Question about LaCie (300770) 250 GB Hard Drive
When I t urn on my laci external harddrive I get a fast pace blinking light and when I put my ear to it, it seems that the motor wants to start running then nothing Just a constant blinking blue light!
    Brigadier General:
  • 10,406 Answers
It seems that you have a problem with the disk-drive inside the case. If it still is under warranty, exercise the warranty to get it replaced.
If not, then disassemble the case, and remove the disk-drive.
Connect it as a "slave" disk-drive inside a desktop computer,
to see if it can be read. If not, then it is "dead".
You could buy an identical disk-drive, and put it inside the case,
to construct a "new" external disk-drive.
Posted on Sep 28, 2010
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
My Lacie 500gb external hard disk has stopped working. it has a scratching like sound and no computer couldn't detect it. even it is not detected in device manager. when it is connected to computers it...
is the scratchy sound coming from inside your lacie or outside ??
it might be a power problem trying to connect to your lacie but unable to find the device or a dirty hard drive the reader arm skipping across the platters you could give your lacie a firm tap on the side to free up the reader arm
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Sep 15, 2011 | LaCie Computers & Internet
My Lacie external hard drive used to turn on when the computer using XP was turned on. It has stopped doing this. Any suggestions to solve this?
if your computer came with a motherboard disc the drivers could be on it
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems hope this helps
Jun 12, 2011 | LaCie Computers & Internet
My Lacie external drive clicks but won't spin up. It is about a year old, maybe less. It was working fine and just stopped working. It has not been dropped. In fact it hasn't been moved.
Your harddrive is bad, the motor bearing that spins your cylinder heads is damaged, even though the harddrive hasn't been dropped, or removed, this is a result of faulty and cheap product. Theres nothing you can do to replace the motor bearing, you will need to just get a new harddrive and install into the external hd enclosure or get a new external drive. If you decide you want to recover your files, you will need to take this harddrive out and maybe take it to bestbuy/ office depot where they will have to send your harddrive out to a data recovery center. They might be able to recover some data, or all, or none. It is a pricey move to take this step.
Jan 28, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Sometimes the hard drive will connect and sometimes it won't.
There have been problems plaguing the LaCie external harddrives, for quite some time now.
The issue directly relates to the interface, inside the external enclosure. I don't know if you are acquainted with harddrive designs, or the interface that they plug into. If you are, disregard the following.
This is an average example of an IDE harddrive, http://en.wikipedia.org/wiki/File:Hard_drive-en.svg
Looking at this illustration, note where it points to -> IDE Connector. The illustration isn't very good, but those dots are metal pins.
The connection inside your external harddrive,
that connects to the harddrive itself, is called an Interface. This is a plug that has socket holes, to match those metal pins.
Now we go a little deeper. There are two types of harddrives. One is an IDE harddrive, the other type is a SATA harddrive. Your LaCie
will have a SATA harddrive inside.
Instead of the 40 pins that an IDE harddrive has, the interface for a SATA harddrive has 7.
(It has 15 pins for the power connection)
Now my solution:
Should you wish to save data that is on your LaCie external harddrive right now, I suggest you buy an external enclosure, (SATA), take out the hardrdive thats in your LaCie, and install it in the enclosure.
Since, the dimensions of the, LaCie design by Porsche 160GB external harddrive are:
Height -> 1.4 inches, (About 1-1/2 inches)
Width -> 4.4 inches, (About 4-1/2 inches)
Length -> 7.4 inches, (About 7-1/2 inches),
I'm willing to bet the harddrive inside is a desktop harddrive size. (3.5 inches across in width)
http://www.lacie.com/download/datasheet/porsche_hd_en.pdf
These are examples of 3.5 inch SATA external enclosures,
(A $25 or $35 unit will work just fine)
Jul 18, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Does not mount, Fan not spinning. 500gb D2 quadra
take the drive out and put it in a external case and see if that helps. if not the drive is dead.
Dec 13, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
External Harddrive Overheated
The disk in side is jammed, try throwing the harddrive like a frizbe but dont let go. That might help unsick the drive
Mar 28, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 500 GB usb external hard drive clicking, and blinking....
had the same problem: (soft) clicking sound, orange/yellow blinking LED
Tried another power supply: nothing
Reattached that power supply back to the drive it was connected to: same problem there now as well!
Tried yet another power supply: working (all drives)
My guess is that the power supplies are the cause of the problem. Taking mine back to the shop next thing tomorrow morning...
Feb 18, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie (300770) 250 GB Hard Drive Logo
532 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
