Question about Samsung Health & Beauty
I have hd 1000s. keep ghetting ERR 1 when it begins inflating the cuff, stops and displays error message
    Problem Solver:
  • 6 Answers
My Omron only goes up to about 165 only takes about 1/2 the time it takes to get a reading from my Samsung. For my Samsung, I use a couple of velcro straps (can buy them at electronic dept's and they sold as wire-cord wraps), and I place them so they go across the seem of the arm band and keep it tight as the BP pressure goes over 215. This solution for me is the only way I can get this machine to perform consistently. It still runs about 10 higher than my Omron, but it is consistent - and now no longer gives me "Err-1" messages. BTW - I've got an order in for the "Advocate Wrist Blood Pressure Monitor" and I'll be happy to post how it works after I receive it.
Posted on Jun 12, 2013
  • Chris Roark Nov 07, 2014
    Sorry for the delay in my update. I received my Advocate Wrist Blood Pressure Meter and I haven't looked back. It's small, runs off of two AA-batteries, and it has a five inch wide band with built-in velcro surfaces. I have NEVER had any problems with this new meter. It's small, so I can take it anywhere. And it's easier to put on that a wrist-watch band. Remember "Advocate Wrist Blood Pressure Monitor". :-)
SEGlover
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Posted on Jan 19, 2010
Testimonial: "Sound advice."
  • 54 Answers
SOURCE: Cuff won't inflate
It probably has a leak. Examine the hose and cuff for cracks by flexing it , especially at the fitting where the hose attaches to the monitor. Also check where the hose attaches to the cuff. Try replacing the cuff.
Hope it helps. Please let me know.
Thanks
Posted on Apr 27, 2010
SOURCE: The Sunbeam blood pressure kit doesn't inflate the cuff.
You have the same problem I do. The hose socket to the machine is broken.
Posted on Sep 06, 2010
  • 23 Answers
SOURCE: Cuff does not inflate properly. Blows up like a
I think your BPM machine has some problems in the electronic components it might not due to the cuff. Shoud return to the shop when you bought it from.
Posted on Jan 11, 2011
Testimonial: "Thanks for your advice................makes a lot of sense."
  • 23 Answers
SOURCE: wrist cuff fails to inflate
1. either the wrist cuff connection to the unit is not connect properly. OR 2. the motor pump is not working OR 3. the air tubing inside the wrist type BPM has leakage.
return to the shops for a new one.
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
Err code 3
From manual at pag.3:
err code 3Appears when pressure value did not increase during cuff inflation: 1) cuff is not fastened 2) air connector is not connected properlMake sure cuff tube is properly connected to monitor, cuff is securely fastened and exhaust rate is between 2 mmHg and 5 mmHg. Make sure air connector is inserted properly into tube and monitor.
refer to manual
Mar 05, 2012 | Lifesource UA 767 Plus Digital Blood...
HD 1000S Blood pressure monitor will not display blood pressure after inflating code ERR 1
tighten the cuff more around the arm or if you have a small arm pull your sleeve down then put cuff on and try it that way see if it helps
Jan 22, 2012 | Health & Beauty
I just put new batteries in my Omron HEM-780. Doesn't work. When it finishes deflating it always says E7. What's going on?
Hi library336
The Omron HEM-780 generally has 5 Error Messages:
1]
ERROR MESSAGE: A single (E) Error message indicates movement during the measurement process, resulting in an inconclusive reading or the absence of a Blood Pressure or Pulse reading caused by a weak Arterial Pulse.
SOLUTION: Remove the cuff. Wait 10-15 minutes. Repeat measurement using approximately 40mmHg more pressure than in the previous measurement.
2]
ERROR MESSAGE: A Double (EE) Error message indicates an under-inflated cuff. Remove the cuff. Wait 2-3 minutes.
SOLUTION: Repeat measurement using approximately 40mmHg more pressure than in the previous, under-inflated measurement.
3]
ERROR MESSAGE: An E directly below another E Error message indicates an over-inflated cuff (in excess of 300 mmHg). Remove the cuff.
SOLUTION: Wait 2-3 minutes. Repeat measurement using approximately less pressure than in the previous, over-inflated measurement.
4]
ERROR: A Blank Screen indicates low or depleted batteries.
SOLUTION: Remove and replace all 4 AA Batteries. Do not mix used and new batteries.
5]
ERROR MESSAGE: An (Er) Error Message indicates an abnormal memory function caused by a faulty internal component.
SOLUTION: Call Omron Customer Service, Toll Free, on (in the USA) 1-800-634-4850 (or on the equivalent Toll Free or Freefone Number in your country).
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 15, 2011 | Omron Health & Beauty
Sometimes err comes up on the screen, why?
Jean, I'll answer both your questions that you posted separately. The change in sound you hear is caused by the monitor noting a change in how it's reading you BP. The error message is probably directly related to the change in sound. Errors are caused by several things:
  • The Cuff has been placed incorrectly. Cuff should be placed on the wrist, at least 1/2" above the heal of the hand.
  • Talking or movement of your wrist or arm during measurement. Measure again. Keep wrist steady during measurement.
  • Shaking of the wrist with Cuff on. Same as above.
  • Air circuit abnormality. Turn unit OFF and then Back ON and measure again
  • Inflation pressure exceeding 300mmHg. Switch the unit OFF and measure again.
  • Error determining measurement data. Wait 1 minute and measure again.
If you continue to have problems with the unit, it has a 5 year limited warranty ... Contact HoMedics Customer Support 800-466-3342.
Hope this helps answer your 2 questions and helps to solve the problem for you.
Happy Easter!
Apr 23, 2011 | Homedics BPW 200 Automatic Wrist Blood...
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
It keep giving me a ee reading every time i try to use it
Hi. One of the most common error symbol that appears on this display panel is a EE with a down arrow and two numerals. The reason for the EE Error Indicator is usually caused because the cuff has been wrapped too loose. The cuff was under-inflated during the measurement. This error will also display if the cuff is worn and needs to be replaced. The EE symbol with a down arrow indicates the cuff is over-inflated. In most instances the cuff has been wrapped too tight or you are using the incorrect cuff size. Turn the monitor off. Read the instructions to correctly apply the cuff. Wait five to ten minutes then take another measurement. This should correct the issue.
Aug 19, 2010 | Omron Model HEM 432C Manual Inflation...
Walgreens HD303 Blood Pressure Monitor error 3
measurement.
Error Codes
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
When the pressure comes up on the monitor the top number was reading EE. It did it three times. I can't find the instructions. The machine is an Omron model: 741CREL. Thanks.
EE=Cuff under-inflated=not inflated enough. While cuff is inflated, keep pressing START button until pressure reaches 15-20 mmHg higher than the pressure when it stops and displays EE. Make sure at least 5 min allowed between readings.
Feb 21, 2009 | Omron Automatic Blood Pressure Monitor...
Health & Beauty Logo
488 people viewed this question
Top Samsung Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Joe Ball
Joe Ball
Are you a Samsung Health and Beauty Expert? Answer questions, earn points and help others
