Question about Toshiba 57H82 57" Rear Projection Television
The image on the tv is blurred, it's not clear. If I try convergence, menus are very clear and adjustments are clear, when I switch back to the tv image, its blurred again.
  • 42 Answers
Sound like you have a bad hyper board.not available new..need to be rebuilt by a rebuilting company
Posted on Sep 28, 2010
Not a clear picture
CRT projection televisions need periodic maintenance to maintain a clear picture. Typically, to maintain a sharp picture, they require cleaning and alignment every two or three years. If the television is being used in an environment where there is cigarette smoke or other smoke sources, the optics inside the television can become dirty and cause the picture to blur. Additionally, CRT focus and alignment wander over time, or physical CRT alignment can be knocked out if the set is bumped or dropped. All RCA CRT projection televisions have an "alignment" or "convergence" adjustment in their adjustment menus, which are fairly simple to use. The convergence feature is usually accessible from the main menu of the television. Check your User's Manual for the procedure to touch-up the convergence adjustment and see if you are able to achieve a sharper picture. If the optics in your set have not been cleaned for several years, or if it is in a smoky environment, the picture will be blurry and usually a brownish color, In any case, since the set is several years old at this point, it's likely due for a cleaning. This is best done by a technician, and mostly involves physical cleaning of internal lenses, the refractor mirror on the back of the chassis, and the back of the opaque display screen. An adjustment of CRT bias controls and individual CRT focus adjustments will bring further improvement in the image sharpness and clarity.
Jul 08, 2011 | RCA Televison & Video
MY TV IS OUT OF FOCUS ON THE ENDS CLEAR IN THE MIDDLE WITH GHOSTING RED A BLUE EVERWORD OR DIAGRAM LOOKS 3 D OR DOUBLE VISION WHY
have you tried adjusting the convergence on the tv
once they get older or get moved you need to do this
go through on screen menus and look for adjusting convergence menu and follow on screen instructions
good luck!
Mar 25, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Just the blue on my rca projection tv is blurred. on the auto convergeance it says it cant read the sensor. on manual the cross hairs for the blue are oversized and blurred. i tryed tuning in the focus but...
Have you try adjusting your focus/screen drive controls to Tube R/G/B you have a focus/screen drive control block to adjust each Tube 3 controls ontop 3under them top ones are for Focus bottom is for screen drive.Red/Green/Blue Tubes.You might need to replace convergence IC, what is your Model number printed on back of TV?
Mar 24, 2010 | Televison & Video
Poor picture quality, the picture is blurred and
You have problem with convergence. Have you tried adjusting in the users menu. This is a common problem in this type of TV, usually two convergence amp need to be replaced and sometimes sets of resistors are also to be changed.
Mar 02, 2010 | Sony KP-43T70 43" Rear Projection...
Image is harp in center and lburred on both sides.
Readjust ur tube back to the original position.Ur convergence is dead,Must know to solders?Replaced the 2 convergence ICS and all it resistors.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 06, 2010 | Televison & Video
Tv projecticg 3 images in red blue and green
Your convergence probably needs to be adjusted. Somewhere on your menus will be an entry for Auot Convergence or just Convergence. The TV will normally display a set of lines in 2 or 3 different colors. You would then adjust the lines so that they line up perfectly. That should take care of the issue.
Aug 12, 2009 | Philips 50PFP5332D 50 in. Plasma...
There is blue yellow color blur on the screen with cable or dvd
This problem is of "CONVERGENCE". You have to replace the convergence IC's which is better to buy a new one TV, Just contact any expert and replace the convergence IC's and your TV work fine again you need not to buy a new TV.
Thanks for using fixya.
Jul 24, 2009 | Toshiba 42H81 42" Rear Projection...
Projection lights
You need to take the Toshiba remote that came with the machine and go into a menu area that deals with convergence. Here's what the manual says:
This TV used 3 separate TV tubes, red, green, and blue. The R, G, and B images are pojected onto the screen wheree they converge to form a full-color picture. You can see a clear picture only when the three images converge correctly. Corvergence my drift over time, or if yo move the TV. I you can see clear images on your TV screen skip this procedure.
Make this adjustment only after the TV as been on for at least 30 minutes.
Press the TOUCH FOCUS (auto convergence) button on the front of the TV at the bottom.
The TV will enter into the convergence mode and adjust the converge automatically (that's what it says.)
TO ADJUST IT MANUALLY:
Press MENU, and the press < or > until the PICTURE menu appears.
Then press UP or DOWN to highlight CONVERGENCE.
Press < or > to display the Center Convergence menu
There's a lot more the book says, but, I can say from experience that you just go through the different sub areas of this menu and converge each color separately, and bingo, it's fixed.
Good luck.
Sep 06, 2008 | Toshiba 43H71 43" Rear Projection...
Hitachi 43fdx20b blurred Picture
Yes this is a normal diagnoise. Just about every Tube type projection TV set ever made will one day need these IC's replaced. They are not really that hard to replace but you would need to know how to solder and unsolder on printed circuit boards, know the procedture, and then have a service manual handy to adjust the convergence after yoou replaced the IC's. If the tech works on alot of these types of TV sets's, most likely they could adjust them without having a service manua handy. This repair done by a pro should run you anywhere from 250 on up to 400 bucks depending on who does the repair and where. Good Luck
Mar 31, 2007 | Hitachi 43FDX20B 43" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
417 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
