Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
WE HAVE A ROBINAIR 34788 JUST OUT OF WARRANTY. WILL NMOT PURGE AIR FROM SYSTEM AFTER TWO OR THREE VEHICLES. LOCKED UP. IS THERE SOMETHING THAT WE CAN DO AT THE SHOP HERE W/O TAKING TO REPAIR FACILITY 60 MILES EAST. DAVE S/. ztrbndr1220@frontier.com
    President:
  • 180 Answers
Opeen front cover and check air purge solenois (12VDC) on top of ISV (Internal storage vessel) tank. It may need to replace solenois coil or rebuild solenoid assy.
Posted on Oct 01, 2010
Robinair 34788 keeps overcharging the isv how do i fix this issue or how do i find out whats wrong
Robinair 34788 Set Up Operation Part #1 - YouTube
? 6:05
www.youtube.com/watch?v=XW8o5tahLpE
Aug 30, 2013 - Uploaded by OTC TOOLS This video takes the viewer through the entire Set Up and Operation of the 34788. The Cool-Tech 34788 ...
Aug 26, 2015 | Robinair Measuring Tools & Sensors
We have a robinair 34788. When attempting to CHARGE a system our machine will begin the purge air cycle. I can hear the solenoid open and the air escaping through the brass filter. It will always time out...
There is a leak in the internal system. It is trying to remove the air from all internal sections in order to store clean Freon that it removes. YOu need to check all the hoses and connections as well as the vacuum pump to be sure that there are no bad connections etc.
Mar 04, 2018 | Measuring Tools & Sensors
I'm Archie i've a Robinair 34988 just five days old and having problem with it. It keeps displaying HIGH PRESSURE (HIGH PRESSURE RESET). whether you try to vacuum,recharge, refill or anything...
This is a common problem of Model: 34788, 34788-I, 34988, AC34788, GE48800 etc.
You need to replace air purge solenoid (Air purge solenoid located on top of the ISV tank, if you open front panel cover then you can see it on top of the tank).
After doing above stapes and your problem still exist then you have to replace PCB relay board. Just claim for warranty (Air purge solenoid and PCB relay board) from where you bought the machine.
Hope this will help to solve your problem, if so please vote for it for farther help! Good luck
May 16, 2011 | Robinair Cool Tech 34700Z Recovery,...
I have a robinair 34788 and when i tunr it on it shows a massage "hi pressure "
Hope this will solve your problem, if so please vote for it for farther help! Good luck
May 13, 2011 | Robinair Cool Tech 34700Z Recovery,...
34788 COOL TECH,FILTER LOCK OUT,REPLACED FILTER TWICE STILL LOCKED OUT,READS FILTER ERROR
Check the filter monitor air flow differential switch is not blocked or broken. have you a manual reset after filter change?
Aug 03, 2010 | Robinair Cool Tech 34700Z Recovery,...
Cool tech 34788 purges alot. Excessive purge time and set error messages for being unable to purge.
Please check 1# The refrigerant which you'v add to the machine, it may CONTAMINATE or NOT PURE R134a. the machine will purge continue while active VACUUM mode if refrigerant is not origenal ! Identify refrigerant if possible.2# Check the automatic air purge device & air purge solenoid repair or rebuild as require
Jul 13, 2010 | Robinair Cool Tech 34700Z Recovery,...
Cool Tech 34788 "air purge not working"
Please check ISV tank air purge (pressure) transducer & 12V DC discrete Solenoid ( both lacated on top of ISV ), it sounds like defective!
NOTE: Never use Automatic Mode till you are not very familiar with this machine
Jul 06, 2010 | Robinair Cool Tech 34700Z Recovery,...
Hi. We've got a CoolTech 34788. Whenever the machine tries to purge air from the tank, we are consistently getting a message saying that the "Air purge timed out". The internal tank shows ~10 lbs of r134a....
It's sound like normal. However when thes message come again you just press Stop/No key to terminates this function. Press Recover & see if the machine is going to recovery after self clearing. If it is then you can continue to work. Hope this will help you best of luck!
Jul 01, 2010 | Robinair Cool Tech 34700Z Recovery,...
Robinair 34788 not pulling a vacuum
It's seems to be problem with your unit relay board,vacuum pump or pressure transducer.Most of Robin air 34788 machine having same problem.You can try as follows 1# Open vacuum pump oil filling cap to release extra pressure from pump.2# Replace new relay board & follow the on screen message(do not skip any option).3# Check pressure transducer is working properly.I hope this will help you.
Jun 06, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
1,084 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
