Question about Janome Sewist 625e
How do i change the bobbin tension? - Janome Sewist 625e
  • Janome Master
  • 7,365 Answers
The bobbin case screw---turn to the left to tighten & turn to the right to loosen
Posted on Sep 28, 2010
I can't seem to adjust my tension--I have it at 0 and the thread still lies on top. Any solutions?
make sure the thread is between the plates and not behind one
0 will be no tension and the tension gets tighter as the numbers go higher
Nov 24, 2017 | Sewing Machines
My bobbin thread is showing through on front please help
Loosen your top tension. If it is too tight, it will pull the bobbin thread to the top of the fabric. If it continues, then it may have to do with the thread weight you are using in the bobbin or the bobbin tension needs to tightened slightly. HOWEVER, adjusting the bobbin tension is usually a last attempt. It is a sensitive adjustment.
I frequently use a lighter weight thread for quilting and need to adjust the bobbin tension. So, I have a separate bobbin case that is adjusted for that purpose only. Having to adjust the bobbin tension every time one changes the thread weight is a real pain. For most general sewing, the factory set bobbin tension should be sufficient.
Understanding Thread Tension Threads
Nov 09, 2017 | Sewing Machines
Adjusting the bobbin tension
hi genevieve.
this is all i could find.
To make a temporary tension adjustment, select the threads for the needle and bobbin, then fill the bobbinand thread the machine. Make a test seam on the fabric that you plan to sew, examine the stitches, then see if you can find a balance using the upper-tensionassembly alone.2 Nov 2008
Understanding Thread Tension - Threads
www.threadsmagazine.com/2008/11/02/understanding-thread-tension
or go to this link might help as well.
sewing machine how to Adjust the bobbin tension Google Search
Nov 07, 2017 | Sewing Machines
Bottom tension is to tight on Jerome gold machine
Usually, the upper tension should work in tandem with the bobbin tension so they actually pull against each other. If the upper tension is too loose, then the bobbin tension will not be pulled up into the fabric. Try tightening the upper tension and see if that makes a difference. The two threads should meet in the middle of the fabric.
However, on occasion, the bobbin tension is, in fact, too tight and can be adjusted. Be sure to mark the setting BEFORE making any adjustments (so you can reverse your changes) and make tiny incremental adjustments to the bobbin tension, ie 1/8 to 1/4 turn. A little adjustment makes a BIG change in bobbin tension.
Sep 26, 2017 | Sewing Machines
Singer facilita 9858-1 top thread is winding around the bobbin case. It seems to get caught under the bobbin case retaining plate, around the left side of the case,& under the rim of the posi
try cleaning cleaning the tension disks, remember you tension setting,, take some unwaxed dental floss and go between the disc's to clean in them, and then reset the tension disc's by to normal
Dec 10, 2014 | Singer Sewing Machines
Do I need to adjust bobbin tension when changing stiches
Usually one does not change bobbin tension. Adjusting the tension on the needle thread is all that is required.
It is sometimes necessary to change the bobbin tension but only when changing to an extremely fine, slick thread or to a very heavy, rough thread.
Oct 02, 2014 | Brother Sewing Machines
How to adjust tha tension on the bobbin on kenmore model 158.13180
Hello Sharon, Remove the bobbin case from your machine. On the side of the bobbin case you will find a single slotted screw. If you want more bobbin tension, turn that screw to the right. ( clockwise ) If you want less bobbin tension, turn that screw to the left. ( counter clockwise ) When you change the bobbin tension, you may also need to adjust your needle tension to match.
Mar 25, 2013 | Kenmore Sewing Machines
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
Thread or bobbin tension
Thread tension. Beware of adjusting the bobbin screw. Pfaffs maintain their tensions just fine without adjusting the bobbin tension, unless you're using some crazy thick or fine thread. If you must change your bobbin tension, you would be well-advised to buy an extra bobbin case, because re-calibrating your tensions after changing them can be less than fun.
Increase your top tension, and your looping should cease. I normally keep my tension around 4.5. Also make sure you're using a good quality thread, and that there's nothing in the upper tension assemblies. Sometimes a tiny piece of debris can keep the top tension from applying enough tension, so turning the machine off and blowing some canned air in there can help as well.
Good luck,
-R
Mar 10, 2009 | PfaFF Creative 7570
Bobbin tension
If the looping is happening on the underside, it is your top tension that is to blame, conversely looping on top is bobbin tension.........take a look HERE for detail on cleaning lint buildup.
Top tension should be set around the middle of the range, usually 4 - 6.
I would not advise playing with bobbin tensions, however, you can take the needle plate off to clean the hook race area (where bobbin case sits) ...this is good housekeeping, my wife does this every time she replaces the bobbin....just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint, if there appears to be fine dirty deposits, a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit will do the trick.
Bargainbox
Jan 26, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Janome Sewist 625e Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
