Question about Canon PIXMA iP1600 Printer
Printer doesn't turn's on
Was printing and the printing just stopped. tried to turn it on, but it doesn't.
checked the cables and they are properly plugged.
printer still does not turn's on
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Per Canon:
Solution: Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
Secure all Power Connections
  • Disconnect the AC Power Adapter or power cord from both the device and the electrical source.
  • Then reconnect it.
  • If you are still unable to obtain power to the device, try another power outlet.
  • If possible, try connecting power directly to a wall outlet (as opposed to using a surge protector or power strip...just as a troubleshooting measure).
If this does not work, have you tried a different outlet to ensure that the outlet isn't the issue? Also, when you press the POWER button, does the printer respond at all, or is it basically dead?
Please post back if you need further help, otherwise, thank you for using and rating FixYa!
Posted on Jun 12, 2008
  • Cheryl Whalen Jun 14, 2008
    pixma1600:
    As I indicated in my response to you, if the Canon solution didn't work and you needed further assistance, I would be happy to help. Canon's only other indicated solution was to take the printer for repair. Further, I picked up your issue and attempted to start helping when it had not been addressed by any other expert for 19 days!
    Therefore, I don't understand why the solution is rated as "poor" without at least indicating that the solution did not fix the problem, and allowing us to help work through your problem as much as possible. Ratings play a major role in an expert's ranking and status, and I am still willing to help you check any possible issues. However, if there is a ranking, and the issue is closed without further communication, this basically eliminates the opportunity for us to help you out. Thank you for using FixYa.
    smartsolve
Problem 5200 wont print
Hi, this problem can solved by doing the following:
1-Check your usb cables, printers, and all connections to the PC are working properly.
2-Make sure you install the latest driver for your printer from the internet.
3-If you install the same printer more than once, try to delete all printers and add 1 printer in the windows control panel >printers.
4-Reset the printer spooler service in the control panel>services(or local services in Windows 7). Find print spooler. Try to stop then start it again and make it automatically start.
5-If this does not work, try to reset the PC. If that doesn\'t work, try another computer
5-If the problem isn\'t resolved, check your printer for hardware issues.
Kind regards
Apr 17, 2013 | Canon MP280 All-In-One InkJet Printer
No communication between computer and printer
There are a number of issues that could cause a communication problem with any USB printer (assuming it is turned on/has power). The most likely is a bad cable. After that, you need to check for a problem with the OS print spooler, a problem with the port (on either the computer or the printer), or a driver problem.
Replace the cable with a new one. Connect it to a different port on the computer. If you use a print server or a USB hub, try a direct connection.
Look at the list of what is printing. In Windows, open the printers control panel (click Start > Device and Printers or Printers and Faxes, depending on the OS). Then right-click on the printer and choose "See what's printing". Are several print jobs still in the queue? Try to clear these jobs by cancelling them. If you can't cancel them, you can force the print spooler to clear by stopping and restarting the service. In Windows, open the command prompt (Start > All Programs > Accessories > Command Prompt (with Vista or Win7, right click and choose Run as Administrator)). Type "net stop spooler" without the quotes and followed by enter. Then type "net start spooler" again without the quotes and followed by enter. After you see the prompt, restart the computer. After the restart, wait a while before trying to print again. (Note: if you have a fax connected to the computer, you will see a message about the fax service being stopped after the first message. Click Y.)
If the printer status is unknown, check the device manage. Click Start > Control Panel > System and Security > System > Device Manager (in Win7). Right click on My Computer and select Properties then click on the Hardware tab for XP. Look for a yellow exclamation point in a triangle next to Lexmark. Unplug the USB data cable and then uninstall the Lexmark software. (A quick link is the Uninstall link in the Lexmark folder in the list of All Programs from the Start button.) Download the correct driver from Lexmark http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X1270&focusedTab=DOWNLOADS#1 . Select the correct OS from the drop down menu. Install the software and then plug in the data cable when prompted. Alternatively, let Windows find the best driver by plugging the USB cable with the trouble-shooter. Right click on the appropriate line in the device manager. (This is not recommended with all-in-ones since Windows often only finds a printer driver and omits the scanner functions.)
