Question about Seagate 500GB REPLICA USB 20 16MB 25IN COMPLETE PC BACKUP SYSTEM 500 GB Hard Drive
Since I connected a Seagate Replica 500GB Hard Drive, I started receiving multiple Error 51 Events in my Windows Event log. They state: An error was detected on device \Device\Harddisk2\DR9 during a paging operation. Should I have the Replica replaced?
    Brigadier General:
  • 10,406 Answers
First, extract all data that you have on the hard-drive, while you still can.
Seagate's web-site suggests that you first download and run Seagate's "Drive Fitness Tool", which exercises the disk-drive, and produces a "fitness" report. If it fails, then delete all your "private" files, and either take the drive back to the retail location where you bought it, or get an RMA (Return Materials Authorization) from Seagate, to get permission from Seagate to return the drive to them, for them to analyze the disk, and probably replace it.
Posted on Sep 28, 2010
When computer boots up I get this error code A disk read error occured code 0F00:0666
A bad hard drive or the boot sector (the map of the hard drive contents) has an error.
You have two choices. If you run regular backups you can do a full restore including the boot sector, if not, you'd have to format the hard drive and lose your data. Then reinstall Windows and start from scratch.
The other option that loses your data, as well, is replacing the hard drive if it's defective.
Mar 09, 2014 | Seagate 500GB Barracuda 7200.12 SATA...
I cannot drop files from my laptop to my lacie n2870. What is the problem?
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Jan 13, 2013 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
I have lenovo G560 laptop where i reformatted hard disk and loaded xp. I now get an error message
Until i know whwt the error message is and relates to i am unable to help
If you want to know what this is the error code is related to
if you need more help with this post a reply with the error message details
hope it helps
Nov 20, 2012 | Lenovo G560 - 15.6 - 500GB - Black -...
What's your problem?error code 0x80004004 when opening maxtor onetouch 4 external hard drive files
im not up to speed with this type of error or what its associated with
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
hope it helps
May 25, 2012 | Maxtor OneTouch 4 500GB External USB 2.0...
I have a problem with my 1Gb One Touch 4 external hard disk. I get error code Ox80070571 when I attempt to create a new folder or try to copy a file to the disk. I can see the images with Windows...
windows 7 ultimate
click start control panel system and security administrive tools then select view event logs then select administrive events in left panel across in the right you will see an error log with errors in red error was and at what time it occured you might be able to work your way through the problem
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope it helps
Jul 21, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
Seagate (ST310005EXA101RK) 1 TB USB 20 Hard Drive i have an error message error 55. registry problem. i plug into my laptop all is fine ..please help..wont run on desktop. has been running fine on desktop...
if this error is a registry problem
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software or only if you don
Apr 10, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
I am getting corruption in MS Word files. Text disappears on the screen before my eyes. I checked the Event Viewer/System and saw it is registering Warnings about Disk problems and cites error 51. This is...
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive or
go to control panel administrive tools computer management you can right click on the drive select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
in xp
hope this helps
Dec 03, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Fujitsu siemens an unexpected I/O error has occured
Hello olamideidowu,
Here is a way to find out what the message means. Look for entries in the system event log that happened on the same day your error message happened.
*Using the Event Viewer:
•Click the Start button on lower left corner of the screen
•Select 'Run' (on Windows XP) or Type 'Run' and press the Enter key (on Windows Vista)
•Type 'Eventvwr' (in the 'Run' box) and click OK.
•(On Windows Vista) open the Windows Logs folder in the left pane
•Select the 'System' log in the left pane
•Look at the system events that happened on the same day as the I/O error. One (or more) of those events should contain the 'unexpected I/O error' message.
