
Feb 04, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I keep getting a UL code which means unbalanced load..Open the machine and look at the cloths shut the door and start it back up 10 min's later wash is done . Looking at the manual it says machine is un...
This is usually a common error. You need to unplug the machine for few minutes, say 30 minutes and then turn it ON, it should reset the error.
If not, the next details you need to check :-
1. Is it accompanied by some other error code?
2. any other problem that sounds in relation with this code?
If not, it refers to faulty control board. Many people have got even error PF ( power failure ) along with it. Once replaced, it would fix the problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 25, 2010 | Kenmore 24032\24036 Top Load Washer
Ul code up and before that just cut off during load
The ul code is unbalanced load. Try adjusting the load. If it happens again try removing some of the clothes.
Mar 09, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
268 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
