Question about Sony Handycam DCR-TRV340 Digital Camcorder
LCD NOT BRIGHT AND SOMETIMES DONT WORK - Sony Handycam DCR-TRV340 Digital Camcorder
    Genius:
  • 1,812 Answers
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 28, 2010
Increase in brightness & sometimes switch to "negative" momentarily
he Dell I'm using also has an adaptive brightness, regardless of the fact it does not have a light sensor. It just changes brightness of the screen depending on how much white/black is shown at that moment. Whenever I switch from a very dark to a very bright website I notice and increase/decrease in screen brightness. I'm running Windows 7 by the way.
Good Luck
Jan 01, 2018 | Samsung SyncMaster 2333SW 23" LCD Monitor
Lcd display too bright
Use the buttons on the LCD display frame to bring up the screen menu. Sometimes these buttons are hard to see, but feel around for them usually next to the power on button. You should be able to navigate to Brightness setting and reduce it to desired level. Often 50 to 75 percent is good..
Dec 11, 2010 | Computers & Internet
My laptop screen is bright. Brightness control works but no picture. The picture is ok on external monitor. Sometimes a faint and incomplete picture appears on startup but disappears after a few seconds....
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Aug 25, 2010 | Compaq Presario 700 470024-192 Notebook
The brightness adjustment scale keeps appearing. I
Hi!!! You can end process by going to task manager and click processes tab. Look for the brightness adjustment among the list and click end process.
Hope it works!
^_^
Jun 03, 2010 | iiyama AX3817UT D 15" LCD Monitor
Lcd screen- bright is low
Sometimes there is a switch on the laptop on the keyboard bezel, up by the screen. Check to see if it's stuck down somehow. That switch cuts power to the inverter.
Also, when you first turn on the computer, do you hear a very faint hissing noise? If so, you may have a short in your LCD. Replacing the LCD would be the next step in this case.
Jan 24, 2009 | Acer Aspire 1690 Notebook
Philips 170s6fs monitor: OSD menu blocked
.well i had the same problem but my dad fixed it.
.he opened the monitor [like unscrew it.] and just clean it. brush it. and it will work fine.
if it didnt i dont know.
Dec 06, 2008 | Philips 170S6FS 17" LCD Monitor
Screen come on but very very faint
first reset ur phone then if it dont work open the lcd portion and pres the jack. ur lcd should work. reply me
Jun 05, 2008 | Motorola Mobility RAZR V3
L13V36 Dark Screen, picture can be seen in bright light.
If the backlight lights up for a second it's probably fine - It lay odds on the display inverter in the screen. Actually finding parts for anything made by gateway may be difficult, however. They do not sell spare parts. Considering the size of the LCD i bet it would almost exceed the replacement cost of the screen to repair it
Dec 30, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Screen`s brightness less
<Fn> + <→> Brightness up Increases the screen brightness.
<Fn> + <←> Brightness down Decreases the screen brightness
If tese dont work either your LCD lamp or board may be going bad.
Nov 18, 2007 | Acer Aspire 5600 Series 5630-6951 Laptop
FD-88, viewing LCD in daylight, too bright
You're not doing anything wrong. Sometimes it's just hard to see to LCD. You could try turning down the brightness, or turning off the backlight, but that doesn't work very well either. There are sun shields for sale. I have a FD-88 also, And so far I've been able to see the screen ok in sunlight. But It's winter in Minnesota so the sun is low in the sky, and I can normally shade the screen with my body. Hope this helps.
Sep 11, 2005 | Sony Mavica MVC-FD88 Digital Camera
Sony Handycam DCR-TRV340 Digital Camcorder Logo
13 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