•Get the Event ID and look up what it means on the Microsoft Events and Errors Message Center: http://www.microsoft.com/technet/support/ee/ee_advanced.aspx
Also, the 'Message Level' of the event shows as Information, Warning, Error or Critical. Looking at the message level can help determine how serious the event may be. Events that have Error or Critical message levels can indicate a problem on the system.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Aug 05, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Seagate freeagentGo does not work with windows server 2003
Symptoms The problem I encountered after connecting the drive to the eSATA card was the following error in the Windows System event log:
Source: Disk
Event ID: 7
Description: The device, DeviceHarddisk2, has a bad block.
At first I thought this indicated a bad disk. But eventually I saw apattern: the bad block error only occurred if the drive had enteredits "sleep" state, i.e. had spun down. By default, this happens after15 minutes. If I accessed the drive in Windows explorer after it hadspun down, in the few seconds that it took it to spin back up, Windowswould get impatient and report a bad block error. Note that the "sleep"mode I'm referring to is an internal feature of the Seagate drive--itis not under the control of Windows Power Options in the Control Panel.
If I attached the Seagate drive via a USB cable, let it spin down, and then accessed it, I did not get a bad block error.
Another symptom, one that I did not at first associate with theFreeAgent disk, was the following message in the Application event log:
Source: VSS
Event ID: 12289
Description: Volume ShadowCopy Service error: Unexpected errorDeviceIoControl(\?Volume{ba849e07-88fb-11d9-9c6f-806d6172696f} -0000017C,0x0053c020,00039B48,0,00038B40,4096,[0]). hr = 0x80070017.
This error occurred when I started an ntbackup job. Apparentlyduring Volume Shadow Services initialization, it couldn't immediatelyaccess to the Seagate drive and so logged this error. A bad block errorwas also logged at exactly the same time.
CauseMy speculation is that Windows knows that USB drives may spin down, andit will wait for them to become accessible. However, because an eSATAdrive runs as a BIOS-attached drive (similar to a SCSI drive), Windowstreats it as an internal drive and expects it to be "on" at all times.
SolutionThe solution is to attach the drive to a Windows XP or Vista machine,install the FreeAgent Tools software, go to Utilities, and set theDrive Sleep Interval to Never. Then move the drive back to the server.The Sleep Interval setting is maintained even though the drive ispowered down when moving it to another machine. Once I did this, boththe bad block and the VSS errors stopped.
ConclusionIt's obviously a pain to have to install a 142MB software package justto change the Sleep Interval, but Seagate Support said there is noother way. Too bad they don't make a simple command-line utility forupdating the drive settings. (The software has lots of slickbackup/restore features, integration with Internet drive access,etc.--all kinds of things that I don't need in this environment.) Itried installing the FreeAgent software under Windows Server 2003, butthe installation failed with a message that it only runs under Windows2000, XP, or Vista. Hence the solution of temporarily installing thesoftware on a desktop machine.
I wonder if others have had similar problems with eSATA drives thatlike to go to sleep? Eventually Windows may need to add an option totreat eSATA drives like it treats USB drives. Considering that thisdrive is only used once a day during backups, it would be nice if sleepmode worked without causing errors. In the meantime, I'll hope thatkeeping the drive out of sleep mode resolves the "bad block" errors.
copied from : http://blogs.mcbsys.com/mark/post/Seagate-FreeAgent-Pro-eSATA-and-Bad-Block-Errors.aspx
Jan 06, 2009 | Computers & Internet
FREEAGENT 250 GB AND USB2 NOT CONNECTING
Most of the time if you get an event 51 error you will need to reinstall drivers associated with that device to fix it. I would delete the device from device manager, uninstall any software that you installed for it, then restart your computer and reinstall the software. I would do this for both the card and the drive. I would also run Windows update to see if it finds any other drivers that you do not have installed. If that does not work it is possible that the card and drive might not work properly together. The only other thing I can suggest trying is reinstalling windows
Nov 14, 2007 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate 500GB REPLICA USB 20 16MB 25IN COMPLETE PC BACKUP SYSTEM 500 GB Hard Drive Logo
569 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
