Question about Euro-Pro 9130 Sewing Machine
I need some replacement bobbins. can you tell me where I can get some, or what the type is so that I may be able to match it at my local sweing supply store? I am short on time.
Am looking for the bobbins did you fine them
Posted on Jan 21, 2011
Jenomi 392 sweing machine bobin thread is not coming up
Be sure to install a brand new needle. Needles should be changed frequently as bent/damaged,worn needles will cause problems with the stitching quality.
Remove all the thread.
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Set the upper tension to the midway point between high & low number.
Bring the bobbin thread up before beginning to stitch.
How and Why to Bring up the Bobbin Thread
If it still will not bring up the thread, then it most likely has a timing issue. Take it for service.
Aug 30, 2016 | Sewing Machines
What size bobbin do I need?
Consult your owner's manual. It should tell you which bobbins work in your machine. There are many, many bobbins on the market, so you need to be sure you have the right one for your machine.
You can probably also search the internet for:
Machine Manufacturer + Model + the word "bobbin"
and you might find a supplier of bobbins for your machine. You can also try visiting a local dealer for your machine. P.S.--you'll need to know the model of your machine.
Jan 05, 2016 | Sewing Machines
Need bobbins for PFAAF 875
Search the internet for:
Pfaff 875 bobbins
or check with the local Pfaff dealer.
Nov 12, 2015 | Sewing Machines
My brother Disney sewing and embroidery se- 270d makes load noise and stopes tangles thread and material
I was just telling someone else that I recently learned from the sewing goddesses that be (at my local Hancock's Fabric Store)--that--you have to use the right bobbin. I mean plastic if your machine came with plastic. Class 65/ 55 (I think those are the numbers) as to match the machine's design. Use metal if your machine came with metal.
the bobbin case is weighted "just so" in order to be sure to run smoothly with the particular bobbin type.
Of course, the top tension and bottom tensions must be checked as well.
You could have some stuff stuck in the bobbin encasing thingy (it has two black tapered lever arms that you can move about 15 degrees to the outside and the case encasement pops out).
Mar 03, 2014 | Brother Sewing Machines
Singer 7462 not picking up bobbin thread
it's very possible that the machine could be out of time & needs to
be checked by a sewing machine technican
Jul 29, 2012 | Singer 3820 Mechanical Sewing Machine
Juki sweing machine timing problem
the timing of your sewing machine is, check your bobbin in right position, quit tightin the tension, and the timing for tiches is just always # 1.5
Feb 25, 2009 | Juki DDL-8300
KENMORE SEWING MACHINE MODEL 1792181
Call some local dealers and tell them what you are looking for. I,m sure one of them will have it,maybe even in stock. It's not always easy to know which bobbin case you need ( especially Kenmores) so be prepared to take in the old bobbin case or the bobbin or even the sewing machine for ready Identification.
Some helps; If your bobbin has holes all the way around then you probably have a standard case with a finger sticking up which you can get from any dealer. If you have a solid bobbin and a wrinkle finish paint on the machine you have an older machine and the dealer may have to order it for you. Be aware there are 2 different sizes of this bobbin case.You must get the right one for it to work.
sewman7
Jul 19, 2008 | Sewing Machines
Euro-Pro 9130 Sewing Machine Logo
60 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
