Question about Maytag MSD2754G Side by Side Refrigerator
Freezer stopped freezing - Maytag MSD2754G Side by Side Refrigerator
  • sandraole1 Sep 28, 2010
    no comment- it just defrosted and will not freeze
  • Maytag Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 28, 2010
Will compressor have anything to do with freezer stop freezing
Yes, if the compressor stops running, refrigerant cannot circulate so heat inside the freezer cannot be carried to the outside. If the compressor is running and the freezer is still not freezing, the likely reason is that the refrigerant is lost due to leakage.
Jun 20, 2014 | Refrigerators
Freezer is around 3 years old. When set at -17 degrees the freezer clicks very noisely, a relay operating I think. When the fast freeze button is pressed this clicking stops but the display reads -27...
In my opinion, since your going for the fast freeze mode, your freezer sets to its lowest operating temperature to fast tract the freezing process.
and about the noisy clicking sound it is probably a thermostat or relays depending on your system which starts and stop the compressor.
i think your freezer is just doing fine.
Dec 29, 2010 | Whirlpool Freezers
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing
sounds like your loosing freon.
Jun 09, 2009 | Refrigerators
Freezer stopped freezing up?
check the compressor to see if it works. You should hear a sound that sounds like a low hum.
Is the compressor fan on at the bottom rear of frig?
Apr 09, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
It is possible that the fanmotor in the freezer compartment is faulty which would cause a freeze up and prevent the air from circulating.
Mar 05, 2009 | Kenmore 44103 Side by Side Refrigerator
The freezer is cold, but has stopped freezing,
This may be as simple as just turning the temperature dial for the freezer to a colder setting. Do that and wait a few hours and your problem may be solved.
Feb 06, 2009 | Frigidaire FRT21H8 Top Freezer...
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Jun 03, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Maytag MSD2754G Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
