I need to set up a security password for my router at the moment i have a unsecured network?
  • 300 Answers
Open an internet window type in your router's ip address and hit go, this will take you into your router's configuration. In there you should see a wireless section in which will be security, you can secure your network there (use WPA or WPA2 it's the most secure). When you have set this you will need to enter your password to all the wireless devices connected to your network.
If you google your routers make and setting up security, you should find a step by step guide.
Hope this helps
Posted on May 24, 2008
How do I secure my wireless connection
Hi Joyce,
Either you have to setup the Encryption password ( network key ) or you need to contact your ISP ( internet service provider ) to do so.
Click on the link below and it will guide you how to set security to your router ( network )
Secure D-Link Wireless Router
Regards,Suhail
Nov 13, 2011 | D-Link DIR-300 Wireless Router
I forgot my user name and password, how can change this, i have internet now but it is unsecured
Hi deltaplus000,
Welcome to Fixya. If you want to setup a password or security on your router you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security on the Dropdown next to Security Mode select either WEP or WPA. Then Personalize your Network Key. The Network Key serves as a password on your network to make it secure. Then Save the settings
If this works dont forget to say thanks. Thanks for using Fixya.
Feb 07, 2011 | Linksys Wireless-G WRT54G Router
Unsecured network
  • You need to log into the router setup screen - you do this by connecting a PC to the Router via a cable connection and then using Internet Explorer (IE) you log into the router.
Using the default settings
  • Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, set the user name to admin and leave the password box empty. Click OK to continue.
  • Goto the Wireless security section to set the security type and the password
Section 4 of the manual - see below deals with setting the wireless security This is the support site for that router http://www.dlink.com/products/?pid=WBR-1310
Click on the Support Resources - that will take you to the manuals for different Version of that model - click on the model you have to get to the online manual
Apr 09, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Have lynksys wireless router but is unsecure -
You can enable WEP on your router to make your wireless network secure.
To access the screen of the router, type the ip address of the router in the address bar of Internet explorer or Firefox. By default the ip address of the router is 192.168.1.1. If this doesn't work, go to the command prompt (Start -> run -> type cmd). Type ipconfig. Copy the default gateway.
It will prompt you for a user name and password. By default leave the user name blank and then type admin in the password field.
Once you are in the Linksys screen, go to the Wireless tab -> Wireless security.
For the security mode, select WEP.
WEP encryption: 64bits 10 hex digits.
On the Passphrase field, type a wireless password of your choice, then click Generate.
It will give you a key. You will need to copy the wireless network key because you will need to enter this key on your PS3 and laptop. Take note that this is also case sensitive.
Once you click save settings, it will disconnect all your wireless computers.
You will need to manually enter the wireless network key on all your wireless devices. Without the network key, other computers will not be able to connect to your network.
I hope this helps.
Please take a moment to leave a comment if you find this solution helpful. Your feedback is important and very much appreciated.
Feb 16, 2010 | Linksys Wireless-G Broadband Router
My Router works only if I do not put security password on it.
The router works only if the network is unsecured.
When you secure the wireless network , make sure that you will change the wireless network name also. Because if you change the wireless security and if you keep the same network name then your computer will try to connect to the same network name with the old unsecured settings saved on the computer.
Try to change the SSID ( network name ) and security to WPA, check if that works.
If that doesn't work then I believe you will need to upgrade the FIRMWARE of the router.
Click here for more information about the routers and the wireless network
Jan 25, 2010 | Belkin Computers & Internet
Need to secure wireless connection
1. Connect the computer to your Wireless router then using the internet explorer access the router gui 192.168.1.1abd7975.jpg 2. It is extremely important that you change the password for your router. Select a strong password using numbers and letters. This is the password that you will use to login and configure your router after this initial setup. 61e656e.jpg+
79ee205.jpg 3. Select a unique name for your wireless network. The name of your network is known as the SSID. This is what wireless users will use to identify which router and network they connect to. 94c0abe.jpg
Nov 17, 2009 | Linksys Wireless-G WRT54G Router
Router
you may need to set up a security item...can't remember what it is, but you need to set up a password as well, to make the network secure
Jan 07, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
If its unsecured that means someone close to you can connect to your network..possibly slowing down your connection..,it took me a few times to get it running correctly...
Oct 27, 2008 | Linksys BEFW11S4 802.11b Wireless...
Unsecured network
open 192.168.1.1 in your browser.It will ask for username and password.Leave the username as blank and in password type admin.You will get the linksys pages.Now click on wireless on the black bar at the top.Click on wireless security just under wireless in the blue bar.Select security mode as WEP.In key 1 type any 10 digit no. which will be your security key.Scroll down and click seave settings.now your network is secured.
Jul 12, 2008 | Linksys WRT54GX4 WIRELESS 802.11G...
D-Link DIR-625 - Unsecure connection
How do you know that you are connecting and there is no security? There first thing to check is the router settings. You should type into the browser 192.168.1.1 (or whatever you have configured your router's IP address for). Enter the user name and password for the router. On the next screen you will notice a link for wireless settings. Click this and on the new page check the bottom section that says "Wireless Security Mode". It should be set to something other than "none". Post back and let me know what it is set to.
Nov 20, 2007 | D-Link DIR-625 (790069292637) Wireless...
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
