Question about Electrolux Vacuums
The rotating sweeper on my Electrolux Discovery II isn't turning. Can I assume there is a belt that needs to be replaced? Also, how do I get at the sweeper unit to replace the belt? Finally, where can I find a replacement belt? Thanks!! Dewey
4 Suggested Answers
  • 70 Answers
SOURCE: Electrolux 1572E (Discovery II) How to remove
Remove the handle assembly by taking the big screw out and pull up on the handle. Remove the four screws where the top half connects to the bottom half. Two on the outside back and two on the inside front where the bag goes. You'll need a long phillips #2 screwdriver. Always have the power disconected. Pull up on the bag housing while twisting it side to side.
Good luck after you get in.
Posted on Aug 10, 2009
jspahn
  • 105 Answers
SOURCE: the bagless rotor does not rotate/sweeper does not rotate
There is no rotor inside the clear container that turns on a DC07. The stuff spins due to the shape of the airflow. Perhaps your cyclones are completely clogged. you can clean them yourself. see this video http://www.youtube.com/watch?v=2OO3ugkyzxk
Posted on Jul 10, 2010
  • 694 Answers
SOURCE: how do i get into the electrolux discovery II
There are two square holes on the outer side of the wheels. Use a flathead screwdriver in these to release the latches. Turn the powerhead over and carefully lift the back of the cover off and pull back slightly to lift off. To remove the brush and/or replace the belt, remove the tiny screw on each end of the brush and lift brush out.
Posted on Mar 20, 2011
Electrolux epic 6500 carpet sweeper cuts off and on while vacuuming
Your description indicates an internal break in the wiring carrying the current to the sweeper motor, though it could be just a loose connection.
The unit will need at least partially dismantling for testing and examination.
Feb 27, 2018 | Electrolux Vacuums
How do you remove the bottom of the electrolux model 1572E to replace belt?
the discovery electrolux are different. :)
The top comes off, not the bottom like other vacuums.
After taking the screws out, turn the vacuum on its side (vacuum handle to your left, front of vacuum to your right when looking at bottom).
There are two rectangular holes, one on top above the wheel and one on bottom below the other wheel. Place a flat head screw driver in one of the holes and pry gently, pushing handle of screwdriver toward your right. At same time pull up on top plastic of vacuum. Do the same thing for the other side. Top should come off.
Best to you.
Jan 18, 2018 | Electrolux Vacuums
Bristles quit rotating and smelled like something was burning. It isn't the belt that turns the bristles. Can't afford a repairman, can you help me fix it?
Belt can reamin intact but still jam and burn. It won't necessarily break. I suggest you remove the bottom of the vacuum where the bristles spins and where the belt is located. You may have something jammed in there. You may need to remove the bristle to get the belt out. Inspect the belt and replace after clearing the obstruiction.
Sep 21, 2012 | Bissell 6594 PowerForce Bagless Upright...
How do i get into the electrolux discovery II powerbrush assembly? I have removed all screws but still no access?
Mar 20, 2011 | Electrolux Vacuums
How to remove brush cover of discovery advantage upright vscume cleaner
Lay vacuum on table or other surface on it's front.
Remove the 4-5 screws on the base plate.
There may be a rectangular hole on each side of the wheels. If so, insert a standard screwdriver and rotate gently to release latches.
Carefully hold the halves together and turn vacuum onto it's back.
Lifting from the back, remove the power nozzle cover.
If replacing the belt or brush, remove the screws located at each end of the brush. Lift brush out and remove belt.
You can no replace the belt, brush, or both. I also recommend giving the insides a good cleaning before reassembling. Make sure when you reassemble, insert the lip of the cover into the slot, then close the back. Some gentle manipulating may be necessary.
Mar 04, 2011 | Electrolux Vacuums
The carpet sweeper on my electrolux stopped working....used it for a little bit and then it just stopped
Make sure the brush is cleared and clean, press the reset button, and try again.
If the motor runs, but the brush doesn't turn, it's likely due to a broken belt. Have it replaced by someone who knows what they're doing.
I strongly recommend taking it into an authorized shop.
Dec 04, 2010 | Electrolux Vacuums
How do you get into Elecrolux Discovery Upright to replace bely
make sure you got all the screws, and then gently pry the cover off, its probably never been off i presume , have some patienc and you'll get it
there may be a fifth screw
Jan 16, 2010 | Electrolux Vacuums
Have an electrolux 2100 canister vac, it has lost suction power thru the years. no clogs in newer hose or in sweeper. even with new bag, filter and belt only increases power minimally.
Have you ever over the years replaced your brushroll ? Have you tried dropping a coin thru the hose from one end to see if it comes out the other end ? Have you taken the wand loose from the elbow ( the swivel part of your carpet sweeper) to see if there was a blockage ? Does the motor make a strange noise ? Have you ever had a tune-up on your vac.
You might think about taking your vac to your Aerus/Electrolux shop.
Joe
Nov 19, 2009 | Electrolux Vacuums
The rotor sweeper is not turning.
Need a make and model number - but more than likely the belt came off or broke
Nov 28, 2008 | Electrolux Vacuums
Kirby generation3 instructions,
Hi there!
If you are talking about the main sweeper attatchment, Lift the light at the front of the upright machine, Make sure the belt inside the sweeper it is over the hook when you turn the handle on the front anti-clockwise to "belt off". Turning handle raises belt.
The hooks at the bottom of sweeper go over the bar at the base of the body. It helps to lift the wheels slightly.
When hooked on, rotate handle clockwise to "belt on" and close the light cover.
Is this solves the problem , please take a moment to rate as Fixya! If you need more help, just ask again on this question.
Thank you.
Jun 19, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Vacuums Logo
24 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