While you are in the Device Manager, check for a similar yellow exclamation point or red x in a triangle in the section marked Universal Serial Bus. Try to update the driver for the USB controller (again you can right click on this).
Next try to reset the printer by removing the data cable and then unplugging the power cord from the printer. Then unplug the power cord from the outlet. Wait a few minutes (if possible, move to a new outlet). Then reconnect the power cord and then the data cable. Turn on the printer if it doesn't come on. Try printing.
If possible, try installing the printer on another computer. If the printer still doesn't work, the USB port on the printer is probably bad. If it is under warranty, contact Lexmark. Otherwise, it may be better to replace the printer instead of repairing it.
I hope this helps.
Jun 12, 2012 | Lexmark X1270 All-In-One InkJet Printer
My x4650 doesnt comunicate with my laptop when I plug in usb lead
Make sure the USB cable is properly inserted behind your printer in the USB port. You may try to unplug then replug the cable to ensure proper connection (forgive me for suggesting this but I have encountered quite a number of instances where the cable was not properly inserted).
It could also be a Print Spooler issue. Ensure that the spooler service is running. On your computer, go to Start menu > Run > type Services.msc > hit OK or enter. Scroll through the Services items and look for Print Spooler. Right-click on the item and select Start (if item is currently on Stop). You may also select Restart. Once the service is running, try to continue with the installation.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 27, 2011 | Lexmark X4650 InkJet Printer
Error 5200 of canon pixma mx328. i already tried turning it on and off several times and even got the cartridges and returned them back but still when i tried to print a page error 5200 still...
Error no 5200 is caused by its temperature high.. to solve your problem follow the instruction given below::
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 23, 2011 | Canon MX300 Office All-In-One Printer
Will not print, says printer busy
There could be some print jobs stuck in the queue. Please follow steps below to fix the problem:
1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Try to print again.
If problem continues, disconnect your printer USB cable from your computer. For Windows OS, go to Control Panel > Printers and Faxes. Delete the Lexmark print object. Reboot pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect the USB cable into your computer. Wait until your computer fully recognizes the USB connection before sending a new print job.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Jul 24, 2011 | Lexmark X5470 All-In-One InkJet Printer
Power lights flashing,will not stop
Ok sir try to turn off the printer if it doesn't. Pull the power cable shutdown your computer then plugged again the power cable of the printer then turn on the pc and printer..If it doesn't change contact a printer technician or bring the printer to the nearest service center. Hope it helps you..
Jul 01, 2011 | HP Office Equipment & Supplies
My printer will not print from my computer. It shows the scan, photo ,copy screen and will do those things. It shows that it is connected to the computer and everything looks like it will print, it just...
Check that the printer cable is connected properly to your computer and printer.
If they are ok I need to know what printer you have as alot of HP printers are having formatter board problems that will cause this.
If the cables are ok and it is not a HP printer, or even if it is, you need to try re-installing the printer driver. Delete your old driver and install new driver.
Jun 02, 2011 | Office Equipment & Supplies
Pinter ink symbols had question mark. Did spooler stop and start. Question marks gone but still not printing.
First remove both cartridges clean the gold plated area and the area where the ink goes out as well as the area where you plug it in ...And then turn it off first and then it turn it back on the open the cover wait for the cartridge carrier to go to the cetner and then install the cartridges make sure its properly plug in after plugging it in . lock the lever of carrier and close the cover .. Try to check if it will print print a test page . If nothing happens uninstall and reinstall the drivers
May 15, 2011 | Lexmark X4650 InkJet Printer
Hi, I have a printer Lexmark X2250 All-in-one. My computer can't connect with the printer. When I try to print something I get a message: 'The printer cannot comunicate with the computer'. I...
According to your problem first check that you have installed the driver properly or reinstall the driver. Check the USB cable of the printer. Replace the cable. Turn the printer off before installing the driver. Turn it on again while the driver installation wizard will ask to connect the printer. After installation reboot the printer and system both.
May 06, 2011 | Lexmark X2250 All-In-One InkJet Printer
It wont print but it doesn´t report no errors, it just doesn´t print
data cable connection may be loose
fix it properly or
change the data cable
Aug 12, 2010 | HP DeskJet 710c InkJet Printer
Canon PIXMA iP1600 Printer Logo
276 people viewed this question
old marine
old marine
