Question about Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher
I posted a question about my Maytag Dishwashere MDBH945AWW not starting, all lights function, and got a response from you seen here in this thread http://www.fixya.com/ThreadView.aspx?thid=6123266&prdid=519913 I was checking the water inlet valve for a clog and have determined with a meter that there is only 25 volts going to the water inlet valve. I notice a blue wire goes to the float switch which I already checked, there are 2 black wires one of which runs towards the back and cant see where it goes, and the other black wire goes up through the door I would guess to the control panel. Do you think the control board is bad? If all panel lights work does it mean the control board is okay?
  • Maytag Master
  • 43,501 Answers
No, the lights can be working and a relay on the board can still be bad. These things can be very difficult even for a pro to trouble shoot as there can be many things that possibly can cause a unit not to start.
From what you are saying the board could well be your problem but you may want to pull the dishwasher so that you can follow the black wires and check the voltage on it. Or pull the panel off so you can check to see if power is coming out of the control board. It may be worth just a bit more investigating..
heatman101
Posted on Oct 01, 2010
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
Nothing happens when the Start button is pushed. Breaker is not tripped.
Hi - check the door switch its likely to be faulty or not closing properly.
cheers
Jun 26, 2011 | Maytag MDBH945AWW / MDBH945AWQ /...
Disherwasher not rinsing well. Top shelf glasses/cups seem to have food residue. Maytag mdbh945awb
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101;;
May 20, 2011 | Maytag MDBH945AWW / MDBH945AWQ /...
I have a 4 year old Maytag MDBH945AWW and the panel lights come on and I can select cycles... but the dishwasher wont start. I tried holding the start cancel button, tried turning the breaker off for a...
What you need to do is read for continuity and power across the door latch switch. (2 white wires) AND 2 Black wires Both wires must read continuty at the control panel connectors to the power source terminals for the unit to start. Since the control panel lights up I have to assume that the black wire from the door switch has 120VAC on it.
There is also a turbidity sensor that can cause this: http://www.appliancepartspros.com/part_details.aspx?part_id=4114286&image=1
I an not telling you to change parts. You really need to use a meter and follow 120VAC power to find out where it stops when it should be passing through a component.
If you can interpet this diagram....
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=1318099&pkw_=basket&model_id=5177084&NewWindow=1
I do not think at this point you need a control panel. It is possible but... the door switch and the thermistor will prevent the unit from starting.
This is ONE source for replacement parts.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177084
There are numerous parts sources on line and locally.
Don't give up on your dishwasher too soon. 4 years is about mid life for your dishwasher.
Thanks for choosing FixYa.
Kelly
Sep 23, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Maytag dishwasher mdbh945aww3 does not start washing. the only button that seems to work is the start/cancel and all it does is turn on all the lights.
you have to get the touch pad replaced. my worked for 11 month, got it replaced (3 weeks to get the part), worked for 1.5 month and broke again out of warranty. time to get a new dishwasher and extended warranty. maytag is total c$%p. Everything is made in Mexico. I think even China makes a better product. WOW did I say that?!?!
Jun 27, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Maytag Dishwasher-MDBH945AWW
About the only things that move in the cabinet other than the water pump is the spray arms. The lower arm should be screwed down fairly tightly (plastic screw), but the upper arm is held in place with a plastic friction plug--it tends to wobble more. Spin both arms by hand to see if either hits something (have the drawers in). The lower arm has metal clips on the ends which may be coming loose. They are just clipped onto the arm edges. Hope this helps!
Apr 06, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Will not start
I have the same problem and it turns out that it is the front panel touch pad that cost $185 for the part. I plan to just buy a new washer.
Jan 19, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
Maytag dishwasher won't start
"unlock" the machine by pressing on '3' and holding for a few seconds. Thats what it says on the back of my dishwasher which is the exact same model.
Oct 05, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher Logo
99 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
