I have a shredder essentials ses-c1500 it powers up and none of the fault lights are on however when I put paper inside it doesnt start up I checked inside and it is clear of any jams what could it be?
jimnfl
  • 17 Answers
SOURCE: Machine won't draw the paper in to send the fax
Technically, your machine is jammed. The paper is jamming as it exits the feed area, and enters the machine. Not being specifically familiar with that model, but rather based on experience with other simular machines with like problems, I would say you should look for 3 possible causes... Most machines have, shortly into the paper path, and generally in the area you're indicating, some sort of sensor switch, whether it be photo-electric, or a mechanically activated toggle, that senses and registers the lead edge of the paper so the machine knows it did feed. This switch could be knocked out of place, or simply dirty, and not sensing the lead edge of the paper within a certain period of time after the machine registers the feed had been actuated. A second possible cause would be (and you may be able to visually verify this) is that usually, in these types of machines, there is some sort of pressure or "retard" pad/roller in conjunction with the feed roller. If this isn't working right, the machine may be feeding more than one sheet at a time, and becoming jammed in the paper path path area due to "thickness". A third possible issue could be an unremoved scrap of paper from a previous jam (or a staple/paperclip/piece of rubber-band/or any other foriegn object, as I've seen them all) still remaining in a thin and obscure position of the paper path blocking the paper's progress to the afformentioned switch. Those are the most likely, but probably not the only possible, causes of the problem you are exoeriencing.
Posted on Jan 07, 2007
leroyal
  • 2120 Answers
SOURCE: GBC 1026S Shredder has stopped
I think they are out of business.
Posted on Aug 29, 2008
SOURCE: says paper jam but there is none. pixma mp450
Take any paper out of the paper feeder and get a plastic ruler the softer the better lift the top of the printer up so you can see where the print cartridges are now push the ruler down through the paper feed roller be careful because you could break the rollers go from left to right right to left twice and check for any debris once you have done this unplug the printer for about 20 seconds then plug back in and let it reset then try copying or printing a doc and see how you go!
Posted on Mar 11, 2009
  • 4 Answers
SOURCE: sx-102M
I have the Infoguard SX-100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, the gears and fuse was ok, I think something on the circuit board was fried.
I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Posted on Mar 28, 2009
rulds2008
  • 3866 Answers
SOURCE: shredder won't come on
The question would be is it getting power!!! if so the motor went bad thus causing this to fail i cannot beleave yuo shred DVD's in this even know it says it can you are still putting alot of strain on the motor.
Posted on May 25, 2009
Shredder will not turn off
Unplug the shredder from the power outlet. Remove the paper canister. You will need a can of air to blow all areas both from inside of the shredder around the blade area and outside of the shredder around the blade area. After you complete that part, Check the sensor area to make sure no paper is jammed around it. Plug the shredder back in and turn it on. If that fixes the problem, get a sheet of paper and put some shredder oil on it and put it thru the shredder for lubrication.
Apr 11, 2012 | Office Equipment & Supplies
I have an Aurora Shredder -- Model #AS1512X. Paper got jammed and I pulled the paper out and now the shredder will not work. Any ideas as to how to fix this?????
Check safety and detection switches. 1. Safety is on the bottom and left or right side of shredder unit inside a narrow gap. On the bucket's wall there is a natch witch should go into the gap, when you put shredder correctly. Check if switch and natch are on the same side. Simple turning around will solve problem. 2. Check a detection switch. It is located in the middle, inside of gap. This switch engages and turns motor on when you put paper into shredder. In other words sheets of paper should push the switch first before touching shredding rolls. If you have digged out that paper from the top side, chances are you have broken that switch.
Feb 12, 2011 | Aurora Electronics Office Equipment &...
The shredder has been unplugged from power for a couple of weeks. I clean and clear paper bits from rollers and plug it in to outlet(with power). It doesn't have an on light and doesn't turn on.
Most common prob with "consumer" machines is that people put "too much" paper in them and JAM them...then if they don't unplug the machine to let it "cool-down"....by which time the machine "fries" the pcb inside.
For parts advice give Royal a call at 1-800-524-0799.
Feb 14, 2010 | Royal 29140X PX100MX Cross-Cut Shredder
The shredder is set on automatic. When I put
Most of these have an optical sensor to start them. Might need a wipe with a damp cloth (disconnect from power first!)
Nov 20, 2009 | Fellowes Powershred 4800CC Shredder
All lights turn on as needed and has power but won't grab paper to shred
suspect paper jam try using reverse button the dislodge paper.
suspect paper feed sensor is blocked or damaged there is a light beem in front of the teeth that starts the shredder if this defective the shredder will not start.
suspect a panel or bin is not correctly seated causing the shredder to not start.
Nov 13, 2009 | Fellowes Powershred 320C Shredder
Paper shredder
Shredders have a light emitter and detector inside the slot where you put the paper. When the paper is put in, the emitted light is reflected off the paper, detected, and then turns on the shredder by sending a signal to the control board. The emitter/detector often has a plastic cover which over time collects paper dust. The paper dust can reflect the emitted light back onto the detector, causing the shredder to remain on. You may need to remove the top of the shredder and remove the shredding mechanism to get to the light sensor. It's also possible that the components on the control board have changed value, causing the detector sensitivity to increase. This may result in the unit turning itself on in daytime and off at night.
Jan 15, 2009 | Fellowes DM15C Shredder
Red Light on, but no jam
Your problem is probally with the safety interlock switch on your machine. On the PS-65c It is located on the right hand side of the unit. There will be a tab of plastic on the inside lip of the basket that goes into a slot on shredder head. If plastic piece is bent or broken machine will not operate. If it does not appear broken make sure when you put shredder head on that it fits flush all the way around on the basket. If none of this helps contact Fellowes Customer Service at 1-800-945-4545 and we will be glad to assist you further.
Jan 28, 2008 | Fellowes Powershred PS-65C Medium-Duty...
Problem ts 6000
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Nov 30, 2007 | Tech Solution TS-6000 Shredder
k24674
jasbo
jasbo
