Question about Sharp Televison & Video
When I replace an old Sharp VCR model VC-A411U with a newer one should I get the same model to ensure good tracking of old cassette tapes or does it matter?
  • duhowe Sep 28, 2010
    I would like a second opinion please:
  • Sharp Master
  • 17,130 Answers
It will not matter unless the recording was done with a VCR which had an altered setting in the tape track position or the servo control.
Normally if the tape runs in the correct path with the pinch roller pulling the tape evenly and the tension being set right, the track will be only normal and will never need a setting.
In the present models as there is auto tracking the control track signals are analysed and the servo adjusts the head to correct to the tracks.
All you can do is to carry few of your old tape recordings to test on the new set and prove it right , this is also needed when quality control is neglected in certain assembly lines and neww sets may not confirm to specifications. So take this tip along and change the brand if you want to have a good range to select from.
Posted on Sep 28, 2010
  • 10,865 Answers
Honestly it does not matter. The new ones are better all around.
You will be pleased with whatever brand name model you choose, I assure you. Joe
How can I get my tape to eject?Sharp VC-A560. Played my taped, rewound, but tape would not eject. Tried to play again and it would not play.What can I do?
Unplug from wall outlet - find the wheel that ejects the tape when you slowly turn it. It's usually on the right side when the cover is open. Avoid touching any metal parts.
Mar 01, 2015 | Sharp VC-A560U VHS VCR
Sharp vc-a412 will not reset to zero
You have to press the clear button on your remote control to put the counter to zero.
Oct 25, 2014 | Sharp VC-A410U VCR
I need watch my vcr tape on vc a556
Most likely you will need a scan converter to change your signal from a Video to a VGA. The signals are mismatched.
Aug 31, 2012 | Sharp 19 Micron 4 Head Vcr Vhs Cassette Hq...
My aiwa vdeo cassette recorder which spits tapes all the time
I would go to wallmart and buy a vcr head cleaner read the instrutions on it and see if that fixis the problem ...
May 29, 2010 | Sharp VC-H973U VHS VCR
Sharp VC-A582 I need a little help adjusting the tracking on my VCR, model Sharp VC-A582. I just acquired this unit and did successfully watch one tape for hours, then must have touch a wrong button by...
I couldn't find anything on your VCR either. But from personal experience I know that a lot of manufacturers use the channel up/down buttons on the face of the VCR as tracking controls while a tape is running.
My suggestion is to start a tape and then press the channel up or down button on the frnt of the VCR for a few seconds and see if it adjusts the tracking.
Hope this helps you out.
Oct 03, 2009 | Televison & Video
Tape wont eject small spring found
Take off top of vcr to expose the tape carriage lift tape door, on the lhs/rhs you shouls see the other small spring fit the spring that you have to the opposite side and try to eject your video cassette, the spring is the part that is stopping from ejecting the tape hiopefully once you have reattached the spring all should be well.
Aug 14, 2009 | Sharp VC-A560U VHS VCR
I have trouble taping when i put the timer on it does't tape.
You are looking for a user manual? Is the Sharp VC-A554U VHS VCR the correct model or do you have another device?
Thank you.
Jan 26, 2009 | Sharp VC-A554U VHS VCR
Picture blinking on a Sharp Quos HD TV
Is the VCR sitting on top of your TV? This has caused problems in the past...accordianman
Feb 18, 2008 | Panasonic PV-8400 VHS VCR
Flashing
One possibility is the tracking/audio head is dirty. Remove top cover of VCR, this head sits just to the right of the rotating video head. Use a cotton swab moistened with rubbing alcohol, or other video head cleaner and clean this head, especially the lower edge, as the tracking info is recorded along the lower edge of the tape (if memory serves). Another possibility is a problem with tape travel past this head. If the tape is lifting or moving up or down, even slightly as it passes this head, tracking will be lost, hence your blue screen & bad audio. This could be observed by playing a tape with the VCR cover off.
Jul 10, 2007 | Sharp VC-H982U VHS VCR
The unit will fast forward and rewind, but won't play
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY. Several likely possibilities when it shuts down: 1. Everything occurs as above, picture and sound appear for a few seconds, but then the VCR unloads the tape, ejects the cassette, goes into REW mode, stops, or shuts off. Two common causes: The takeup reel does not turn and tape spills into the machine. This is sensed by the microcontroller which aborts record or play and attempts to save your valuable cassette. Most likely cause: old/dirty idler tire. As a test, turn the idler tire inside-out. The fresh surface will now work well enough to confirm this diagnosis and will continue working long enough for your replacement idler tire to arrive. See the section: "General guide to VCR cleaning and rubber parts replacement". The takeup reel is turning properly but
Nov 22, 2005 | Sharp VC-H810U VHS VCR
Televison & Video Logo
111 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
